Question about Leica Sprinter 150m Electronic Construction Level Packge
No driver for leica sprinter 150M - Leica Sprinter 150m Electronic Construction Level Packge
POTHWFLANAD1
You should describe your problem with a little more detail!
If you search on the web, you find some posts, that they do not have drivers and that this device does not work on WinXP, Vista or 7 without drivers. It is said that it works on LINUX. So what do you use? Do you have drivers installed for it?
What do you mean by 150m in your question. A ethernet-network may noot be longer than 90m + 6m +4m from device to device. If you need to brifge 150m you need a repeater or, even better, use a fiber-connection.
Mar 22, 2014 | Eforcity (PUSBLANXAD01) USB Network...
I have a Leica Digilux, but could not fine it anywhere on tghe dealer spots. I need a memory card for it and its difficult to get locally. The size is larger than the regular cameras.
Amazon could be a help:
http://www.amazon.com/MEMORY-Leica-DIGILUX-Digital-Camera/dp/B000Y06WXA
It may depend on what your exact camera model is. You have only stated Leica Digilux.
There is the Leica Digilux 1, Leica Digilux 2, Leica Digilux 3, Leica Digilux 4, and the Leica Digilux 5. Most seem to take the SD HC (the SD card may work as well) card:
http://www.google.com/search?q=Leica+Digilux+memory+card&hl=en&prmd=ivns&source=univ&tbm=shop&tbo=u&sa=X&ei=FjQaTtGBMoKusAKnxLzCBw&ved=0CDsQrQQ
If your camera is a Leica Digilux 1, then the cards it can take are: Secure Digital Card and Multi Media Card
http://en.wikipedia.org/wiki/Leica_Digilux_1
If you have an earlier camera, then it could take some other kind such as the Compact Flash Card, although I did not find such a note anywhere.
Jul 10, 2011 | Leica Cameras
IBall Baton 150M Wireless-N Router driver
iBall Baton 150M Wireless-N Router or any routers do not need drivers to work on your PC. Just the configurations settings provided by your ISP account.
Only Wireless adapters ie PCI or USB interface needs drivers for the device to work on your PC.
Here is a link pdf help file to help you configure your router to work on your PC/Laptop.
Hope it helps.
Dec 05, 2010 | Computers & Internet
Hoover ultracare hc6 150m. Changed drum bearings today .but pulled of spade terminals to power switch .Established live and nuetral feed to switch ,but unable to establish switching pair polarity..Wires...
Now THIS is strange! I hunted HOOVER and got this:
"Your search for "hoover ultracare hc6" resulted in no products."
and
"Your search for "hoover ultracare hc6 150m" resulted in no products."?
Even a GOOGLE SEARCH had no real hits for:
hoover ultracare hc6 replacement parts
...had ZERO results... well actually there were some hits but no actual "part sellers" and the DO want to make money!
Dec 06, 2017 | Hoover UltraCare HC6 150M Front Load...
Can't find instruction manual
Hello
At the link beow you will be able to download the manual for the requested manual.
http://www.retrevo.com/support/Leica-D-Lux-3-Digital-Cameras-manual/id/522dj983/t/2/
Kind regards
Andrea
Jan 24, 2010 | Leica D-lux 3 Digital Camera
Driver
This person may be able to help you find the driver--
http://www.thesurveyorexchange.com/index.php?a=2&b=126
There is a phone number listed--
Apr 17, 2009 | Leica Optics
Leica Sprinter 150m Electronic Construction Level Packge Logo
332 people viewed this question
Top Leica Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Leica Measuring Tool and Sensor Expert? Answer questions, earn points and help others
