Question about BaByliss 7053U Beard Trimmer
Where can I find a new battery for the Babyliss 4120 0210 ADL
BaByliss 2082CU Pro 235 Hair Styler these won't seem to heat up enough on highest setting, brand new
Enter the serial number on the babyliss website to ensure you have a genuine hair styler, if genuine ask for your equipment to be swapped or repaired at there cost
Feb 23, 2015 | BaByliss Health & Beauty
I overcharged my babyliss grooming kit now it won't work
You will have to get new batteries. In Greece, there are specialist battery shops that supply or charge batteries for every possible use. One of these shops replaced my batteries for 8 euros and now my hair trimmer is as good as new again. The trimmer appears to take two common AA sized rechargeable batteries, so you should be able to change the batteries yourself.
Jul 01, 2014 | BaByliss 7053U Beard Trimmer
Need replacement foils for model 8667BU as mine is broken
hi my foil babyliss machine was broken how can iget new foil for model 5667bu
Jul 09, 2011 | BaByliss 8667BU
I have lost the charger for my Babyliss 7053u, where can I find a new one?
A new kit is fairly cheap: http://www.amazon.co.uk/BaByliss-Men-7053U-Over-Grooming/dp/B002FGTJ0O
I couldn't find just the charger anywhere... I would recommend just buying a new kit.
Apr 21, 2011 | BaByliss 7053U Beard Trimmer
I have a nokia 5130c there is problm camra on stand by please help me
Tools & Materials required  :
  1. Mxkey Dongle with latest software installed
  2. UFS / JAF Box
  3. Nokia 5130c Fbus cable
  4. CA-101 Usb data Cable
Step By Step :
  • Backup RPL & PM
  1. Open Mxkey Software
  2. Select UFS / JAF as Interface, then connect it.
  3. Pick Nokia Module
  4. Pick BB5 Tab
  5. Pick Service Tab
  6. Connect Phone to UFS / JAF box using Nokia 5130c Fbus Cable
  7. Click on " backup RPL "
  8. Save to safe location.
  9. Pick PM Tab, read full, save to safe location.
  • Flashing / Firmware Updating via CA-101 Usb data cable
  2. Select Nokia Usb Rom as Interface
  4. Pick BB5 Tab
  5. On flashng Tab, Pick Nokia 5130c Latest Firmware Package Properly.
  6. Click on " Flash " Tab
  7. Connect Phone to PC via CA-101 Usb data cable.
  8. Wait Until All Process done
Here's the log operations :
Reading phone`s ID ...
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
productData saved.
Restarting phone ...
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 24E0000D70D27D5657572DFFD11A84578F44242B
ASIC MODE ID: 00
 SecondaryBoot: rap3gv3_2nd.fg [BB5]  version: 9.11.1 revision: 0.0 size: 0x3C00
 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982  - 0000 8A31 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM]  version: 9.50.0 revision: 0.0 size: 0x23010
 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
TransmissionMode: DDR&TX2
Reading RAP NPC (0x168 bytes).
Reading RAP VARIANT (0x0 bytes).
Reading RAP CCC (0x160 bytes).
Reading RAP HWC (0xD4 bytes).
Flash Imei: 35422303116811
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
SUPERDONGLE_KEY_DATA saved OK
CMLA_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
RPL saved to "C:mobileEx.4dataackupRPLBB5_35xxxxxxxxx_BACK.rpl"
Library version: 1.0.0.8955(29-09-2010), 1.0.0.14639(29-09-2010)
Processing file: rm495__07.97.mcusw as MCU
 [BB5,BB5 ALGORITHM]  size: 18.20 MB
 Supported RAP Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable,Battery back to device.
Insert Charger or Press phone's power button
Waiting for USB device ...
[ADL] Pooling for ADL device
[ADL] Device found: nmwcdnsucNokia USB Flashing Generic, ID: 1FB998E3
RAP SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
RAP EM0 ID: 00000296
RAP EM1 ID: 00000B22
RAP PUBLIC ID: 24E0000D70D27D5657572DFFD11A84578F44242B
RAP ASIC MODE ID: 00
RAP ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
RAP ROM ID: 273F6D55DFAAF68F
[ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes
[ADL] Update Server code succesfully sent to phone.
