Question about Singer Sewing Machines
6180 errors I have been using this machine from 2 years and it was working fine. But now the upper thread keeps breaking. I couldn't proceed single inch from 2 weeks. pls help me.
    Champion:
    Habit-Forming:
  • 201 Answers
Try to use quality threads. Or add some drop oil on thread.
Posted on Nov 21, 2013
SOURCE: BabyLock Proline upper looper thread keeps breaking
I ended up switching the spools of thread around. Apparently, even though I had purchased good quality threads, one of the spools was wound in a way that made the thread loop and twist around. So I put the offending spool of thread through one of the needles and put the needle thread on the upper looper. That seems to be working. By the way, BabyLoc was very unhelpful dealing with this problem.  Thank you!
Posted on Sep 09, 2008
SOURCE: Brother 925D - threads do not lock
threads do not overlock stich
Posted on Sep 27, 2008
SOURCE: Designer 1: upper thread shredding while embroidering
I too, have the same problem withmy Designer 1. I just bought ISACORD brand polyester embroidery thread to hopefully solve this problem, but I believe it must be a tension problem. I have a "date" with the repair lady on Friday (11/22/08) and if it gets repaired I will re-post what the problem was. Still love the machine WHEN IT SEWS!!
Posted on Nov 16, 2008
SOURCE: I have a Kenmore 385 (12116690) the thread keeps breaking
I have this same machine, it belonged to my husbands grandmother and was given to me after she passed. I let it sit for a few years before I got it out to use it, it was just too emotional. I had this same problem, and after cleaning, it worked fine. I followed the instructions in the manual for taking out the bobbin, bobbin case and metal parts that hold it in the machine. (there are pictures in the manual to help you take it out, take it apart, and put it back in... sounds hard but it's really not). I used a tooth brush to get all of the dust bunnies out (you could go over with a vacuum hose too, after the toothbrush cleaning). After I did this it worked fine. You may want to look in the manual about oiling the machine, if it's been years since it's been done, that might help to. Hope you get it working! I love this machine, it works well and is good quality. (they don't make sewing machines like they used to, the only one I'll buy is a Kenmore!)
Posted on Feb 27, 2009
  • 240 Answers
SOURCE: Machine is jamming
You need to remove the bobbin from the "race" by following the instructions in the manual. Give it a good clean and remove any bits of fluff and thread. Remove the upper thread also andmake sure that the tension wheel is clear of any broken threads and is on the correct setting. It may have been threaded wrong. The hand wheel not turning sounds like the bobbin area is jammed also.
Posted on Jun 11, 2009
Kenmore mini ultra The top thread breaks off from needle after a few stitches. The bobbin seems to Be catching the top thread. Thank you. ??
If the top thread sews a few inches and then breaks, something is catching the top thread and holding it until it breaks. Usually, this will happen when using the old style thread cones with the slit in the edge to keep the thread from raveling off the spool. To prevent the thread from hanging up, turn the thread spool over so the slit is at the top instead of the bottom. Sometimes top thread breaks will happen if the thread becomes looped around the thread spool pin.
Remove the thread, ALWAYS RAISE the presser foot and then rethread the upper thread. Verify that the thread path is correct and that the thread has not looped around a guide.
If the thread is fraying at the needle eye, the needle/thread are not compatible. Also, the tension may be too high.
Check that the upper tension disk is clean--no gunk buildup or thread pieces stuck.
If the thread is actually breaking when it penetrates the needle plate hole, there may be a burr or nick somewhere below that is catching the upper thread. You can wrap your finger with a piece of fine fabric, like an old pair of hosier, fine knit fabric, etc. and running your finger around in the bobbin area, under the needle plate. If you get snags, then you have a burr or nick. If it is small, you can sometimes smooth it with a fine emery board. If it is a large burr, you may need to purchase a replacement part.
Why Does My Top Thread Keep Breaking Sewing Machine
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Sep 05, 2016 | Kenmore Sewing Machines
Why the thread cracked with when i sticked with the machine
Thread breakage could occur for several reasons.
First, try a brand new needle.
Second, use only good quality thread--NOT old thread or bargain bin varieties.
Third, when threading the upper thread, be sure to ALWAYS RAISE the presser foot throughout the threading process.
Verify that the thread path is correct (consult the owner's manual). Incorrect threading will usually break the thread.
Check that the upper thread tension is set at the midway point between the high & low numbers.
NMSU Checklist of Common Machine Troubles
Why Does My Thread Keep Breaking While Sew
Aug 27, 2016 | Brother ES2000 Computerized Sewing Machine
My thread keeps breaking, Ive checked and changed my needle, re-threaded bobbin and upper but every time I try to sew the upper thread breaks.
Have you tried loosening the upper tension? Remove the upper thread, RAISE the presser foot and rethread from the beginning (make sure it follows the correct thread pathway). Sometimes the upper thread jumps out of a thread guide or wraps around something. Or try a different brand of thread? Avoid old or bargain bin threads--use good quality thread. Could also be the incorrect needle for the thread/fabric, ie thread too large for the needle eye.
Apr 03, 2016 | Sewing Machines
Singer 3825 upper thread keeps breaking
You might have an old needle. Most sewing experts recommend changing the needle between each project. As the needle ages the eye of the needle becomes rough and cuts the thread.
Alternatively, you might be using the wrong needle. Depending on the thickness of your fabric and the type of thread you are using you should adjust your needle type. There are needles for denim and needles for metallic threads.
When I have chronic problems like this I rethread both my upper and lower thread and that usually resolves the problem.
Dec 08, 2014 | Singer Sewing Machines
Necchi 519
Re thread your machine with a different thread, allow the thread spool a bit of play if it is position horizontal, leave your upper tension at mid range and have a go on straight stitch first. If ok then try the other patterns.
Aug 29, 2013 | Sewing Machines
Upper thread keeps breaking bobbin thread grtting cut on bobbin,
you need to change your needle first. then if that does not work you may have a small area on your bobbin case that has been damaged
May 22, 2009 | Baby Lock Esante
I have a brother 270D and the upper thread keeps breaking (common i know) but ive done everything int he trouble shooting section of the manual.. its only when i embroider too. checked different tensions,...
I had the same problem with my machine and what was causing the problem was the use of the wrong size bobbin. Check and make sure you are using the right size (type a) and if you can get bobbins already wound it would be better. Hope this will help you
May 14, 2009 | Brother SE-270D Computerized Sewing...
Brother 1034D
I had the same problem with the blue thread- it would sew and inch then pop- mine worked wihtout breaking after I re threaded in this order: green, blue, red then yellow
Jun 08, 2008 | Brother 1034D Mechanical Sewing Machine
Needle jams and breaks off
Needle jams....Thread is caught in the hook...solution...Remove the upper thread and bobbin case,turn the handwheel backwards and forwards by hand and remove the thread remands.
Needles breaks
1. Needles is damaged..Insert new needle
2. The needle is not correctly inserted....insert flat side towards the back
3. Wrong needle size for the fabric...Choose a needle to suit the thread and fabric.
Mar 24, 2008 | Singer 1116 Mechanical Sewing Machine
Sewing Machines Logo
48 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
