Question about Hoisting
How much can my lever ratchet hoist lift? - Hoisting
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Habit-Forming:
  • 15 Answers
Common ratchet lever hoists have the capasity to lift up to 5 tons, but some can only lift 1/2 ton its important to consult your user manual for exact numbers before use.
Posted on Nov 21, 2013
What safety tips should I follow when using lifting hoists?
Lifting hoists are tasked with the pivotal job of lifting heavy loads that would otherwise be rather impossible to lift. Used in many industries worldwide, there are various safety tips and guidelines one should follow thoroughly, to ensure both the safety of the workers, and to extend the lifting hoist's lifespan. The equipment should first be inspected before and after every use, so as to make sure there are no defects and that the equipment is clean, as slight issues with the equipment could be dangerous if left unattended for any period of time. One should also always be aware of the lifting load limit of the lifting hoist and comply to this limit - never, for any reason, exceed this limit! This can be extremely dangerous, as placing too much strain on the lifting hoist can cause it to break. These are just a couple of the number of factors that could cause a normally sound piece of equipment to be dangerous. To find out more on this topic, this handy infographic from Lifting Hoists Direct, titled "Safety Tips for the Effective Use of Lifting Hoists" was helpful in answering all my questions.
safety tips for the effective use of lifting hoists infographic (final)-3lnz3eczbu0rpnl5hmzvm3sh-2-3.jpg
Sep 13, 2017 | Cars & Trucks
Youtube repair
safety catch worn or spring weak.
Aug 13, 2014 | Jet 310015 JLH-100WO-15, 1 Ton Capacity...
How to remove hills hoist from ground socket
Wrap a chain or rope around the base, and then around a 2" x 4" length of lumber (or somesuch) near the end. Put one end of the board on the ground, and lift the other end.
Use it as a lever to pull straight up and remove it.
Jul 26, 2014 | Hills Everyday Villa 37 Rotary Hoist...
Are wire hoists as strong as chain hoists?
Wire hoists are as strong and in some cases can be stronger even than chain hoists being able to lift between 1/2 up to 80 tons.
Nov 21, 2013 | Hoisting
Can i possibly pull a 3.4 out the top from a 2001 olds sillouette van, i pulled one from a 2003 dodge caravan, it was tough but it worked. can it also be done in the olds. i dont have a hoist or accsess to...
Its going be tough to pull out anything other than a small 4 cylinder without a hoist. You could use a comealong. Its like a small hoist, has a chain and a lever you can use to lift the engine. It has a hook on it to allow you to attach it to something.
But to be able to use it you need to put the car underneath something that is sturdy enough to support the weight of the engine, like a large limb on a tree or a metal frame of a garage or something like that.
And you will need a sturdy chain. The bigger the better. Attach the chain to your engine lift hooks.
Get some grade 8 screws,nuts and washers from home depot. Get the largest diameter screws that will fit through the links of the chain. Make a loop on each end of the chain by putting the screws through links and tightening the nuts on the screws. Put the loops you made on the engine lift hooks. Attach the come along to the tree or whatever you can find thats sturdy enough to support the weight of the engine with another chain. Then lift the engine out.
you will have to detach the ac compressor and power steering pump and tie them out of the way with pieces of wire. That way you wont have to discharge the ac system or drain the power steering fluid. Remove coolant hoses and fuel lines. And remove the half shafts for front wheel drive. Then detach the motor mounts/transmission mounts. Of course, theres a lot of other stuff you need to detach, but im sure you know that already.
You can rent engine hoists for like $35 a day from a Taylor Rental or other equipment rental
company. Rent it one day and take it back and rent it another day when you are ready to
put the engine or another engine back in.
Sep 14, 2011 | 2001 Oldsmobile Silhouette
Hi I purchased a used jazzy 1103 for my father and need to replace the batteries I cannot remove the seat directions say pull friction lever up to remove seat however the seat won't move
the seat post is probably rusted in the post. Try lifting the handle and twisting the seat and pulling up at the same time it can really be very hard but keep trying and maybe get some help to lift as it is being turned. I've had to use a hoist to lift it off the floor and twist the seat until it comes out. Hope this helps
Feb 22, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Wheels sticking will not open lock jammed
The bugaboo brake lever can lockup. Check the screw nut at the bottom end of the cable. If you can wind that down to take some tension off the cable the lever will them release. If there is no adjustment try lifting the lever up higher (as to put the brake on harder) then push the white release button at the same time. The break lever uses a set of ratchet teeth that must move up slightly to release.
Dec 30, 2010 | Bugaboo Cameleon - Tailored Fabric...
How do I hoist or lift an old 2001 Mercury Sable engine and replace with new? I need places on the engine that will allow me to lift out engine with a hoist.
ENGINE AND TRANSMISSION HAS TO BE SUPPORTED ON THE BOTTOM BY A POWER TRAIN LIFT. THE ENTIRE CAR BODY HAS TO BE RAISED BY A LIFT UP AWAY FROM THE POWER TRAIN WHICH IS SUPPORTED UNDER THE BOTTOM WITH A SPECIAL POWER TRAIN LIFT OR TABLE.
Dec 24, 2010 | 2001 Mercury Sable
I need a hoist manual for a Demag hoist type:36/24K6p
buenas amigo tengo disponible todo los catalogos Demag de servicio que requieras. Tambi?n tengo el que requieres. el costo del manual es de 20 dolares. combo de 10 catalogos 190 dolares. Jcmreconomia@gmail.com
Mar 19, 2009 | Crane & Co SpitzLift Portable Crane & Lift...
How do I get a manual for a 1998 mercury Sable for free?
To replace or service the transmission you will need to:
lift the vehicle
support then engine using a hoist/lift
support the transmission using a hoist/lift
unbolt the motor mounts (There are 4 of them)
lower the engine 8 - 10 inches
unbolt the transmission
lower the transmission
Jul 19, 2008 | 1998 Mercury Sable
Hoisting Logo
966 people viewed this question
Top Hoisting Experts
gbob59
Andrew Taylor
Andrew Taylor
Are you a Hoisting Expert? Answer questions, earn points and help others
