Indicators not working
WHEN YOU SWITCH TO LEFT, HAZARD LIGHTS COME ON AND NOT THE LEFT INDICATORS. RIGHT SIDE WORKING OK. WHAT TO DO?
    Champion:
  • 219 Answers
Check the flasher
Posted on Nov 27, 2013
2 Suggested Answers
T3KK
  • 171 Answers
SOURCE: Left side OK but right side has vertical lines
Fairly simple one this.
If all the cables are connected properly and the video card is sitting in its slot properly then either your video card or monitor has died,
Try a different monitor - if the same porblem exists then you know it is your card, if the problem does not exist on the new monitor then you know it is your monitor.
Although you may be lucky and just find that the card is not sitting in its slot properly, or a cable is loose. The card may even be overheating, if it is a newer card, make sure the fan is working on it.#
If this is helpful please vote kindly.
Posted on Oct 07, 2009
Alpha Romeo 156 My Left hand indicator light stays on continually, does not flash. and when I turn the hazard light switch on both indicators continually glow.
Generally speaking, symptoms of a bad or failing turn signal bulb are usually the culprit...in your case, either it's the front left or rear bulb. Varies for different vehicle makes...common signs include:
  1. turn signal light staying on solid
  2. or blinking very fast
  3. or either sides of the bulbs stop blinking altogether.
To test this, make sure you reconnect everything you disconnected.
Turn the left signal light on; go to the front of the vehicle, is the turn signal bulb illuminated? If it lights up, even though it is not blinking obviously the bulb is okay. If it doesn't, replace it- problem solved. You'll do the same procedure for the rear turn signal Is that lit up? If not replace the bulb and the problem is solved.
Another common failure is when the turn signal blinks really fast, same procedure as mentioned above.
If both bulbs for the left side and right side illuminate but don't blink, the problem is in the steering column turn signal switch.
If the left or right side blinkers don't work properly at all...then check the integrated hazard warning/turn signal flasher relay- that may be defective; again, that's usually the case if both sides of the signal light don't work.
If you are blowing any fuses related to the flasher system, you have an electrical overload in the turn signal circuitry.
Feb 12, 2017 | Cars & Trucks
Clio wiring diagram
one of the common probs is the hazard switch faulty it can stop one side or other working intermittant. when problem happens operate hazard switch a few times and check all 4 work ok. the bulb holders are also poor if its just the front change the relevant bulb holder the only other is the poss is one of the inline harness connectors under bonnet or fascia. good luck.
Sep 29, 2016 | 2005 Renault Clio 1.4
Pride Celebrity XL8 - problem with right side indicators
hi Stuart, have you check out the actually switch that you pressed to activate the indicators ?
Regards
Rob
Apr 18, 2016 | Pride Health & Beauty
When I turn on either left or right indicator both indicators light up
try pushing the hazard light switch again. what you have is the hazard lights in operation ( both sides indicators working) In normal indicator operation power from the flasher unit is directed to which ever side you select but by pressing the hazard light switch the indicator power lights up all lights.
Nov 13, 2014 | 1987 Citroen AX
I have an 02 kia sportage. my signal lights come on but dont blink outside. no lights for the signal lights come on on the dash at all. also, no hazard lights.
If the 15A HAZARD fuse in the passenger compartment fuse box is OK, power is getting to the hazard function of the flasher unit. Pressing the hzard switch should cause the hazard lights to flash. HOWEVER, there is an electronic time and warning indication system module connected to to the hazard switch lead and that may be affecting things. If the 10A TURN fuse is OK, power is applied to the turn switch (with the engine in START or RUN) and you state you can select a right or left turn. HOWEVER, the RED/WHT and RED/BLU outputs from the flasher unit connect directly to the front and rear turn lamps and the instrument cluster turn indicators so you are not getting any flasher output. Again, that electronic time & warning indication system module could be affecting things
Oct 26, 2012 | Cars & Trucks
Left turn signal lights are not working
In my case the left front turn indicator lamp worked, but not the left rear indicator, although all the lamps would turn on with running lights activated, as well as the backup light and 'night-light' mode. The left rear turn indicator would not work with the hazard lights activated. I tested the combination switch (this is the left/right turn indicator switch you use when driving to indicate which direction you are going and is mounted/located on the steering column) and it tested O.K.. I had good continuity from the combination switch black wire, and resistance on the blue-white wire from there to the left rear turn indicator lamp, as well as good continuity on all wires going out from the left parking light fuse. Since the Haynes manual indicated that the flasher module was probably good if it made the tell-tale clicking sound, I was feeling perplexed. So I took it into a local shop that specialized in auto electrics and it turned out to be the flasher module. I was under the impression that it operated in a straight-forward left-right manner, but apparently it has a different circuit for each turn indicator lamp. So even if it is making the appropriate clicking sound when the combo switch is flipped, it could still be the flasher module. Obviously the manual leaves a bit to be desired in the troubleshooting of malfunctioning turn indicators.
Sep 07, 2012 | 1998 Dodge Caravan
My right side turn signal cuircut works but my left side doesnt ive checked the light bulbs but they're all good.
if hazard lights are ok and you can see all are working, you can tell that your signal lever switch is broken.
Nov 18, 2011 | Cars & Trucks
I havea 1995 Ford Fiesta and the indictor lamps(front and rear) only work on the right hand side, if you try to indicator to turn left you just get a ticking from behind the instrument panel and neither...
Try the hazard lights to check if all four lights flash, if not then check the bulbs. If the bulbs are ok check the contacts and the connections. if all all these are ok the problem could be the indicator switch. The flasher unit is fitted in the circuit before the indicator switch, that is why it operated although the lights might not.
Jan 17, 2011 | Ford Fiesta Cars & Trucks
Indicators/flashers
Check your wiring for continuity. Mine did the same on the Fatboy - found a broken return wire by the right Handlebar switch when I opened up the switch gear housing on the bars. Bit of solder, heatshrink and good as new! (my problem light was on the right side so check the left side on your first - was a white wire with orange stripe I think, should be easily visible from the indicator switch inside). All the other lights worked fine. Maybe an earthing problem?
Oct 31, 2007 | Harley Davidson Harley-Davidson Motorcycle...
Open Questions:
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
