Question about Sewing Machines
Babylock Ellisimo Gold machine sews for about 20 stitches and then stops. A screen comes up and says Check and rethread the top thread. And the cycle begins again.
When embroidering with a hoop, the machine will sew the first 20 or so stitches and then stop. (It stops in the same place each time it is sewn.) The prompt comes up on the screen asking you to check and rethread the top thread. And you begin again, and the same thing happens. I have rethreaded, blown out the cracks and crevices with canned air, rethreaded the bobbin, put in a new needle and nothing of that sort has helped.
  • krisann528
    krisann528 Mar 26, 2014
    Thread the machine with the presser foot UP until you get to #5 then put it down and finish threading. With the foot down, the tension disks are closed so the thread is not seated between them.
    New Friend:
    Problem Solver:
  • 5 Answers
Blame the bobin the case or the inner machine dont blame the stches
Posted on Nov 21, 2013
SOURCE: singer sewing machine model 6012 c
hi
i want to know how i put thread in the sewing machine
thank you
Posted on Aug 23, 2008
  • 3 Answers
SOURCE: Babylock Ellure thread issues
I have the same machine and love it. Sometimes if the thread is old that will happen to me.  And also I spray the thread with static guard before i thread the machine in dry cold weather.  Since you said you are an embroiderer I assume you are using the same weight thread top and bottom. The other thing that causes that on my machine is if there is a nick on the spool of thread I am using and the thread catches just a little as it comes off the spool.  I use a fine nail file and smooth off the edge where the little v is to reattach the thread when you are finish using it.  I never use them. You do sew a little and cut off the tail off the top thread before you let it go through the rest of design. I hope you have found the solution but I learned these tricks while having the same problem as you.
Posted on Mar 07, 2009
  • 14 Answers
SOURCE: on a babylock elegante the bobbin thread shows,
Have you reset the tensions for this machine, look in your manual and follow directions. If this is an Elegante there is also a set of instructions on the machine. On the LCD screen there is a picture of a sewing machine with a question mark, touch it, find Troubleshooting and touch that then find the problem you are having and read. If this does not help take it to a Brother dealer and have it reset so as to keep you machine in good running order.
Posted on Jul 07, 2009
miket756
  • 2702 Answers
SOURCE: NEEDLE WON'T PICK UP BOBBIN THREAD
im not!
it needs a good service the timeing has sliped out a little, nothing more that that,,,see its not a lost cause just yet
Posted on Oct 24, 2009
Testimonial: "Thanks! I was hoping to avoid paying for a fix, but it looks like I have to **** it up. So much for being thrifty and restyling my clothes."
Zenqi
  • 208 Answers
SOURCE: needle not picking up bottom thread
Remove the needle plate and the bobbin case.
Ensure that the needle is inserted all the way up into the needle clamp.
Set the machine for straight stitch, center needle position.
Slowly turn the handwheel in the normal sewing direction and observe the following hook timing setting:
When the needle reaches it's lowest point and travels up 3.5mm, the point of the hook should be directly behind the needle, or at least within 1 or 2mm.
Another view is as the hook passes the needle, it should pass the needle slightly above the eye of the needle.
If the timing looks good, use some alcohol on a bit of cloth to clean the hook, careful around the tip of the hook as it is very sharp.
If the hook timing is off, you will need to take it to a knowledgeable service person as there are several possible solutions and several other related adjustments which will need to be made.
Posted on Jan 16, 2010
I have a Babylock Diana. My stitches are looping, but they just build up into a nasty mess and the fabric does not feed under the foot. I have rethreaded and checked all my settings.
When you thread the top thread, ALWAYS RAISE the presser foot throughout the process. This allows the thread to seat fully in the tension disk. Then test your machine and tweak the tension.
Mar 07, 2018 | Sewing Machines
Bobbin thread is coming out on top stitch.
Check your tension. Rethreading the machine making sure the top thread is well between the disks. Then sample sew. If still present adjust the thread tension lower/looser.
Oct 10, 2014 | Sewing Machines
Babylock ellegante 2
Threads bits/dust has accumulated at top thread sensor or the sensor need to be replaced
Oct 30, 2013 | Baby Lock Ellure
The thread on my ellisimo gold keeps shredding
try changing the needle
and also check for burrs on the needle plate and in the bobbin
area
Jan 14, 2013 | Sewing Machines
Have been given an old frister rossmann 402 machine with no maual so i cant work out why it sews some stitches and becomes hooked up underneath by loopy threads
change the needle
rethread the top thread make sure the thread doesn't come off the thread take up lever
check the bobbin area for lint or loose threads
also rethread the bobbin in the bobbin case & reinsert it
also check the top thread tension try 3 or 4
Nov 04, 2010 | Sewing Machines
Serger stitch not forming right
It sounds like the timing needs to be reset by a sewing machine repair tech.
May 09, 2010 | Baby Lock Evolve
Stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
Dec 10, 2009 | Brother SE-270D Computerized Sewing...
Babylock sewing machine, upper thread is bunching
the tension is wronge has the lower bobbin case been unwound and refilled)(check that this is threaded right as well)
Sep 05, 2009 | Sewing Machines
Singer futura CE-100 4 blinking reds lights
This error indictaes that the upper thread is broken. If it is not the sensor is telling the computer the thread is broken. Try tightening the upper thread tension some and rethread the upper thread.
Dec 23, 2007 | Singer CE-100 Futura Computerized Sewing...
Sewing Machines Logo
297 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
