Question about ViewSonic VA1912w 19" LCD Monitor
Viewsonic va1912w lcd monitor doesnot start
Front panel led light continuously blinking
noone
  • 105 Answers
SOURCE: analog
Seeing the word "analog" on your screen means the monitor has recognized video input on the vga "analog" input connection.
Most computers output "analog" vga (15 pin) which must be converted to digital for a flat panel monitor to display the image.
Many LCDs now have both analog and digital inputs.
Mike
Posted on May 02, 2008
SOURCE: viewsonic problem
I RMA'd this probablem as well. They asked the usual questions -- try it alone, check the connections, are you using VGA or DVI... blah blah. Eventually they could give me an RMA.
They have customer support via phone on Sundays in the US, which is nice. Total time from calling to RMA was about 20 minutes.
Posted on Sep 14, 2008
SOURCE: viewsonic vp930b-3
Same symptoms with no display and blinking green light. My monitor had been having a distorted image occasionally and a subtle whack on the side would clear it up for a week or so. I replaced both of the 1000uF 16v caps and both 250uF 25v caps on the power supply. All 4 were bulging before. Powered up and all looks good. Thanks!!
Posted on Oct 06, 2008
SOURCE: viewsonic VA720 monitor has small blinking light, won't turn on
When turning on the computer we get analog auto save, and don't get as far as the desktop, how can I solve this problem
Debi
Posted on May 04, 2009
avdhootrao
  • 101 Answers
SOURCE: viewsonic va1912w monitor no display cables ok
this might be the problem of backlight which is used to give away light for viewing of color watch carefully u might see the picture without color if it is though then change the backlight byy contacting ur nearest service center
Posted on Jul 04, 2010
Viewsonic VA1912w sound fix
Please rephrase your question. Your subject title is vague. A qualified answer cannot be provided based on what is stated. Or contact ViewSonic technical support for assistance.
May 04, 2014 | ViewSonic VA1912w 19" LCD Monitor
Hi i have a view sonic va1912w lcd monitor but i cant get it to its true resolution that is 1440*900 i get only 1280*1024 plz solve this issue
You probably need to install the drivers for this monitor. Try going here: http://www.viewsonic.com/support/downloads/drivers/?prod_name=VA1912w
and download and install the drivers for your OS (Vista, Windows 7, etc). You may need to then restart your machine, but this should hopefully help with your issues.
Sep 01, 2011 | ViewSonic VA1912w 19" LCD Monitor
Viewsonic va1912w monitor no display cables ok computor ok green light flashes
Jul 04, 2010 | ViewSonic VA1912w 19" LCD Monitor
NOT ABLE TO VEIW THE SCREEN, GREEN LIGHT ON MONITOR IS BLINKING
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder jopints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 08, 2010 | ViewSonic VA1912w 19" LCD Monitor
The screen is black but if you look hard you can see the background very lightly
Hi, your monitor's backlight is burned out or malfunctioning. The LCD monitor consists of two major parts - the LCD panel where images are created, and the backlight which forces light to pass through the LCD panel so you can see things. Your backlight is out. Viewsonic has great warranty support and service. You should contact them, provide them with the serial number, and they'll probably repair it under warranty for you. This is a hardware malfunction, so it needs to be repaired.
May 15, 2009 | ViewSonic VA1912w 19" LCD Monitor
Viewsonic VA720 monitor has small blinking light, won't turn on
Debi
May 03, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Flat monitor doesnt boot
I think the problem is with the capacitor....you need to change the capacitor...
Mar 24, 2009 | ViewSonic VA1912w 19" LCD Monitor
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Feb 18, 2009 | ViewSonic VA1912w 19" LCD Monitor
VGA Problem
when u start sys press F8 KEY then go to safe mode and change resolution settings to 1024x768 or more
thern restart .
Mar 31, 2008 | ViewSonic VA1912w 19" LCD Monitor
ViewSonic VA1912w 19" LCD Monitor Logo
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
