Question about Spirit Exercise & Fitness
Technogym run 900 TV treadmill
After turning on the machine the display shows a message: "Reset in process" during about one minute after that a message says that we need to activate one button and when it's done a red message appears saying that the Treadmill is blocked and we need to contact Technogym service.
SOURCE: york t500 treadmill model no:LQ6010 showing err07 when turned on
Error 7 is a Safety Key Error..
that's the red magnetic circular thingy on the console.
Simply secure the safety key in place and try it again
Posted on Apr 20, 2009
  • 3 Answers
SOURCE: I have a Nordic Track treadmill C1800. When first
You have 1,2 or maybe 3 problems. 1st is you need to remove the cover over the motor. The belt that the motor turns may be slipping. You need to loosen the bolt that keeps the tension on the drive belt. Push down to tighten manually and then tighten bolt. While your in there you should check the drive belt for wear. If you have used the treadmill a lot it may need replacement. $20 from readmilldocter.com The walking belt if badly worn can be replaced for like $99 but probably is fine. put all back together and tighten tension. Should be able to lift walking belt 3 to 4 inches from center sides. Any less and its too tight. Its probably better to just replace the drive belt anyway. This should work. Do not over tighten ever. This is the cause of most problems.
Posted on Feb 20, 2010
maxtreadmill
  • 832 Answers
SOURCE: i want to buy a technogym treadmill and i would
Press 369 simultaneously the enter the password 2501 which will get you in the service menu than pres 1 go to operating data and you will see then go to tot km press enter and you will see info needed
Posted on Apr 12, 2010
  • 19 Answers
SOURCE: my freespirit treadmill showsL5 on nthe display then quits
If calibration doesn't work replace controller.
Posted on May 14, 2010
SOURCE: I need to take my Technogym treadmill apart to
Run XT 600 Pro
Please explain elevation problem (-0.5)
Posted on Feb 11, 2011
How to increase the time to 60 minutes for the technogym run 600 xtpro
If you wish to get some details about treadmill; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 20, 2016 | True Technogym Excite Run 700 Treadmill
Technogym run 700 shows RESETING.... No other function. How do i solve this problem.
Can be a number of issues.
Do you get an error or message after a bit?
Most common I have found is the emergency stop switch is broken. Remove the cap and make sure all the connections are still on. Guessing not.
Next most common would be the limit switch is not resetting. Make sure that it is depressed. You can even try holding it, and having someone turn the treadmill on. Don't let go until it resets, or tries for about 15 seconds.
If that's not the case, make sure the limit switch is still connected. That's the cable under the motor controller that is connected to the bottom shroud.
If it's none of that, then I'd lean towards it being the motor controller itself.
Jul 03, 2014 | True Technogym Excite Run 700 Treadmill
Technogym no power to display
Assuming all the cables are ok, your display is probably dead and needs repaired. But more often than not the inverter is the problem.
If you have a way to swap it with another Technogym inverter I would try that first.
Jun 13, 2014 | True Technogym Excite Run 700 Treadmill
Technogym Runrace displaying belt movement halted message
I've got the same problem mate - technogym say you need to have an engineer to call round but it will be expensive...
Feb 01, 2014 | Technogym Deck, 52"
Treadmill display problem
The equipment is blocked... (2) this is the message I get in my Run excite 700 technogym treadmill.
Can some one help.
Thanks a lot
Jan 08, 2014 | True Technogym Excite Run 700 Treadmill
Technogym I am getting message "Your Technogym is blocked" Could you tell me what I need to do to remove this?
follow this steps and fix it. God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 17, 2013 | Exercise & Fitness
We have two commercial treadmills of your company with following details: 1- Technogym Run Exc 700 (Serial # D447ELNAL0000UKS) 2- Technogym Run Exc 900 (Serial # D4492LNAL0000USS) Now problem...
Might be the top panel monitor is faulty Also check that the treadmills are set into km not miles can effect the volt of treadmill and cause errors on treadmill Tip go on to techno gym site and look for display reset something like that and give that a try
Oct 08, 2013 | Exercise & Fitness
Technogym Run Excite 700 Schematics
Dear John
Please find here in attachment the schematics for the lower kit/board for the Technogym Run Excite Treadmills.
We would be very happy to help you. So, can you please tell us where do you come from? We will put you in contact with our local customer care.
Thanks
Technogym Staff
Apr 13, 2013 | True Technogym Excite Run 700 Treadmill
Change language on technogym treadmil
go to the MENU and proceed with the instr. manual for to change the language.OR download the owner manual free.
go to www.fitness.manualsonline.com
God bless you
Dec 06, 2012 | True Technogym Excite Run 700 Treadmill
Exercise & Fitness Logo
46 people viewed this question
Top Spirit Exercise & Fitness Experts
MrJunk
Level 1 Expert
Electro Med Services...
Mister G
Mister G
Level 1 Expert
Are you a Spirit Exercise and Fitnes Expert? Answer questions, earn points and help others
