Question about Radio Communications
Icom ich16t CAN YOU PLEASE ASSIT ME WITH THE FREQUENCY PROGRAMMING BOOKLET OR INSTRUCTIONS REGARDING FREQUENY PROGRAMMING ON MY ICOM - IC-H16T HANDHELD RADIOS PLEASE. I WILL REALLY APPRECIATE IT IF YOU CAN ASSIST ME. I HAVE MISPLACED MY BOOKLET WHILE MOVING HOUSE AND I AM HAVING PROBLEMS CHANGING THE FREQUENCY TO SUIT THE NEW LOCATION WHERE I NOW RESIDE. KIND REGARDS. GARY SAUNDERS
Benimur
  • 6966 Answers
SOURCE: OLDER ICOM RADIO ICBP5 AND A REGENCY U156B
Hi, The Icom radio models start with IC followed by numbers and then letter(s). The BP5 is the model of the battery pack. Pls post back. I'm not familiar with Regency U156B. However, there is a Regency RU156 which is a 16 channel UHF 25watt mobile radio which could either be crystal controlled or PLL diode matrix. Regency was reported sold to the BK Relm Company, which no longer supports older Regency Radio Equipment. There are a few sites on the Internet where you can get hold of a user's manual (some for a fee) like http://www.bearcat1.com/manuals.htm. Hope this be of some help/idea. Post back how thin gs turned up, the Icom model or should you need additional information. Good luck and kind regards.
Posted on Oct 03, 2007
SOURCE: icom IC-F1020 and icom ic-f3
cqham.ru
Posted on Apr 13, 2008
  • 14 Answers
SOURCE: motorola gp 68
Batlabs at http://www.batlabs.com/2way.html (Hand Held Radios) has the GP-68 users guide(Operation Guide), on the right side I think what you might be asking is in "Basic Operation 2", if not look into the Programming section below it.
Posted on Oct 30, 2008
  • 17 Answers
SOURCE: Programming an Icom IC R5 scanner
This is a problem with any scanner which has no keypad..
First set the squelch (gets rid of the hissing noise and allows the radio to scan)
to do this....
On the side are 2 buttons, the bottom one is monitor.
press and hold then look at the display,
turn the top dial until "AUTO" appears,
The squelch should now keep the radio quiet.
Now the tuning step..
You need to set this because if your radio was on 450.000 and you wanted to listen to 450.012.5 you would miss it if your radio was making 000.025 "steps". IE you would need 12.5 steps. This is the most common step used by ambulance etc in the UK, you will need to check local band plans.
Stick with 12.5 and you should get most stuff on VHF / UHF.
For airband 12.5 will get most stuff, but some is now changing to 8.33.
For HF (below) 136 Mhz I'd use 5
To set the step....
On the front there are 4 big buttons.
press [V/M.S.MW.SKIP] to select VFO mode,
then press [BAND.LOCK] to select the band you want to listen to,
then press [TS.SET] to enter the step
turn the dial to select your step (stick with 12.5 for now)
press [TS.SET] to exit back to VFO mode
To scan...
First set the scan type...
Press and hold the one that says [MODE.SCAN] for 2 seconds and look at the display,
turn the top dial until the screen reads ALL,
press [MODE.SCAN] again and the radio should start to scan with the 12.5 steps you set earlier.
If you want to change scan direction, just turn the top dial.
If you want to stop the scan, just press [MODE.SCAN].
When you hear something interesting, make a note of the frequency on the display.
To set memories (store frequencies).....
to get close to the frequency you made a note of, press [BAND.LOCK]
Then set the actual frequency with the top dial,
press and hold [V/M.S.MW.SKIP] for 2 seconds to select memory write mode (1 short and 1 long beep)
turn the top dial to select which channel you would like to overwrite. Start with 01.
press [V/M.S.MW.SKIP] for 2 seconds. ( 3 beeps )
Thats it!
Any more problems just post on here and either me or someone else will help.
M3ODQ
Posted on Feb 02, 2009
SOURCE: ICOM IC-A6 Feedback type interference
The problem is caused by the microphone preamp in the headset demodulating the AM transmission. Sordin MSA headsets also have the same problem. What you require is a headset with no electronics in it and a dynamic microphone.
Posted on Jul 01, 2009
Icom programming
I looked up ICOM 2710 on the icomamerica.com web site and found ICOM IC-2710H which is a ham radio transceiver.
Jul 14, 2014 | Radio Communications
Can you change the squelch setting on an ICOM F61V
The squelch setting can only be changed with dealer programming software. A Manual for this radio is available from http://www.icom.co.jp/world/support/download/manual/pdf/IC-F51V_F61V_3.pdf
Jul 06, 2014 | Icom IC-F61V UHF PMR Handheld Transceiver...
Can I us a cp100 with an icom
Yes. Both must be programmed to the same frequency and DPL code ( if digital) or TPL code ( if analog).
Mar 26, 2012 | ICOM Informatique Icom Radio IC-F3, IC-F4,...
How to add frequencies/channels to ICOM IC-F21 two-way radios?
Sorry, but your radio is limited to 16 channels in the 400-430 and 440-470 MHz ranges. The number of channels cannot be expanded, nor can the frequency coverage.
Bill B
Mar 28, 2010 | ICOM Informatique Icom IC-F21 16ch UHF...
I need the IC-F11/S to talk to my CP100 (vhf) model
Programming the CP100:
http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
Programming the IC-F11:
I believe one must purchase software and a programming cable to program the frequencies of this radio.
Mar 13, 2009 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
IC A23 Portable VHF radio Locked
ic a 23 quero scannear como fazer /???
please scam mode /???
Mar 04, 2009 | ICOM Informatique IC-A23 VHF NAV/COM Air...
Miland 70-154
http://www.scribd.com/doc/11188457/MIdland-70154254-Icom-ICUV16-programming
http://www.retrevo.com/s/ICOM-IC-2GXET-review-manual/id/559bh834/t/1-2/
Jan 25, 2009 | Midland Radio 70-154 Compatible Battery
Radio Communications Logo
439 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
