Question about 3Com OfficeConnect 802.11g/b Wireless Access Point
Keeps rebooting, never start
My 3crgpoe10075, never start, keeps rebooting again and again. I connect by serial cable to console port, I can see it reboting and these problem show: after: AP software 4.0.0.140 ---panic: trapmon detected a fatal error.
  • 2 more comments
  • Anonymous Dec 03, 2007
    I have had this problem with four of these devices and it's because of a fault in the firmware that makes them go into a re-booting loop. The problem was supposed to fixed in a later firmware upgrade but how are you supposed to upgrade the firmware when you can't even boot the device and log into it?
  • meandi123 Oct 16, 2008
    Hi
    I have the same problem too
    I cannot connect to the device via the ethernet.
    The status led is flashing red while the device is trying to boot (i guess)
    but then it looses the LAN connection (the LAN led goes off) and the
    procedure repeats itself again and again.
  • Ramez May 11, 2013
    Change board data: [Boot]: S name: Atheros AR5312 default magic: 35333131 cksum: 11a1 rev: 4 major: 1 minor: 0 pciid: 0013 wlan0: no 00:03:7f:fe:00:00 wlan1: yes 00:03:7f:fe:00:02 enet0: yes 00:03:7f:fe:00:01 enet1: yes 00:03:7f:fe:00:03 uart0: yes sysled: yes, gpio 7 factory: yes, gpio 0 serclk: internal cpufreq: calculated 180000000 Hz sysfreq: calculated 45000000 Hz memcap: disabled watchdg: enabled
    wlan0 disable, wlan1 enable,wlan1 2G enabled,enet0 enabled
I have the same problem. You have solved ?
Posted on Oct 19, 2008
SOURCE:
Lost web interface otherwise system is working
This does happen occasionally but is not a typical thing. This means that you have either lost network access to the system or a service on the system has stopped. The system will have to be rebooted to get things going normally again. The preferred method (since you can do it through netset) is to connect to the console port with a DB9 straight through serial cable and open hyperterm or putty and connect to it at 9800, 8, 1 none settings. Hit ctrl r and the system will reboot. if you don't have a serial cable then you are forced to pull the power or switch it off and then back on. CAUTION: you risk a database corruption every time the system loses power without closing the database properly (netset or ctrl r through the console) so do this as a last resort. Also, the system will do a disk scan (except V3001) and will take 15 to 45 minutes to complete before the system will start to function again. DO NOT UNPLUG IT AGAIN WHILE IT IS DOING A DISK SCAN! You can tell if it is doing the scan by looking at the S1 and S2 lights on the Call Processor. During a disk scan, they will be alternating back and forth (like police lights). Wait for it to complete and try netset again. I recommend doing a fresh reboot through netset after it comes back up just to be sure it's a fresh clean boot.
Jan 10, 2014 | 3Com NBX V3000 IP Phone
When i open the webcam got error or not connected how to connect
The webcam you want to connect should have a cable attached to it. One end is connected to the cam and the other end is to be inserted in the USB port.
Plug in the cam cable in the USB port of your computer and wait....
Note:Now, Keep your driver software ready. You will get it in the CD provided by the manufacturer of the cam at the time of purchase.
Now a window will appear stating "Found New hardware wizzard"
Click on NEXT....then select the NEXT again...here it will search for the driver in your CD and install the same.
Now Reboot the system and start using Webcam
May 20, 2011 | Computers & Internet
Need driver for CISCO DB9 TO RJ45 6FT CABLE 72-3383-0 for my notebook
If I am understanding correctly, you are using a serial to ethernet cable. The serial cable plugs into your laptop and the ethernet end plugs into the CONSOLE port on the Cisco.
From here you use a terminal emulation program like "Hyperterminal" to connect via the serial port. As long as your serial port is installed, no other drivers are necessary.
May 02, 2011 | Cisco Compatible DB9 to RJ45 Console...
Which cable can i use to configure switch HP J4900B
The switch comes with a console cable which will be connected to the console/mgmt port one end and the serial port of the Laptop at the other end.
If you dont have a console cable then you can try a rollover cable.
Oct 27, 2010 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
How do I reset the Privilege password on a 2600? The former IT Manager left without telling us what it is, and now we're screwed.
you need a reboot and a serial console I'm afraid. Lots of places on Cisco that detail the password recovery process, it's quite complex so I'm not going to go into detail, but you need to be physically in the same room connected with a serial console cable (9600 baud) for it to work. Basically, use break to interrupt the startup, change the config register to ignore startup config, reboot , go to enable mode, copy run start, enter config mode and reset the password.
Mar 26, 2010 | Paradyne BitStorm 2600 (2611-a1-430)
How to reset to factory default a Cisco Aironet 340 (AIR-BRI342)
  1. Use a straight-through cable with 9-pin male to 9-pin female connectors to connect the COM 1 or COM 2 port on your computer to the RS232 port on the bridge or AP. You can select the Reset option only through the console port.
  2. Open a terminal-emulation program on your computer.
    Note: These instructions describe HyperTeminal; other programs are similar.
  3. In the Connection Description window, enter a name and select an icon for the connection and click OK.
  4. In the Connect To window, select the port to which the cable is connected and click OK.
    1. In the Port Settings window, enter the following settings:
    2. 9600 baud
    • 8 data bits
    • No parity
    • 1 stop bit, and
    • Xon/Xoff flow control
    1. Click OK and press Enter.
    2. When the Main Menu screen appears, reboot the bridge or AP by turning the unit off and then turning it back on.
    3. When the bridge or AP reboots and the Main Menu screen reappears, typ
    4. Use a straight-through cable with 9-pin male to 9-pin female connectors to connect the COM 1 or COM 2 port on your computer to the RS232 port on the bridge or AP. You can select the Reset option only through the console port.
    5. Open a terminal-emulation program on your computer.
    6. In the Connection Description window, enter a name and select an icon for the connection and click OK.
    7. In the Connect To window, select the port to which the cable is connected and click OK.
    8. In the Port Settings window, enter the following settings:
      • 9600 baud
      • 8 data bits
      • No parity
      • 1 stop bit, and
    9. Click OK and press Enter.
    10. When the Main Menu screen appears, reboot the bridge or AP by turning the unit off and then turning it back on.
    11. When the bridge or AP reboots and the Main Menu screen reappears, type 2 to select Reset and press Enter.
    12. Type yes and press Enter to confirm the command.
      Note: The Reset command is valid for only two minutes immediately after the bridge or AP reboots. If you do not enter and confirm the Reset command during that two minutes, reboot the bridge or AP again.
    13. After the bridge or AP reboots, reconfigure it by using the terminal emulator or an Internet browser.e 2 to select Reset and press Enter.
    14. Type yes and press Enter to confirm the command.
    15. After the bridge or AP reboots, reconfigure it by using the terminal emulator or an Internet browser.
    Apr 17, 2009 | Aironet BR500
    Xbox 360 hard drive
    you have a networking problem or your cable is bad check all your cables if your cables may look good but if a pinched wire has occured you will get a cut off connection like that if not you will have to redo all of your networking settings if you call 1-800-4myxbox they can help you have your gamer tag ready and your serial number from the back of your xbox or in front at the usb ports
    Sep 18, 2008 | Microsoft Xbox 360 Console
    Psp
    press "Home + Select" to power off. And press "Home + Start" to reboot
    Jul 14, 2007 | Sony PlayStation Portable (PSP) Console
    3Com OfficeConnect 802.11g/b Wireless Access Point Logo
    307 people viewed this question
    Top 3Com Computers & Internet Experts
    john smith
    didi2005
    Håkan Sterner
    Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