[ADL] Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes
[ADL] Flashing CMT Update Server Data, PASUBTOC: 0x59940 bytes
[ADL] Device found: nmwcdnsucNokia BB5 ADL Loader USB Generic, ID: 8572D57
[ADL] Verifying communication to device OK.
Erase size: 21.00 MB
CMT NOR area [00000000-000006BF] erased in 0.500 s
CMT NOR area [000006C0-0001FFFF] erased in 0.515 s
CMT NOR area [00040000-000BFFFF] erased in 2.172 s
CMT NOR area [000C0000-0013FFFF] erased in 2.094 s
CMT NOR area [00140000-0137FFFF] erased in 1 min 17.812 s
CMT NOR area [01380000-0151FFFF] erased in 6.954 s
Flash programming ...
CMT PAPUBKEYS: 0C917F11196FDB7378C18EF7260698CA4489DCA0 (RAP Certificate 164 v.1) written.
Programming completed in 1 min 5.172 s
Processing file: rm495__07.97.ppm_x as PPM
 [BB5,BB5 ALGORITHM]  size: 7.72 MB
Erase size: 8.62 MB
CMT NOR area [01520000-01DBFFFF] erased in 37.188 s
Programming completed in 26.469 s
Processing file: rm495__07.97.image_x_red as CNT
 [BB5,BB5 ALGORITHM] page size: 128 K size: 12.89 MB
Erase size: 34.00 MB
CMT NOR area [01DC0000-0215FFFF] erased in 22.829 s
CMT NOR area [02160000-03FBFFFF] erased in 3 min 12.922 s
Programming completed in 45.125 s
[ADL] Restarting phone ...
[ADL] Device found: nmwcdcNokia 5130 XPressMusic USB Generic, ID: 1878DB02
Flashing completed in 9 min 5.000 s
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.97 13-09-10 RM-495 (c) Nokia
Imei plain: 3542xxxxxxxxxxx
Product Code: 0578115
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SUPERDONGLE_KEY seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 354xxxxxxxxxxx
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Total time to process is 9 min 8.922 s
Jan 24, 2011 | Nokia 5130 Cellular Phone
Need new battery for babyliss trimmer
Here you go: http://www.cellpacksolutions.com/rechargeable_shavers.asp
Jun 26, 2010 | Forfex BABYLISS Pro Clipper/Trimmer Combo...
Forfex blade reinstall
I have the Forfex babyliss 720 and I can't get new blades installed in it. I have tried 8 times and someone else has tried 5times. Do you have any instructions on this model.
Thanks
lchardt@embarqmail.com
Dec 16, 2009 | Forfex BABYLISS Pro Clipper/Trimmer Combo...
New battery installed in 05 Solara, passenger door does not unlock when car put in park. How do I fix this?
When the battery is disconnected, the ADL mode returns to the default setting (Mode A). The following procedure must be used to set the ADL function to Mode B whenever the battery has been disconnected.
Initialization Procedure
Perform the following procedure to initialize the ADL function to Mode B.
1. Move the shift lever into the "P" position and close all doors. 2. Turn the ignition switch to the "ON" position. 3. Within 10 seconds after the ignition switch is turned to the "ON" position, push and hold the rear side (unlock position) of the door lock switch for 5 seconds. 4. All doors will automatically lock and unlock when you release the power door lock switch. ^ This indicates that the ADL function is set to Mode B. If all doors do not lock and unlock, the time the switch was held may have been too short or too long. Perform the procedure over again starting from step 1.
Sep 11, 2009 | 2005 Toyota Camry Solara
My forfex clippers won't hold a charge
How old are the clippers? Babyliss have a one year warranty on all their electrical goods. It sounds as though you may need a new battery. Have you checked the charger itself to make sure it is working properly?
Jun 10, 2009 | Forfex BABYLISS Pro Clipper/Trimmer Combo...
BaByliss 7053U Beard Trimmer Logo
54 people viewed this question
Top BaByliss Health & Beauty Experts
NOEL
NOEL
ray gallant
Tom Chichester
Are you a BaByliss Health and Beauty Expert? Answer questions, earn points and help others
