Question about Nakamichi SoundSpace 9 CD Shelf System
Subwoofer repair I need information on removing the front diamond cover (grill) on the subwoofer. Can anyone help?
It's easy just use a flat screwdriver and sprang the 4 sides of cover grill. It's should pop out easily.
Posted on Dec 11, 2013
Can't get the back off of my Wharfedale Diamond's. Model 7.1
Sometimes the back does not come off, but the speaker comes out from the front...
Mar 22, 2010 | Wharfedale Diamond 8.3 Main / Stereo...
How do I change out a 2005 murano grille? THANKS
This is out of my 06 Murano manual, hope that it helps.
REMOVAL
1. Apply protection tape around outer circumference of front grille (bumper fascia side).
2. Remove front grille-radiator cover clips and remove front grille-radiator cover.
3. Remove clips on upper side of front grille.
4. Remove clips of air duct and remove air duct. Refer to EM-16, "AIR CLEANER AND AIR DUCT" .
5. Pull out grille pawls, and remove front grille assembly.
Installation is the reverse of removal.
good luck
Feb 26, 2010 | 2005 Nissan Murano
Mitsubishi NEC Diamond PRO 930SB Monitor - cover removal?
Remove the screws as you have done. Looking at the monitor front on you'll see 3 bits sticking down from the top (in the deatil gap) which are clips unclip them by pushing through the corresponding holes along the top. Also there's a clip at each side on the underside of the monitor which are very obvious. With the monitor facing down and everything unclipped just pull the cover upwards. It's not easy but work your way round the front edge and it will come.
Jun 26, 2009 | NEC Mitsubishi Diamond Pro 930SB 19" CRT...
2001 ford focus stereo amp location
not all have amps.
SECTION 415-01: Audio Unit 2001 Focus Workshop Manual
REMOVAL AND INSTALLATION Subwoofer Amplifier Removal
  1. Remove the subwoofer speaker. For additional information, refer to Section 415-03 .
8 screws
  1. Remove the grill.
  1. Remove the subwoofer amplifier cover retaining screws.
  1. Disconnect the subwoofer amplifier electrical connectors.
  1. Remove the subwoofer amplifier retaining screws.
    • Remove subwoofer amplifier.
Apr 27, 2009 | 2000 Ford Focus
Parts for New Braunfels Black Diamond Smoker
i need replacement grilling grates for my black diamond smoker can someone help?
Apr 09, 2009 | New Braunfels Black Diamond Smoker...
How do I remove the cloth grill cover from the front of speaker?
Some speaker manufacturers design their boxes with non-removable front grills. Be thankful that you can remove the back because I've seen these sealed as well. Once inside, the speakers should be mounted from the inside (mounting screws on inside) compared to front mounted. IF they are not then either you're not using the proper method to remove the grill OR it's glued in place and will require breaking the glue bond to release the grill. One note to remember...non-removable grills can mean the manufacturer has something to hide.
Mar 22, 2009 | Philips Audio Players & Recorders
Dis-assembling subwoofer
Unless you are good with wiring and can accept having the front cover broken, then you can do it yourself. The speaker protector can be gently pried off but will probably break if not done perfectly. If you get the front cover off, there should be 4 screws holding the speaker. Remove them and then you can see inside. Take note of how the resisters are attached. You may need to solder if they are separated. If you are confident handling this job, go for it, if not, take it to your local repair shop.
Oct 29, 2007 | Philips LX3600D System
Gas coming out near burner knobs
The issue is with the valve that is connected to the knob. it is poorly designed. To fix it take off the lid assembly and remove the front black cover that covers the knobs. remove the almost diamond shaped metal piece that the knob shaft runs through. put on your gas tank and adjust the valve to a position where no gas comes through.. might be lucky or you will have to replace that valve.
Oct 14, 2007 | Coleman Roadtrip Grill LXE 9949-750
Nakamichi SoundSpace 9 CD Shelf System Logo
89 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
ELECTRICLAW
Level 1 Expert
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
