Question about Honeywell Programmable Thermostat Heater
Honeywell thermostat lr95329 class 2 wiring diagram
Heater won't stay on
SOURCE: Honeywell T86A3006 24V Class 2 Round thermostat 8020
The honeywell tradeline thermostat would work as a direct replacement (no mercury in the new ones), however if your using just heaters and no cooling system off of it, you could Heat only thermostat from honeywell that would replace your unit as well. Both at available at Ace Hardware with the heat only unity being roughly 7 dollars cheaper.
Posted on Jan 23, 2008
SOURCE: Honeywell RTH230B
This my situation exactly.  Changing from a 6 wire manual round Honeywell thermostat to a 5 wire Honeywell programable.  Is there a way to maintain all functions?
Posted on Nov 25, 2008
machtcl1
  • 61 Answers
SOURCE: Thermostat Wiring: W2? E? Where to connect?
You have a heat pump. You need a thermostat for "Heat pump with Electric back-up heat". Make sure the 'stat has either an "aux" (auxilliary heat) or an "E"(Emergency heat) terminal. The wiring instructions will be provided with the thermostat.
Posted on Dec 16, 2008
SOURCE: rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
I connected the blue wire to the R and the white wire to the W on the old thermostat and shoved the new Honeywell 5-1-1 Day programmable thermostat up the first guys *** that i ran into at Canadian Tire
Thanks for your help
Posted on Dec 29, 2008
  • 252 Answers
SOURCE: my honeywell ct87K thermostat will not turn the heater on
On your thermostat - R is the power in terminal. Y is the cooling out. W is the heating out. (G is fan out). It does not matter which wire goes to R, the other should go to W - if no heat with a call, the thermostat is bad.
Posted on Apr 17, 2009
How can I connect to replace an old Electromode thermostat that has 2 black and 2 white wires?
The packaging for the most recent Honeywell thermostat I installed has a "Consumer Helpline" telephone number of 1-800-468-1502. You also might try a Google search using the model number.
Mar 14, 2016 | Honeywell Programmable Thermostat Heater
Heater won t stay lit
check gas pressure sounds like running out of gas meter might be too small
Jun 23, 2013 | Hayward Pool & Spa
The heater won't stay powered on
Locate the flame sensor (connected only to one wire) and remove it. Some people use fine sandpaper, I use WD-40 to clean it. And I do this every year at the beginning of Winter. Good luck!
Jan 22, 2013 | Heating & Cooling
Pilot light won't stay on
Dust gets inside the pilot safety during the months when it is not in use. Blow out the pilot safety without disturbing the flap. and retry.
ODS VENT FREE HEATER TUNEUP
Nov 12, 2012 | Empire ECS HearthRite HR18MN Heater
Heater does not turn on
If you have a gas hot water heater that won't stay on, check to see if pilot light is out and relight it if it is. If you have an electric hot water heater that won't stay on, then you should have an electrician check the wiring.
if you need an auto tool you can click here: chinasinoy.com
Nov 05, 2012 | 1990 Toyota Corolla
Heating & Cooling Logo
142 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
