Question about Samsung ML-2855ND Laser Printer
Main Firmware - Samsung ML-2855ND Laser Printer
I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
your machines NVRAM is bad, did you have the main board replaced ? You are going to need a technician to repair this as the either the machine firmware is corrupt or the NVRAM module need to be replaced along with the main board $$$$$$$$$$$$$$$$$$$$ you can not reset!!!!! the NVRAM module and or main board work together, or the firmware is corrupt not the print drivers but the machine operating system which (firmware) is on a secure server with access to only KonicaMinolta dealership technicians. Konica Minolta wants to protect its copier and printer operating systems.
Mar 26, 2017 | Minolta Office Equipment & Supplies
Tip
What is firmware version and How to check your firmware version?
A "Firmware" is the phone's operating system stored in internal Flash memory of the device (disk Z.
Manufacturers release new firmware versions containing bug fixes, improvements and - sometimes - offering new functions.
Firmware upgrade can only be made in authorized Nokia service centre (point).
To check your current firmware version simply type *#0000# on main Phone screen.
on May 25, 2010 | Cell Phones
What does "Firmware Rev B 13" n on indoor control panel? Help! Robert
The firmware message is the firmware on the wall mount control. The wall control would seem to be getting power, giving you the firmware rev only. Your communication with the main board has been lost, broken wire, main board has gone bad or for some other reason can not receive and instruction from the main board. If you have a spa side control, if spa side works then board may be ok, look for bad wire. If spa side is not working disconnect and power cycle the system and try the wall mount with spa disconnected. You may only need to replace the main board. More info on your system would be needed in order to suggest the proper replacement.
Sep 04, 2014 | Pool & Spa
Firmware on main board 10000100 error
Live (free support) chat with Epson:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&category=Products&infoType=Contact&oid=14397&prodoid=19302859
Nov 06, 2013 | Epson Stylus Pro 9600 InkJet Printer
After reset chip printer, printer error NICBridge Gzip. c 1334 and does not edit the keys would be much help thanks.
U have wrogly upgrade d the firmware.of the main board.Try with a fresh copy of original Samsung firmware.
Elase replace main board.
Dec 22, 2010 | Samsung SCX-4828FN All-In-One Laser...
Sharp TV LC-42D64U
That totally stinks! Do a search for that tv on the internet. You might be able to get a main board inexpensively. I did for an LG 32 inch. I got all the circuit boards for the tv (never used) for less than $100. I replaced the main board and works great. Replace only if you know what you are doing!
Nov 03, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Camera wont work
This could be a Hardware Issue, and there are also chances that your Firmware is buggy.
You need to Flash your Phone through USB Cable and a software call Phone XS++
SE phone Firmware has two parts.
Main Firmware which contains all the phone software. Main firmware file has the .mbn extension.
FS is a firmware which has settings and all other data like the default images and Ringtones and all other files that is used by phone. It has .fbn file extension.
Before you flash the main firmware make GDFS BACKUP. GDFS backup is very important and not to be missed. You also need to have USB Flash Drivers Installed.
Download Links For XS++ and everything else is here
Download The Video Guide
Note: There are many things that should be kept in Mind while Flashing your Phone like..Full Battery/No Power Failure during the process...etc.
So If you are Ready then Proceed, otherwise contact someone, who had done it .
Regards,
Waqar.
Aug 16, 2009 | Sony Ericsson Walkman W810i Cellular Phone
MAIN FIRMWARE
You can find firmware at :
http://www.akshayy.com/sonyericsson/
Hi to all. I have seen thet flashing CID52 phones has been very often nowadays, but many people are asking how to flash their phones and there is no such tutorial around the forum, so I decided to put one icon_smile.gif.
First of all I would like to tell the advantage (purpose) or meaning of flashing icon_smile.gif. Flashing the phone is procedure of putting new firmware (software) in the phone. There are many reasons to flash our phones. Firmware upgrade, solve software problems and bugs, convert our phones to some other model (most common is K800 to K810) and etc...
