Question about Magnavox DTV Digital to Analog Converter
I need to turn on my digital converter box
I can power up the box but the green light wont come on just a yellow one that says stand by
Converter box will not stay on - starts green light then switches to red
I have one of those right here attached to my computer so I can watch TV on the PC. The red-green light is the power indicator. Your converter is turning off for some reason. Possibly it is getting a signal from another remote, and turning off. You can block the converter's remote sensor with something (black tape works) and then change the channels with front panel buttons if it has them.
Mine has power buttons for both the TV and the converter, so watch out for that.
Apr 06, 2017 | Televison & Video
2004 Chrys Concorde, new utility trailer, tail light converter. Problem: There is output from conv box in yellow wire, when turn signal is on, but when it is connected to the trailer harness, no output...
Your vehicle CANNOT be wired for a trailer without using the converter box. The only vehicles that do not require a converter box are the vehicles that use the stop lamp bulb as a turn signal. Your vehicle is equipped with SEPARATE stop lamp and turn signal bulbs.
To make the converter box work correctly, it must be wired according to the instructions to BOTH the stop lamps AND the turn lamps. The tail (or PARK) lamps DO NOT go through the converter box.
Your trailer uses the SAME bulb for stop and turn - THIS is the reason you need a converter.
The wire color for both your LEFT TURN and your RIGHT TURN are LIGHT GREEN/TAN. Although the wire colors are the same at the bulb sockets, these are SEPARATE circuits and must be wired to the correct wire at the converter box. (LEFT and RIGHT) The converter box will have an INPUT connection for EACH of these.
The wire color for your STOP lamps is WHITE/TAN. The converter box should only have one INPUT wire that connects to this. It doesn't matter which side of the vehicle you connect this wire to. All of the stop lamps are on the same circuit.
The converter will then have only one wire for LEFT turn and stop (usually YELLOW) this is the wire that needs to go to your trailer connector for left turn and stop.
The RIGHT turn and stop will most likely be GREEN coming out of the converter.
Sep 05, 2011 | Chrysler Concorde Cars & Trucks
My converter box will not turn on. The light stays red. i plug it in and it lights red but it wont turn on it stays off and i use remote and i manually push the power button but it wont turn on!!
TRY
Unplug receiver.
Leave for 10mins.
Plug in again.
Wait another 10 mins.
Press the hand control stand by button.
In a few minutes the light should turn green and start options should appear.
Good luck. This works when my HD box freezes.
Feb 02, 2010 | Televison & Video
We unplugged out VCR, and now the converter box won't turn on. has power to it, but the little red light won't turn green.
plug your vcr back in, or undo co-ax cable from vcr and put antena wire to antena in on converter box and wire going to the back of tv to tv out on convrter box
Nov 26, 2009 | Insignia Digital-to-Analog Converter for...
Drive stopped working
I had the same problem - green light on power cord but when plugged in the green light would go off and the hard drive would do nothing. I took it into Geek Squad finally and it turned out that the problem was hard drive casing, which I had to have replaced.
Jun 07, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
Tv wont turn on
If your AVC works and would like to sell I will buy this unit
Jun 03, 2009 | Hitachi 42HDT51 42 in. Plasma SLC1551AW
Yellow power light will not turn green
It sounds like U have a bad box. This seems to be the most common problem with them, besides not picking up all the channels.
May 01, 2009 | Televison & Video
Unable to properly connect sony dvd to tv to play movie
DVD-3 RCA phono outputs(red & white=audio,yellow=video
I have a DVP-NS700,the same happens on mine.Turn it on,goes green to red(standby),then press eject,it will then power up properly.
Jan 03, 2009 | Sony DVP-NS300 DVD Player
Trailer wiring
you have to purchase a converter box with 5 wires, red, yellow, green and brown. this is because your turn signal is seperate from you parking and brake light bulb. you have to wire it straight in behind the connector.your basically converting two wires ( brakes and parking) to one wire (tailights) 5 wire to 4 wire.
Jul 12, 2008 | 2004 Ford Escape
CANON PIXMA IP1200 resetting
My converted iP1200 is currently blinking green, yellow, green, yellow on the power lights after start up and print request. The pop-up prompt suggests turning off the printer and turning it back on. Error 5100 is always seen.
Please Help Me...
rakibfuture
Mar 30, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Magnavox DTV Digital to Analog Converter Logo
Top Magnavox Televison & Video Experts
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
