Clicking Sound between agitation and drain cycle
I put it on the 6 min cycle and it agitates just fine, after agitation it starts clicking. After a period of a few min it drains the water and starts spinning just fine. It Goes through the rinse cycle and it starts clicking after it fills up. It again drains and starts spinning. I don't know what stage the clicking transpires but it is driving me crazy. Motor seams fine if it agitates and spinns, then not the motor. Have a clue what stage it is, between agitation and draining? Once I figure out that it might help me understand what the issue is...
  • 1 more comment
  • ComputerGuy Oct 08, 2007
    It is a top loading machine.
    It is a top loading washing machine.
  • JAYDBO Nov 17, 2007
    I also get the "clicking sound" with only partial agitation late in wash cycles, or in gentle cycle. This is coupled with a flickering of our house lights. Is this a solenoid problem?
  • 94 Answers
Is it a front loading or top loading washing machine?
Posted on Oct 08, 2007
Know when clutch going bad
Needs agitator dogs in agitator.
Mar 13, 2014 | Whirlpool Washing Machines
No drainage, Sound in Spin/Rinse Cycle
You may have a broken pump belt, or belt may have fell off pump pulley. Another possibility is that you have a bad clog before the pump keeping water from draining. Your machine will agitate because this is a separate belt. Good Luck Friend.
Oct 13, 2017 | Kenmore 98702 Stacked Washer/Dryer
Kenmore model 2495-4301. When closing the lid to begin any cycle, there's a metal clicking sound coming from the area of the bottom. The agitator will not move in any cycle. Just that clicking sound..
I had a similar problem with my washer. It was clicking, but the agitator was moving fine. The clicking was coming from the centrifugal switch. After checking the capacitor I was about the give up and call a repair tech. Then I noticed the Speed Selector was set between Delicate and Normal. I moved the selector to a proper position and the washer stopped making the clicking noise and is working correctly.
Feb 08, 2011 | Kenmore 24952 Top Load Washer
Washing machine is making a clicking/ticking sound when it is agitating during wash cycle
This is a sign of strained agitator components that are about to be damaged or stripped. I recommend pulling the agitator and clutch. inspect each device for stripped components and uneven ware. replace the agitator and clutch if found to be faulty.
Check the transmission(gear box) for damage as well. fill with oil if needed.
May 27, 2009 | Washing Machines
Grinding noise while agitating.
possible foreign substance under agitator
Feb 26, 2009 | Admiral AAV7000A
Washer does not spin and drain water. (Kenmore Elite Heavy Duty)
it seems to me ur washer transmission is going out or already there
Nov 26, 2008 | Kenmore 24032\24036 Top Load Washer
My washer does not drain after the rinse cycle
Open and close lid, listen for 'clicking' sound. If no 'clicking' sound, replace lid switch.
May 31, 2008 | Whirlpool Washing Machines
Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
Nov 10, 2007 | Kenmore 22422 Top Load Washer
Washer agitates for a time then sputters. Does not spin
In sounds to me like you have a motor issue. We have found that on these particuliar models, that the motor tries to run in both speeds at the same time. If you already replaced the control board, then you will have to get a new motor kit. This kit includes directions as well as a new wiring harness and start capacitor. You would have to remove the old motor and rewire the wiring harness (instructions included with the kit) and add the new start capacitor (instructions also included). Job is'nt really that hard to do. Front cover would be all you would need to remove to get to all the parts. Good luck and let me know how it turns out or if you need any additional help. Jim
Sep 05, 2007 | Washing Machines
Washing Machines Logo
219 people viewed this question
Top Washing Machines Experts
