Question about Acer AL1716B 17" LCD Monitor
Monitor with horizontal shakes
I have the al1716b and i plugged it into my computer via vga and get funny shakes that go horizontally across the screen. the funny part is that when i hit the menu button on the monitor itself, the monitor display menu is as clear as day. its not the cable or the pc. and i do have my pc turned down to 60 hertz and it still is shaky. HELP PLEASE!!
I have found a twisted groundline makes my monitors horizon dance, try a more natural approach to your power cord setup, like a waterfall or growing vines, rigged every 8 inches
Posted on Jun 25, 2008
When turn on - Image have double shadow like 3D, bold horizontal lines jumping across, hardly read the menu.
Shut down the computer, load into BIOS, if problem exists, the issue is likely with the monitor, try another monitor, if issue exists, else if in BIOS, the display is perfect, the graphics card driver needs to be updated or the graphics card needs to be replaced.
Apr 24, 2010 | Boxlight SP 6t Multimedia Projector
Wide horizontal bars ghosting across screen
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .also check you warrenty its usually 3 years
Apr 12, 2010 | Acer AL1916W 19" LCD Monitor
Shrinking of the display
The DB15 VGA (Video Graphics Array) connector contains however 15 pins in three rows of 5 pins each. These five pins carry the color and synchronisation signals, also a digital I2C interface for two-way communication between the video controller and monitor. The common 15-pin VGA connector found on most video cards, computer monitors, high definition televisions which support VGA connections. The following schematic diagram and table shows respectively connector and pin assignment of DB15 VGA.
Pin
Name
Function
6
7
8
9
10
11
12
13
14
15
RED
GREEN
BLUE
n/c
GND
RED_RTN
GREEN_RTN
BLUE_RTN
VDC
GND
n/c
SDA
HSYNC
VSYNC
SLC
Red Video
Green Video
Blue Video
not connected
Signal Ground
Red Ground
Green Ground
Blue Ground
5 VDC supply (fused)
Signal Ground
not connected
DDC/I2C data
Horizontal Sycn
Vertical Sycn
DDC/I2C Clock
Aug 10, 2009 | SAMTRON 55V 15" CRT Monitor
Screen shakes BUT menu is clear (Not shaking) and the power cord solution does not work. What other Ideas are there?
Try installing this Monitor on a different PC. If the problem is then resolved, its your video card.
Jul 25, 2009 | Acer AL1716B 17" LCD Monitor
Monitor not getting info from computer
Does the computer beep when it starts? Does the monitor work on another pc? Possible culprits with these symptoms are the power supply and video card.
Feb 16, 2008 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
My screen has horizontal lines across it
its the ram
mine does the same took ram out replace
Nov 24, 2007 | Medion MD 7317 17" Flat Panel LCD Monitor
Unstable image
Have you tried installing a different monitor to your pc to actually find if this is a problem with the monitor or the video output of the pc? If this is not a viable option for you, you might try running a S Video or RCA cable from your video card to a TV and changing the output on your video setting to reflect such.
Aug 15, 2007 | Acer AL1716B 17" LCD Monitor
Acer AL1716B 17" LCD Monitor Logo
257 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
