Thunder bird e-mail error 'Sending of message failed. Unable to open the temporary file C:\Users\JOHNW_~1\AppData\Local\Temp\nsmail-3.tmp. Check your 'Temporary Directory' setting.
  • 121 Answers
SOURCE: installed spysweeper and i keep
you can use the other programs and they are free to download.. here is the site: http://www.download.com/
i would try to install one of these programs, then run a full sweep to see if any of the spyware that is already on your pc will be removed.. this could be why you are having problems installing spysweeper.. i figured since you probably paid for it you would like to use it versus the free downloads.. adaware is my suggestion between the two.. once you sweep your pc, shut it down and start it up again.. then retry spysweeper.. hope this helps..
Posted on Mar 14, 2008
clark_styx
  • 282 Answers
SOURCE: 1. Error loading C:\PROGRA~1\MYWEBS~1\bar\1.bin\M3PLUGIN.DLL 2. Can
try to run virus scan first,download malwarebtes
run it for a while and remove..
Posted on Oct 09, 2008
SOURCE: Upgrade for settlers downloads but won't run
I had this issue as well. Download the patch directly from the website, and run it locally. Afterwards the updater won't find a newer patch, and goes directly to the game. I don't know whether this will break again once a new patch is released, but you should be able to manually install it again at that time. Patches can be found at http://www.ubi.com/US/default.aspx under support --> patches.
This link may take you directly to the right place.
http://www.ubi.com/US/Games/Info.aspx?pId=5923&tab=download&dcId=63
Posted on Jan 01, 2010
  • 22 Answers
SOURCE: UNABLE TO DOWNLOAD ITUNES TO MY unable to download
It is required to clear the temporary folder before downloading the Software. For this click 'Start' button then select 'Run' (you can open 'Run' by press and hold Windows button on the keyboard and then pressing alphabet key 'R'). Type '%temp%' inside the Run window, and you will get a folder opened. Delete all the files in the folder and close it. Now try to download the Software, it will work.
All the best.
Posted on Sep 21, 2010
bronk50
  • 27725 Answers
SOURCE: I keep getting an error message that says, "Microsoft Outlook. Cannot open the Outlook Window. The set of folders cannot be opened. Errors have been detected in the file C:\Users\my name\AppData\Loc
To resolve this problem, use the following steps. On the Start menu click Run. In the Run dialog box, type the following command:
Outlook.exe /resetnavpane
Note:
There is a space between "Outlook.exe" and "/resetnavpane" Click OK. Note If you are using Windows Vista or Windows 7, you may not see Run on the Start menu. In this situation, use the following steps to locate the Run option. On the Start menu click All Programs. Click Accessories. Click Run.
Posted on Apr 15, 2013
Problems installing Neat Receipts
You need to install Microsoft SQL Server Compact 3.5 Service Pack 2 from MS web site:
http://www.microsoft.com/en-us/download/details.aspx?id=5783
Steps:
1. Download installation package from above link and save them to the desktop or other folder
2. Start that .exe and unpack to some folder on your PC (or that same folder)3. Open that folder and run BOTH installations for Windoxs x64 PC - first start:
SSCERuntime_x86-ENU.msi and then
SSCERuntime_x64-ENU.msi
4. This would install necessary SW and then you could re-insert Neat CD to start the installation which would proceed now.
Mar 06, 2012 | NEAT Receipts Mobile Scanner
Ho to fix problem name blue screen
can you post the actual blue screen code?
Nov 17, 2011 | HP Pavilion dv9000t Notebook
Hello. I have Dell notebook-inspiron 1525. When I started my notebook, suddenly it goes for shutdown within 2-3 minutes. After restarting, it shows message mention below.Problem signature Problem Event...
Try this one first.
Boot to F8 then select Last Known Good Configuration.
If fail boot back to F8 then Safe Mode.
In safe mode try to do system restore from the time system was working fine.
After that everything will be fine.
Mar 29, 2011 | Dell Inspiron 1525 Notebook
Error 1606
Re: Please Help Unable to Install TIVO Desktop -- Error 1606. Could not access network location %APPDATA%\
The response to "Echo %appadata%" should be
C:\Users\UserName\AppData\Roaming
A space in the user name shouldn't be a problem, but creating a new user may fix the problem because it will create the account with default registry settings which will hopefully have the missing %appdata% information.
If you want to check on this before creating the new user, just for curiosity's sake, check the following Registry key:
HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders and check the value for AppData in the right hand pane. If it's missing, then that would explain the problem. It should be as listed above, substituting the UserName with the folder name for the user under Users.
