Question about Apple Computers & Internet
Unlock volume when I put my earphones i can here but once i remove them the sound is locked I just can't even decrease or increase the volume
  • 9 Answers
SOURCE: can't increase & decrease the volume
Double check your connections. Still not working fine. Remove the input jack connector and try to touch or hold the tip of the connector, also adjust the volume of the speaker, you should heard loudly the 60 hertz sound of your body signal. Otherwise you have a defective amplifier in the speaker system.
Posted on Aug 25, 2007
SOURCE: Volume and menu does not display
I had this problem on my Aquos (LC-46D62U). It was NOT a hardware problem. I recommend turning off the television. Next unplug the television for 5 to 10 seconds. This resets something for the television. Plug it back in and turn on the television. You should now be able to get your volume and other on-screen displays.
Posted on Feb 18, 2008
SOURCE: popping & hardly any volume
i had the first problem and you can probably fix it by turning the volume knob all the way up and down about 20 times. it worked for me. supposedly the potentiometers in the z-5300 get dirty or worn out, somehow this might fix it. for the second problem maybe try plugging it into the laptop and unplugging it again seeing if it goes back to normal?maybe its a problem with the amp?
Posted on Aug 14, 2008
SOURCE: Volume Control on my SCBT100 Blu-ray Home Theatre doesn't work.
Unplug the power and let it sit. Plug it back in and it should fix. Worked for me.
Posted on Mar 22, 2009
SOURCE: I cannot adjust the sound volume from the right of the monitor
Thank you for your assostamce, but I simply downloaded the User Manuel?
Posted on Jun 02, 2009
MacBook Pro mid 2011 AUX input dose not work with my headphones.. please help me.. :(
Its very rare a mac has sound problems. Some earphones consume batteries, does yours have batteries in it? and is it powered on while connecting? With the earphones connected, check system volume and increase the sound while playing music. If there is sound coming from the mac itself then there maybe an issue with the AUX connection. Possible dust blocking the port. Clean it and try again. If there is no sound coming from the mac itself while the earphones are connected, then the AUX port is connected to the earphones and is in good working condition. Increase the volume on both devices, the mac and the earphones, if it has this feature. If there is still no sound, there may be a problem with the earphones itself. Possibly bad wires already, connect the earphones to other devices and listen for sound. If still no sound, replace earphones.
Oct 17, 2013 | Apple MacBook Pro MB991LL/A 13.3-Inch...
I am having problems adjusting volume
What type of laptop HP , ASUS , COMPAQ , ACER ?..........
Up the Volume on My HP Laptop
Open the "Start" menu and click on the "Control Panel" icon.
Locate and open the icon that deals with sound.
Depending on your version of Windows, it will say either "Sounds and Audio Devices" or "Adjust System Volume."
Adjust the volume under the "Speakers" icon.
To do this, click on the slider bar and move it up on the slider.
If you need to decrease the volume, simply move the slider bar down.
Click on "OK" when finished and close the "Control Panel" window.
Click on the speaker icon in the bottom-right corner of the screen for a faster volume adjustment. Simply move the slider bar up to increase the volume and move it back down to decrease the volume.
Volume on an Acer Laptop
Acer laptops are typically sold with pre-installed Windows operating systems that offer sound-adjustment features for increasing the volume on the laptop's built-in stereo speakers.
These same functions can also be used in tandem with external speakers or headphones to increase the volume, as well as mute all sound on the laptop.
If the computer should output an unusually low volume, fixing the problem may be no more involved than sliding a control switch with the computer mouse. Click once on the speaker icon in the taskbar on the lower-right corner to open a rectangular window with a slide control.
Click and hold the left mouse button on the slide control to drag it upward, increasing the volume to the laptop's maximum setting.
Click the "Mixer" button below the slider control to open another window with volume controls for "Speakers" and "Applications," adjusting each slide control upward to increase the volume.
Be sure the speaker icon below each control is not accidentally muted.
Click once on each speaker icon to remove the red circle with a slash through it, which will restore audio.
Click the Microsoft flag or "Start" button in the lower-left corner if the shortcut speaker icon is missing from the taskbar.
Click "Control Panel" to select "Adjust Sounds" from the Hardware and Sounds category.
Aug 10, 2013 | Computers & Internet
Keyboard sound buttons not working
Are you pressing the fn key at the same time? These are FunctioN buttons and work in conjunction with the fn key.
Feb 02, 2013 | Apple MacBook Air
In my nokia n900 cell, i have a issue in earphone.its earphone is not working properly as i can`t getting sound more ,as i m putting full volume so i dint understand that is the issue with earphone or with...
Dear, in your mobile just play an audio without your ear phone, then increase or decrease its volume if it get increased or decrease then their is no problem in your mobile.
then again put your ear phone to your mobile, and trying doing the same thing, if it does not getting increase or decrease then surely their is a problem in your ear phone.
change your ear phone either from nokia care or some local mobile accessories store.
regards!
Jul 30, 2011 | Nokia N900 Smartphone
My Amplifier is in good working condition, except for the volume control has gone weird Using the remote, you can increase volume, but not decrease volume. On the unit, rotating the volume control...
Cleaning the contacts may help. The volume knob should pull off. Once its off use a non-flammable contact cleaning spray to clean the contacts behind the knob.
Electronics and automotive stores should have this.
May 16, 2011 | Onkyo TX-DS494 Receiver
Want to know how to lighten up the screen. need an instruction manual
These are the Function keys
<Fn> + <↑> Volume up Increases the sound volume.
<Fn> + <↓> Volume down Decreases the sound volume.
<Fn> + <→> Brightness up Increases the screen brightness.
<Fn> + <←> Brightness down Decreases the screen brightness.
Nov 09, 2010 | Acer Aspire 5100 Notebook
How do I increase the volume on my Nokia 1661?
There are 2 types of volume in your nokia phone that you can increase or decrease.
The first one is the ring tone volume. You can either increase or decrease your ring tone volume by pressing the menu key then go to settings, go to profile, select any desired profile go to personalise go to ringing volume, then increase or decrease by using the navigation button to the right or left.
The second way is to increase or decrease the volume of the speaker of your phone which i think is the cause of your question (this volume enables you to hear clear and loud the person on the other phone). You increase or decrease the volume by making a call, as soon as the call starts ringing, press the navigation key to right to increase the volume or to the left to decrease the volume.
Jan 19, 2010 | Nokia 1661 Cell Phone
Earphone volume is too low
kindly contact your network provider.may be it's related with network
Sep 22, 2009 | Cell Phones
Light-up volume bars on the hp pc notebook dv7 1132nr
Hi Folks....
If you are talking about the Quick Launch buttons of the Notebooks from where we usually increase, decrease or mute the Volume, the lights will be still and will not increase or decrease with the increase or decrease in Volume.
However, you do have a utility which should be preinstalled in Notebooks called HP Quick Touch which shows the bars on the Display when the volume is Increased or Decreased  using the Quick Launch buttons. This application is not compatible with Windows Vista 64 bit edition.
The HP Quick Touch application is available for download from the link below :
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38358.exe
Save the file in the Notebook and double click it once the download is completed to install the application.
Hope this helps....
Dec 20, 2008 | HP Pavilion dv4000 Notebook
Sound Level Changes Constantly
Make sure digital sound control is not set to optimal
Make sure incredible surround is off
Press optimal sound mix until it says "OSM Off"
Double-check the speaker connections
May 07, 2007 | Philips FWC399 CD Shelf System
Computers & Internet Logo
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
