Question about Brookstone Siemens Gigaset Euroset 5040 Corded Phone with Proximity Sensor
I can't access to my gigaset 504 AGU router's advanced settings
I change the password without connecting the cable and my internet stopped working then i went for reboot and fter that i cannot access to my advance settings and i redirect me to the login page again and again
How can i know or change the main password for administrator. I cant access main page for Siemens Gigaset 504 AGU, because he inform me that password is invalid although on the default generally password...
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa
Jul 06, 2014 | Siemens Efficient Networks SpeedStream...
Gigaset 504 agu
power up your modem and connect to your computer directly with an LAN cable.
open your web browser (internet explorer)
type 192.168.254.254
and enter
you will be asking for administrator password which is normally "admin"
hope this answers your query
Jan 15, 2014 | Siemens Efficient Networks SpeedStream...
Hi there I have a gigaset 504 agu router and my
Its means that 11 people are using you're router. I would turn on WPA or WPA2 security on the router, and put a password on it, then use whats called MAC address filtering so it only allows you internet access. Also disable WPS if you can because it can be hacked easily.
Nov 03, 2013 | Siemens Efficient Networks SpeedStream...
How can i configure siemens gigaset 504 agu for bsnl broadband connection
Connect the ISP modem to main uplink port. Then connect pc to any other port. Done!
Search siemens gigaset 504
They have very easy setup instructions
http://etisalatsupport.blogspot.com/2012/07/siemens-gigaset-504-router.html
Save file for next time.
http://www.etisalat.ae/eportal/en/images/docs/userguides/modem&drivers/Setup-ADSL-Siemens504AGU.pdf
Oct 25, 2012 | Computers & Internet
How to change password in gigaset 504 agu
How to change my Gigaset 504 Agu wirless password
Mar 13, 2012 | Siemens Efficient Networks SpeedStream...
I need to secure my gigaset 504 AGU, i put password on my router wifi but still i have a Enabled 50 clients,on my wireless network
you have put password for accessing your router( system config menu/router config menu) but not client WEP password, the router is still open access point( AP). configure a WEP key and then each/any of the client need to know this key/password to access internet via your router. good luck
Aug 14, 2011 | Computers & Internet
I have a siemens gigaset 504 AGU wirless router. I moved to a new apartment and changed my land line and internet company provider. Connected my router and wirless network was detected and connected...
Gigaset 504 AGU black color signal antenna . How to find (Host Name) and only showing there mac address ans ip address. i want see witch one using my net and we want fine friend computer name in my router .
Jul 01, 2011 | Siemens Efficient Networks SpeedStream...
Siemens Gigaset 504 AGU router password and email adfdress forgot. How can open this usb modem. before it was working in uae etisalat.than
You need to made it to default factory reset by pressing a few seconds on the reset button in the bottom of the devices. When it restarts it will be looks as new and you should re configure the isp settings of your internet connection. That's all. Before you make reset, don't forget to save the configuration to your computer for the future. Because if it is not working when you made the reconfiguration, you can also install the configuration from this configuration file.
Apr 16, 2011 | Computers & Internet
Wireless LAN not active
loptop not connect to router as wireless
Oct 11, 2009 | Siemens Efficient Networks SpeedStream...
Brookstone Siemens Gigaset Euroset 5040 Corded Phone with Proximity Sensor Logo
Top Brookstone Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Brookstone Lands Phone Expert? Answer questions, earn points and help others
