Question about Viper 7211V
Won't program How do I program the remote with the keys
Program keyless remote 2009 pontiac vibe
Try removing the battery then try again.
Aug 11, 2013 | Televison & Video
1995 Chrysler Lebaron won't start without the Keyless Remote.
that is a arter market alarm .that year did not come with a keyless enter. I have I have 2 conveter lebarons in my garage now. you will need to remove the after market alarm
Dec 05, 2012 | 1995 Chrysler LeBaron
Programmed remote still won't work
Wrong remote or wrong programming method or system is not operable.
Oct 22, 2012 | 2007 Subaru Forester 2.5
I installed prostart remote starter in 2002 Sonoma,used xpresskit bypass module to bypass passlock 2, truck started with remote ,now won;t start with remote,have to reset and start with truck key
If you are sure that everything is connected properly, then the only explanation could the ground when running from the remote starter to the bypass. If you are using data to data(D2D), switch over to wire to wire. Test the ground when running connection from the remote starter (white) to the ground when running connection of the Xpresskit (blue). You could even go so far as to connect the ground when running of the bypass to constant ground for the test. You CANNOT leave this wire connected to chassis ground.
Also, that vehicle has a second ignition wire(white) that MUST BE power up for remote start. If not, it will trigger the check engine light.
Oct 01, 2012 | Vehicle Parts & Accessories
Electronic key on 2008 jeep cherokee says key damaged or key not programmed. car won't start. some things work but radio won't come on. etc..
electronic key on 2008 jeep cherokee says key damaged or key not programmed. car won't start. some things work but radio won't come on. etc..
Jul 24, 2011 | 2008 Jeep Cherokee Grand
I will program the remote the correct way, but still it won't program. When I'm done typing in the code for my ESA tv, I'll press the power twice and it'll turn off. Then I'll try...
Hello
Codes for ESA TV with RCA RCR312w are:
10812, 10171, 11963
1* Manually turn on the component you want the remote to
control.
2* Locate the enclosed Code Lists. Find the list for the
component you wish to program. Find your component's
brand. You will see a listing of four-digit codes for each
brand. If your brand isn't listed, use one of the Code Search
methods to program the remote control.
3* Press and hold the component key (TV,
VCR•DVD, SAT•CBL) you wish to
program. The illuminated ON•OFF key
turns on and remains on. If you release
the component key at any time during the Direct Code
Entry procedure, the illuminated ON•OFF key blinks four
times, and the process is exited.
4* While holding down the component key, consult the
Code Lists for the four-digit code that corresponds to your
component's brand and use the number keys (0-9) on the
keypad to enter it. While you are pressing the numbers, the
illuminated ON•OFF key turns off.
5* After the fourth number is entered, the illuminated ON•OFF
key turns on. At this time, release the component key. If the
illuminated ON•OFF key turns off, you have entered a valid
code and have followed the correct procedure for Direct
Code Entry
If you enter a code number that is not in the Code Lists or
you do not follow all of the steps for Direct Code Entry,
the illuminated ON•OFF key blinks four times when the
component key is released. This is an indication that a
programming error has occurred. In that case, repeat the
Direct Code Entry process from step 3.
Tip: Throughout the programming of each key, be sure to keep the
remote pointed at the IR sensor of the component you are currently
programming the remote to control.
6* To confirm that the component key is programmed with
the correct code for maximum functionality, test the
component. Attempt to control a variety of the component's
functions with the remote. If some of the features of your
components do not work, try programming the remote with
a different code in the list until you find the code that allows
the remote to control the majority of your component's
functions. Different codes can provide different levels of
functionality
Jul 08, 2011 | RCA RCR312W Remote Control
I need help I just won a tv but it didnt come with a remote but I have a RCA remote transmitter. Im trying to program it for the tv but I dont have the book anymore can you please help me The tv is on but...
This Web page should allow you to find the codes for any devices you want to add for this remote.http://remotefinder.rca.com/default.aspx?site=rca
Other than that there is an easy way to program this remote.
1. Turn on the device by hand. 2. Hold down the device name key.(hold the TV button to program a TV) 3. While holding down this key also hold down the power key until the red light turns off and comes back on. Then release both buttons. 4. From here hit the power button repeatedly until the device turns off. 5. Hit the stop key at the bottom. Now the remote is programmed for that device.
May 05, 2011 | Televison & Video
Keys won,t lock or unlock doors
Use this Procedure for Buick Vehicles "With" Driver Information Center Buttons.
This information is in your "Owners Manual" in the "Drivers Information Center Section."
1. Insert Key and turn to ON position so you can access Driver Information Center.
2. Press the vehicle information button until PRESS TO RELEARN REMOTE KEY displays.
3. Press the set/reset button until REMOTE KEY LEARNING ACTIVE displays.
4. Press and hold the lock and unlock buttons on the key-less remote at the same
time for approximately 15 seconds. A chime will sound indicating that the remote is
programmed.
5. To program additional remotes at this time repeat step 4. This vehicle can have a maximum of eight remotes programmed.
6. To exit programming mode turn key off and remove key. Test remote(s).
Use this Procedure for Buick Vehicles "Without" Drivers Information Center Buttons.
To access this display, the vehicle must be in Park (P) with key in the on position (as far as you can go without cranking engine).
1. Press the trip odometer reset stem until RELEARN REMOTE KEY displays.
2. Press and hold the trip odometer reset stem for three seconds. The message REMOTE KEY LEARNING ACTIVE will display
3. Press and hold the lock and unlock buttons on the first key-less remote at the same
programmed.
4. To program additional remotes at this time repeat step 3. This vehicle can have a maximum of eight remotes programmed.
5. To exit programming mode turn key off and remove key. Test remote(s).
Good Luck !
Mar 25, 2009 | 2005 Buick LaCrosse
Unable to program year 08
8 key broken on your remote? try a universal remote.. if not then the people who programed in the years into the tv figured that the tv wouldnt be in use in 10 years so they stoped programing at 07' ... not really a whole lot you can do there but deal with it or buy a new TV. sorry =(
Jan 18, 2008 | Quasar VV-1302 13 in. TV/VCR Combo
Viper 7211V Logo
50 people viewed this question
Top Viper Televison & Video Experts
Hjalmer Lamminen
Hjalmer Lamminen
Paul Bade
richie46
Are you a Viper Televison and Video Expert? Answer questions, earn points and help others
