Question about Sony Computers & Internet
Sony sdm-hs93 driver for windows 7 64bit - Sony Computers & Internet
bunnydawg
  • 5158 Answers
SOURCE: windows vista driver for Sony SDM-hs75
http://esupport.sony.com/perl/select-system.pl
please take a moment to rate this solution
Posted on Feb 02, 2009
budmrtn
  • 11361 Answers
SOURCE: My Sony SDM-HS93 has a VERY intermittent
Common failure in the SDM-HS73/93 is the bad lamps assembly due to poor soldering works.
Service manual: http://elektrotanya.com/?q=showresult&megnev=SONY&megnev2=SDM-HS93&kategoria=monitor&kat2=all
Pictures: http://s807.photobucket.com/home/budm/allalbums
Posted on Apr 12, 2010
budmrtn
  • 11361 Answers
SOURCE: No input signal, go to power save sony sdm-hs93
I f you see the message on the screen indicating 'NO INPUR SIGNAL', you need to check the VGA cable and both ends of the connectors also. Try this monitor with other PC also.
This SDM-HS73/93 have common problem: bad backlight assemblies due to poor workmanship in sodlering works, see my pictures below. You should also inspect the caps. This is not recommend for DIY.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS93/
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
Posted on Apr 18, 2010
SOURCE: My Monitor Sony SDM HS93,
sony sdm e96d screen does not come on. the light goes from green to yellow and doesnt switch on.
Posted on Feb 16, 2011
ticthak
  • 43 Answers
SOURCE: Sony SDM-HS93 -No Power light, No Image
It doesn't sound like an inverter problem if the fuse is OK, there should at least be a standby indication.
There are typical problems with ALL power supplies for LCD displays, not just these Sonys.
Posted on Feb 11, 2013
I have a Sony SDM-HS93 (Black) 19 I turn the monitor on and it flashes on then off and on again. does this continually.. any answer for me? I have opened the back and checked capacitors and all look...
It may have bad lamp assemblies, you need the inverter tester lamp to verify. See my pictures here:
This is common problem with the 17" version also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Feb 10, 2011 | Sony SDM-HS93 19" LCD Monitor
I have a SONY SDM-HS93 LCD monitor, Maybe Monitor receiverd an electric overstress, so the screen displayed but screen disappeared after few seconds. And if I turn it off & turn it on again, it turns...
Siny LCD Monitor is so expensive. <a href="http//www.wholesaleeshop.com.au/LCD-Monitor/index.php?keywords=philips">Philips LCD Monitor</a> is good!
Nov 02, 2010 | Sony SDM-HS93 19" LCD Monitor
Hi..my sony model sdm-hs93 lcd monitor flutters for a couple of seconds right before the screen blanks out. But, if I leave the monitor on for a day in sleep mode, the next day i can hook it up to the...
I think the problem with your monitor is that, the picture board on the monitor is malfunctioning that is why it keeps going blank after a minute.
What you need to do is to replace the picture board on your LCD monitor, replacing the picture board will solve the problem, because the picture board on the monitor at the moment is bad and will need to be replace.
Replace the picture board and you will see that the problem will not repeat itself again.
Take care.
Jul 16, 2010 | Sony SDM-HS93 19" LCD Monitor
Sony SDM HS73 ''turns off''
One thing I know for sure on this model HS73/HS93 is that the backlight assemblies failed due to poor soldering works. This may the problem with your monitor.
It is very time consuming repair works that I doubt very much if repair shop will do the work.
Apr 19, 2010 | Computers & Internet
Apr 18, 2010 | Sony SDM HS93 19" LCD Monitor
Sony SDM HS93 works fine, but: Monitor will not turn on with power button, if I plug in A/C cord power light goes on, monitor works. Sometimes the monitor comes on too bright, other times, too dim....
i get same..controls not working ,,sometimes menu button works and one arrow button..button "ok" button doesnt work and up arrow...brightness not working.
i get black box in upper left corner...quite diffucult to get rid of.
G
iamthehipster@yahoo.com
Feb 25, 2008 | Sony SDM HS93 19" LCD Monitor
Computers & Internet Logo
79 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
