Question about Carburetor Support Bracket Air Cleaner to Tappet Guide 1957-1985 XL
There are two holes between the spark plug sockets of a toyota yaris 1.3. My car is licking oil through these holes when driving because the components that cover the holes have been removed. I want to purchase them but don`t know the name.
  • 787 Answers
Without seeing a picture of the engine I can't be 100% but it sounds like someone has removed 2 of the valve cover bolts for some reason.
Posted on Nov 21, 2013
Location of spark plugs on a 2000 Toyota Echo
a repair manual will probably tell you. it has maintenance schedules, models of commonly replaced parts (spark plugs, oil type, weight etc)
http://www.papertownspdf.com/downloads/toyota-yaris-echo-repair-manual-1999-2010/
Dec 29, 2016 | 2000 Toyota ECHO
How many spark plugs
  • Quantity Per Vehicle: 4.Here's a link to some,best to use the same that's in it type.
List Spark Plug 2008 Toyota Yaris Reilly Auto Parts
Sep 23, 2015 | 2008 Toyota Yaris
Stripped spark plug
Add little oil to the plug hole,turn back n forward by little by little,it might strip the thread,but u can get repair tool to fix it easy after.u need to try to turn it with patient.warm up the engine I can feel more easy to do.:)
Jan 26, 2014 | 2003 Toyota Matrix
The yaris is automatic transmission(the lever is not select properly,the car is not moved the oil is overfiow
i cant read that.
1: i can't move shift lever, from park to drive?
2: the car will not move, that is i can not drive car.
3: the oil from (what) is overflowing. what oil, landing where?
the #3 is the most perplexing,
can you crank engine?
does engine start?
if engine oil is on the drive way, do not start car. or risk burning up engine,, (brown oil, not stink to high heaven)
if A/T (ATF) its pink oil, if on drive way, then the tranny is breached.
do not drive or the tranny will burn up.
to sure #1 , read the operators guide.
you start the engine,
apply the foot brake and the shifter lock ,releases.
Dec 08, 2013 | 2007 Toyota Yaris
O7 yaris starts then shuts off
Engine stalls soon after starting
1. Fuel pump control circuit.
2. Spark plugs.
3. Ignition system.
4. Fuel Injectors.
5. Variable valve timing system.
6. Electronic throttle control system.
7. Air induction system.
8. PCV hose -
9. Compression
Aug 20, 2012 | 2007 Toyota Yaris
How to change plugs in a 2008 yaris
- Remove 4 (with 6mm socket) and cylinder head plastic cover.
- Disconnect Igniters connectors.
- Remove the bolts and ignition coils.
- Remove the spark plugs with 16 mm spark plug socket.
- Inspect the electrodes of all spark plugs. If the electrodes are found to be round or corroded at their tips, replace all together.
- Adjust the spark plug gap to 0.9 -1.1 mm.
Jul 21, 2012 | 2008 Toyota Yaris Sedan
How to replace spark plugs in a Toyota Yaris sedan
Your car has four coil packs, coil packs set on top of valvr cover, remove bolt that holds coil pack, pull coil pack out, and with extension and spark plug socket remove spark plug, do the same with all.Hope this was very helpful.
Aug 19, 2010 | 2008 Toyota Yaris Sedan
How do you change spark plugs on a toyota yaris 2001
First you must remove the plastic cover from on top of the engine to access the ignition coils. The next step is to remove the ignition coils. To do this you must carefully disconnect the plug by holding down the plastic tab while pulling the plug off the coil. Then you must remove the small bolts holding the coils to the valve cover. Pull the coils straight out. To remove the spark plugs you will need a torque wrench, long extension and a self holding spark plug socket. All these can be bought at your local auto parts store. The spark plugs are removed by unscrewing them from the cylinder head and pulling them straight out. Installation is the reverse of removal. The spark plugs are tightened to 25 foot pounds of torque and the small bolts for the ignition coils are tightened to 10 foot pounds of torque.
Oct 23, 2009 | 2007 Toyota Yaris
Carburetor Support Bracket Air Cleaner to Tappet Guide 1957-1985 XL Logo
48 people viewed this question
Top MCA Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a MCA Vehicle Part and Accessory Expert? Answer questions, earn points and help others
