Question about Sony KP-57WS500 57" Rear Projection Television
Too much red unable to adj it out
Picture is saturated in red...sometime. when picture should be black(in between scenes or before dvd starts) screen is totaly red with thin red arcing lines. can not adjust it out with remote control adjustment
  • 1 more comment
  • moeman560 Oct 08, 2007
    tv is a sony model KP-57WV600
  • moeman560 Oct 18, 2007
    in regard to dry solder joint, am I looking for a physical loose connection??
  • moeman560 Oct 19, 2007
    had a repairman stop by charged me 25.00 to tell me the red gun is bad will cost 1,200 to fix never even looked inside. sounds like bull**** to me any suggs.
    Problem Solver:
  • 5 Answers
I got this TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Posted on Jan 15, 2008
I am having the same issue only with blue lines. I was told to get the voltage adjusted. Can you tell me how to do this? Thanks in advance!
Posted on Dec 31, 2007
    Genius:
  • 1,694 Answers
Might be able to mitigate problem temporarily by adjusting
the red screen control......but I tend to agree - red CRT bad
Replacement cost 600-700.00............T.
Posted on Oct 25, 2007
  • Vista Electronics Oct 25, 2007
    PS. Be glad to describe how to adjust red screen voltage..
        Let me know.......T.
  • 4,889 Answers
This problem is apparently occurs in 2 cases 1)Exposure of the screen to stron magnetic fields This can be solved by degaussing(if this feature is there in your tv)Otherwise u can drop into a seervice center and it will be fixed in a jiffy. 2)Due to the presence of a dry solder(Loose contact) If you think you can try opening your tv and attempt to spot it. Otherwise just drop into the nearest service center..U can locate by clicking on the link below http://www.sony.net/SonyInfo/Support/
Posted on Oct 08, 2007
  • 1 more comment
  • eagle338
    eagle338 Oct 18, 2007
    Yes..
  • eagle338
    let me know if it worked..
  • eagle338
    eagle338 Oct 19, 2007
    He is trying to rip your pocket..!
    There seems to be a problem with the crt driver boards, or a bad
    capacitor in the sweep power supply that supplys the screen voltage to
    those boards, or a problem with the RGB section of the video jungle IC
    or ita associated componets. This is a hard call with out first getting
    a print(schematic diagram) and while its cold, look at the voltages and
    waveforms. Not a job for the consumer, but a trained tech should be
    able to handle this..I suggest you do not go to your local service man..Give it for repair in a sony service center..No way it wil cost you that much..
SOURCE:
Television is a Tosiba DLP 72HM195
your tv needs a y-load board its like a grafix card as computers have due to overheating the board components are affected this is a manufacturing fault it tends to happen with samsung aswell
Feb 22, 2012 | Toshiba 72HM195 72" HDTV
Brand new 47" "Edge Lit" LED, model MV4(Cant
I believe there may be another setting, it has to do with auto contrast which can make the TV seems to have high contrast ratio but sometime it does not work right, espically on the scene with dark sky with stars, someitme it will will reduce the brightness to make black real black and you can loger see the stars in the scene. I forget the name of this setting, it may be in the user manual. Do you see that in TV HD mode in other movies with a lot of dark scenes?
Dec 01, 2010 | Televison & Video
Brightness and dark scene problems
you need to check your picture menu to verify you contrast is at max and brightness level is at approx 55% . if good , call for service and have htem check the setting on the screen controls. sometime they drift with heat, cold and age. when this happens, they usually have to reset the grey scale (black and white content) of the picture. Beyond that could be a defective red crt drive pcb or red crt or small signal panel.
Apr 20, 2010 | Philips 55PW9363 55" Rear Projection...
Red arching lines showing up on screen promident when a dark background is present
Red picture tube needs screen voltage adjust. Open fornt or back of TV and look for a black square looking box with adjustment knobs. Look for red screen adj and slowly turn rt or lft until lines just disappear. If screen goes too bright tv will shut down, just turn back on again and retry
Dec 04, 2009 | Sony Televison & Video
Picture has a red "haze"
the color in my tv is a little faded when theres dark scenes on cant really see picture. Red and Blue really fade into picture
Feb 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
Black box covering one-half of TV screen
Try turning off the text box function of the closed captioning.
Aug 02, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
DVD quits while watching a movie
Have you tried cleaning your lens?
If so your dvd drive may be going bad
Apr 08, 2008 | Bose (321GS) System
Black scene frame
i think you have changed the screen into other mode so that you are unable to see the recording picture there will be a switch to change the mode at the back of the cam or at the right of the cam.
Mar 25, 2008 | Sony Handycam DCR-DVD100 DVD Camcorder
Brightness of picture
If you feel good about opening your set then you can try this: Look for the flyback (high voltage) transformer, with the thick red wire which goes to the top of the picture tube. There are 2 controls on the flyback transformer, focus (top) and screen (bottom)Turn the brightness and contrast all the way down and then increase the screen control until you see retrace lines, and then back it down until those lines just vanish. Return the brightness and contrast to normal and adjust the focus control, if necessary, for a nice sharp picture. Let me know if that brings your brightness back.
Aug 21, 2007 | JVC AV-27D104 27" TV
Red spot when screen is black
Your light engine will need to be replaced as you have a LCD panel failure. Here is the link to the part number for the model 50V500 if you have the 50V500A it has a different part number. http://www.partstore.com/ProductDetail.aspx?ProductSKU=8286849&ProductType=PART&ModelID=374014
Mar 14, 2007 | Hitachi 50VX500 Television
Sony KP-57WS500 57" Rear Projection Television Logo
535 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
