Question about LG 42LP1D 42 in. LCD HDTV
LG TV GOES ON AND SHOWS NO PICTURES THOUGH THE ANTENNA IS CONNECTED PROPERLY
  • 115 Answers
Are u receiving sound
Posted on Nov 21, 2013
Why does LG tv shows no signal fot local nbc channel
Not sure how you are connected to receive the signal, but if you are not using a cable box and going off air, then either the signal is not coming in from NBC, or your antenna needs adjustment. IF its over the air, its also a digital signal which will tune to lets say channel 4. For digital it will be 4.1 or 4.2 etc.
If you are using a cable/sat box to then connect to the TV, call the provider and ask.
Aug 26, 2014 | LG 42LC2D 42 in. LCD HDTV
TV antaina not found
Need more info to help fully, but here goes:
If you're trying to setup for over-the-air broadcasts, make sure the antenna you connect to the TV is an amplified antenna (preferably an OUTSIDE amplified antenna). Unless you're very close to a transmitter, you won't pick up signals otherwise.
Dec 10, 2013 | LG Infinia 47LV3700 47 inch LED HDTV 1080p...
Connecting pc to tv - tv shows pc screen then goes black
Try running through all the different resolution settings on your laptop, some tv's are very specific about which resolutions will display and which won't.
Nov 06, 2013 | Televison & Video
I don't now how i recive tv chanels in hd
Your source has to be in HD like a local broadcast TV station currently broadcasting in HD which you get with a VHF/UHF antenna connected to the HDTV. Most primetime TV shows are in HD so using the antenna on the HDTV is all you need. Press MENU on your TV remote and make sure you have ANTENNA set instead of cable to get local TV stations.
You also could use your local cable TV provider. You would need digital cable service and a HD cable box with HDMI or component video cable hookup to the HDTV. HD channels are typically above 100. Call your cable TV provider for more details.
Read your user manual for the LG TV. Ask for help from family, friends, neighbors, local electronics shops.
Mar 13, 2011 | LG 32LG30 32 in. LCD HDTV
My lg tv (had since Nov) says no signal for the tv or dvd player. How do I fix this?
Try unplugging all inputs and the power cord from the TV for 5 minutes. This will allow the main board to reset.
Next, just plug in the power plug to the TV, power up the TV, and even though there is not a source connected to the TV, check at least three inputs and see what the TV will report on the screen for each input.
Next, turn off the TV, plug in all known working devices (Cable/Antenna, DVD, Blu-Ray, Cable/Satellite box, Game, ….) with a known working cables to the TV, make sure all the devices connected to the TV are powered up and on, and now power on the TV.
Now check to see if the TV is seeing valid signal for all the inputs connected to the TV.
If your TV cannot see any signal at any of its inputs (HDMI1, HMDI2, HDMI3, AVI1, AVI2, Component1, ……), then the main board has failed and need to be replaced.
Good Luck.
May 21, 2010 | LG 32LG40 32 in. LCD HDTV
My on screen TV guide no longer works, and my TV keeps losing time (between 10 and 20 minutes). I'm not sure how to fix this. Is this a hardware issue or a settings issue? Has someone else had prior...
Do you have cable TV? Many Cable TV companies have recently (over the last year or two) quit sending TV Guide data. You can get it through an external antenna connected to the TV's antenna input if you are within range of an ABC or NBC and a PBS affiliate for the clock auto set.
But if you still have TV Guide service, some of these have failed circuit boards for the TV Guide, ( usually shows a complete black screen when you turn it on or hit guide button.
Apr 13, 2010 | LG 50PX4DR 50 in. Plasma TV
I have an LG flatron l1710s monitor . when you turn it on it flashes the message that there is no video signal then the screen goes black. and nothing is showing. the monitor stays on as far as the power...
You need to 1. hook up and 2. select a video source. It can be from your antenna, cable, tuner, VCR, DVR, DVD, etc.
If you have any of these connected properly, 2. select the correct input to get any video to work.
See your operator's manual for set up instructions or ask me for more information about the hook up.
Hope this helps. :)
Mar 31, 2008 | Televison & Video
Watch while recording
Make sure the DVD has RF lead and Scart lead connected in and also BOTH connected out to the TV. When you record from TV use channel numbers, when you record from cable use AV channel, (on DVD). When watching TV use TV channels 1 to 5, when watching Cable use AV channel, (on TV).
Feb 06, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
My dvd shows prog 200 and wont change
FIXED! LG DAT-250W INSTRUCTIONS: TURN OFF THE MAINS POWER AT THE WALL UNPLUG ANTENNA FROM THE BACK TURN POWER BACK ON AT THE WALL & START AS NORMAL IT WILL COME UP WITH "POOR SIGNAL" THEN WE FLICKED THROUGH THE CHANNELS & TURNED IT OFF AGAIN AT COMPONENT & AT THE WALL PLUG THE ANTENNA BACK IN TURN EVERYTHING BACK ON Note: **Just avoid the channel that keeps locking up** LG are aware of this issue
Sep 30, 2007 | LG Televison & Video
LG 42LP1D 42 in. LCD HDTV Logo
21 people viewed this question
Computer Repairing
Computer Repairing