Flashing the firmware is done by changing the MAIN and the FS part of the firmware (while not touching the EROM and the GDFS) which makes the flashing easy procedure that can be done with the ordinal DCU60 USB cable (the cable you get with your sony ericsson phone) icon_smile.gif.
Once we know what flashing is, we can start preparing for the flashing procedure icon_smile.gif. To flash the phone means to change the MAIN and the FS part of the firmware, which means if you want to flash your phone with new one, you have to download it. Firmware and other stuff can be downloaded from here:
http://www.sek750i.pl
http://www.iprotebe.cz
These pages are free and registration is easy and fast.
First, download XS++ flashing program.
When you download MAIN and FS files for flashing, you need to download finalization files for your new firmware. There are MAAANY finalization files (a.k.a custom files or custpacks and etc...) sorted by the phone's firmware CDA numbers. To download the right one for you, you have to check your phone CDA. CDA can be checked from the service menu (>*<<*<*) where you check the firmware version. There are letters CDA followed by some numbers like 1024, 1025 or etc... These numbers are the CDA version. You have to download custpacks for the CDA you have, and the firmware you are planning to flash your phone with.
When you have all files needed you can start flashing the phone.
You need to have installed flash drivers for your phone. For beginners, flash drivers installation guide is included here:
http://www.esato.com/board/viewtopic.php?topic=150098
When you have the flash drivers installed, you can run XS++.
Before that, prepare you firmware files in one folder (I mean the MAIN and FS file unzipped in .mbn, .fbn format or whatever it is) to have them easy for accesing and navigation.
Turn off your phone. Remove the SIM card. Run XS++ and then press the "Connect button"
Then connect the phone to your pc using the USB cable while the phone is turned off. When connecting the phone to pc, hold pressed the "c"button (on the phone) pressed down. This will connect your phone to XS++, where you can start flashing it.
You will see folowing window:
New window
Press the flash radio button (As number 1 shows) if needed only. That will guide you to the flashing panel of XS++. Here you can select which firmware files you will use to flash your phone with. So check the FLASH MAIN and FLASH FILESYSTEM check boxes. Then press browse and locate MAIN and FS firmware files. When browsing from MAIN navigate and select the MAIN firmware file you have downloaded, and when browsing from FILESYSTEM, do tha same for the downloaded FS firmware file.
Then press the "Flash" button.
Now you have to wait while your phone is being flashed.
Once flashing is done, you will be prompted to unplug the phone. Then you can turn on the phone. You will get this error:
"Configuration error, please contact network operator for information". This means that your phone is not finalized. Finalizing the phone is done by uploading a pack of files into predefined folder inside the phone's filesystem structure. That pack of files is called finalization files also knows as custom files, cestpacks and etc...
Use XS++ to upload these files (you downloaded before) into this folder:
tpa/preset/custom
Use the XS++'s FSX feature to upload these files.
Here is a tutorial how to upload files to phone filesystem using XS++
http://www.esato.com/board/viewtopic.php?topic=153863
WARNING: EVERYTHING YOU DECIDE TO DO WITH YOUR PHONE IS AT YOUR OWN RISK. ME OR ANYONE ELSE IS NOT RESPONSIBLE FOR THE DAMAGE MADE TO YOUR PHONE DUE TO UNPROPER USING THE PROGRAMS INCLUDED IN THE GUIDE!!!
Hope this guide will help most of the people who are runing around the forum and asking the members for step by step flashing tutorial icon_smile.gif.
Mar 13, 2009 | Sony Ericsson K550i Cyber-shot Smartphone
Firmware
can only be done by service personal by help of a special service software....
Jun 23, 2008 | Brother MFC-5440CN All-In-One InkJet...
Lost playlist on main screen
Have you tried updating the firmware of your Zen V Plus? I've had mine for almost an year and haven't had these issues -- I updated the firmware as soon as I unpacked it.
try downloading the
MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
By the way, before updating the firmware, let the battery have a full charge, ok?
Jan 03, 2008 | Creative Labs Zen Touch MP3 Player
Samsung ML-2855ND Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
