Question about Hoisting
What is OSHA and why do they need to inspect my wire hoist every year?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 10 Answers
OSHA is the United states department of labor Occupational safety and health administration. They have to inspect your wire hoist every year to make sure that you and your employees are safe when they are using the wire hoists in your facility.
Posted on Nov 21, 2013
Leaking oil severely from the front side of the engine don't think it's front mean what else could it be
You don''t even bother to indicate what year and model of vehicle you have and which engine is fitted.
Get the car up on a lift/hoist and do a proper inspection and you should be able to locate the source of the oil leak if you cannot identify the leak from a top side inspection in the engine bay. There are numerous possibilities for a severe leak depending on the engine fitted.
Apr 11, 2016 | Cars & Trucks
Are wire hoists as strong as chain hoists?
Wire hoists are as strong and in some cases can be stronger even than chain hoists being able to lift between 1/2 up to 80 tons.
Nov 21, 2013 | Hoisting
Where can I find instruction for installing a wire hoist?
I found this set of instructions to be very detailed and helpful when I had to set up my wire hoist. Good luck and stay safe!
http://voices.yahoo.com/how-install-wire-rope-hoist-7673214.html?cat=6
Do I need a permit to rent or put up a buck hoist?
Needing a permit to build a buck hoist depends on where you are building it. Only a few states in the US require you to get a permit and the elevator to be inspected. Indiana, Michigan, Arkansas, Washington, Nevada, North Carolina, California all require you to get a permit.
Nov 17, 2013 | Hoisting
What is the OSHA?
OSHA stands for Occupational Safety and Health Administration. OSHA is the main federal agency charged with the enforcement of safety and health legislation.
Feb 06, 2013 | Miscellaneous
What are the advantages of a wire hoist over a chain hoist?
chain hoists are heavier, and are more susceptible to rust, although wire hoists can also rust
Jan 16, 2013 | Hoisting
What maintenance is necessary for my wire hoist?
I would recommend lubricating the entire system every couple months. Also OSHA has to inspect it every year
No problem with unit. Is this air conditioner CSA or OSHA approved ?
It's not the unit that you have to worry about for CSA or OSHA. It's how you intend to install it. You have to use the proper installation guidelines as approved by OSHA. I do know that going outside a wall or window you must have the proper bracket/frame installed outside the exterior wall to prevent it from falling on someone's head if high enough. If down low, they still have to be braced/bracketed properly to avoid injury. That's standard procedure.
http://www.osha.gov/SLTC/indoorairquality/
You need to find out what OSHA has for safety guidelines and restrictions. Also check with your local building code office to check with their pre-set guidelines. They have to be automatically in compliance with OSHA if they intend to operate guidelines for business purposes. So Call either- or both. It's not the unit you need to worry about unless it's very old. Good Luck.
Mar 10, 2011 | Maytag M3X05F2D Air Conditioner
Can't get spare tire hoist to tighten under truck
Hoist assembly needs to taken down and inspected for kinked cable and lubricated. If cable is kinked or frayed, entire assembly needs to be replaced.
Jun 19, 2010 | 2004 Chevrolet TrailBlazer
How to wire
use a wireless controller it will be cheaper and easer http://www.telecrane.com/
the three wires are
x1 constant power
up
down
x1 is connected to the up or down wire to activate the hoist in the desired direction
Mar 16, 2009 | Jet Equipment Chain Hoist 1TON 10 Ft Lift...
Hoisting Logo
958 people viewed this question
Top Hoisting Experts
Jerry Kramer
Jerry Kramer
FIREFOX ENGINEERING
Are you a Hoisting Expert? Answer questions, earn points and help others