Also check the key
HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
The value of this key should be
%USERPROFILE%\AppData\Roaming
More keys to check:
HKCU\Volatile Environement (1)
HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders (2)
HKU\Sxxxxx\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders (2)
HKU\Sxxxxx\Volatile Environement (1)
The values in (1) should have the full path spelled out, the values in (2) should use the %USERPROFILE% variable in the path. If the value under HKU\.DEFAULT is missing or bad, then creating a new user probably won't work either. If that value is missing, then I would recommend a clean reinstall of Windows because there is no telling what else is messed up also.
The value for AppData in the registry key HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
is C:\Users\Murray Admin\AppData\Roaming
In the key the key
The value for AppData is %APPDATA%
The value for Local AppData is %USERPROFILE%\AppData\Local
In HKCU\Volatile Environement (1)
The value for HOMEPATH is \Users\Murray Admin
In HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders (2)
The value for AppData is %USERPROFILE%\AppData\Roaming (all the keys have the %USERPROFILE%\ )
In HKU\Sxxxxx\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders (2)
The value in one of the \Sxxxxx\Software\Microsoft\Windows\CurrentVersion\Explorer\UserShell Folders keys for AppData is
%APPDATA% (Missing the %USERPROFILE%\ ) --- Could this be the problem???
All the other values within do contain %USERPROFILE%\
Do you think editing the key, adding %USERPROFILE%\ would do the trick? If so, it would be alot eaiser then
a re-install. There is not much junk on it as this pc is only about a month and a half old. The other machine
is about six months old. Both are from the same manufacturer (Compaq) but different models.
Also - Using the set command the value returned for %APPDATA% are:
Microsoft Windows [Version 6.0.6001]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Murray Admin>set
TEMP=C:\Users\MURRAY~1\AppData\Local\Temp
TMP=C:\Users\MURRAY~1\AppData\Local\Temp
Jan 20, 2010 | HP Computers & Internet
Using "Vista Ultimate", The problem is of "automatic shutdown" and error report is as follows:- Problem signature: Problem Event Name: BlueScreen OS Version: 6.0.6000.2.0.0.256.1 Locale ID: 1033 Additional...
Hello and thank you for using Fixya's services.
First, I would recommend erasing all of your temporary files. This can be done by opening Internet Explorer, click on tools and choose Internet options. Click on the tab labeled, general and delete browsing history and cookies, offline files, temp. pages, etc.
There is a file, more than likely a hijacker txt file in the temporary pages making the system shut down.
After this is complete, reboot and run a full scan to get rid of all mal-ware and/or trojans. Delete all unnecessary toolbars, etc. I recommend kaspersky and you can get the free trial from their website.
* Tip: Never have two anti-viruses on the same machine.
Lastly, upgrade Windows to service pack 2 as I see your computer hasn't automatically downloaded even service pack 1. This is very important and will keep the computer safe from hackers, etc. You can do this by going to start button and type in windows update on the search bar. This will bring up the auto updates and allow you to run a manual upgrade and install.
Please let me know if you have any questions. Glad to help!
Nov 28, 2009 | Computers & Internet
Aug 02, 2009 | Ubi Soft Entertainment The Settlers: Rise...
Crc failed in Enterprise.ww\enterww.cab
Based on my experience there are many reasons that this issue may occur. I
suggest you try the following suggestions:
* Suggestion 1: Clear Temp folders
1. Click Start>Programs>Accessories>Disk Cleanup
2. Clear your Temporary Internet files and temp files.
3. Restart the PC.
4. Copy your Office 2007 files and folders to a local folder.
5. Double click on the Setup.exe to start the install process.
* Suggestion 2: Check the Environment Variables
I remember I have resolved some similar issues that the users report Office
2007 has failed to install. I have figured out this is caused by the wrong
configuration of the user variables. To check it, please follow the steps
below:
1. Right click on Computer, and choose Properties
2. In the Tasks list that appears on the left, click Advanced system
settings.
3. Click Advanced tab, click Environment Variables.
4. Under User variables for user name, check if TEMP is configured as the
following value: "%USERPROFILE%\AppData\Local\Temp"
* Suggestion 3: Install under Vista safe mode
Please try to install Office 2007 under Vista safe mode:
1. Restart Windows.
2. At the boot sequence, long press F8 key to invoke startup menu.
3. Choose Safe Mode with network connection on the menu and press Enter.
4. After Windows starts in this mode, install Office 2007 again and see the
result.
Feb 04, 2009 | Microsoft Office Professional 2007 Full...
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
