Question about Kenmore Washing Machines
How do you display error codes on a kenmore 100.20022011
Does this model even have error codes? (I an answer to my problem for a different model that suggested looking at error codes) My washer does not complete spin or drain cycles... clothes remain soaked. Spin cycle does work sometimes when directly putting the machine in that mode but not in a full cycle. Already replaced the latch lock assembly. Machine less than 6 months old!
SOURCE: Kenmore Elite H3t washer
What a blessing to find others with the same exact problem. Had a call in to Kenmore service center and was having to wait 8 days till a repair man could show up. Service call would have been at least $110 for the man to show up at the door. After discovering this website my wife and I are proud to announce that we found two (our 2 year olds) socks and one of my wife's nursing pads clogging up the filter along with some thread and a little gunk. Cleaned it out and in 10 minutes from start to finish we were done. Ran the machine twice and find it is running just like new. Like other postings here we found that a 45 minute wash took 90 minutes because the machine never could spin out on the first try. We thought it had problems balancing out the load of wash. Now it spins out quickly and without wasting time. I think of how much extra money it cost us to run the machine like this. Also, while we were sitting in our laundry room admiring the return of our washer I took a look at our complimentary Kenmore Elite HE3t dryer. Everyone who reads this far please do the following:
1. Unscrew the bottom panel of the dryer (unplug machine first)
2. Unscrew the black metal chute that goes from the lint catcher down to the blower (two sheet metal screws) pullout and clean.
3. Unscrew entire lint catcher from inside. (5 screws total) and clean.
4. Reinstall
5. One more step to really get all the lint includes pulling the entire machine out and removing the outside vent from the base of the machine. There is a 2 foot pipe to be cleaned out that extends from the other side of the blower.
I could not believe how much lint had bypassed the lint screen and had created a wall in front of the blower. I had previously checked the vent pipe leading to the outside wall and found no buildup whatsoever so I figured everything was okay. Was I ever wrong. I had found that the dryer (which is only 4 and 1/2 years old) was now taking 59 minutes to dry at normal temp instead of
the 41 minutes to dry when we first bought the machine. After I performed this service the dryer was back to drying the clothes in 41 minutes time or even less!!! In the future I will do this service, as described above, on a yearly basis. Once again we were wasting energy because we did not do this simple maintenance.
Posted on Jun 26, 2008
SOURCE: Kenmore Front Loading Washer Slow Final Spin Cycle
I have exactky the same problem Replaced the drum and now it will not final spin, I touched nothing else.Can't figure what could be wrong,speed board too sensitive?
It worked fine before the bearing went.
Any ideas?
Posted on Aug 22, 2008
SOURCE: UL Code
Solved the unbalanced problem - open the top of the machine (press in with a flat putty knife about 3" in on the front on each side while lifting up as there are 2- 1" wide catches). Once both sides are unlatched, raise the lid then slightly lift the rear of the lid so that it fits into the curved part at the top of the hinges then open all the way - tape the lid to the top so it doesn't flap about and scotch the lid to keep it from falling back down on you. Now, look around - see all that rust?  The rust has fallen into and gotten underneath one or more of the 4 white plastic suspension "ball joints" which have probably totally dried out by now from their factory grease because of the water, bleach, and rust particles.  Having someone help you, simply lift up on one of the 4 corner suspension rods - gravity and weight is all that holds them down. The white ball will lift out of the socket and still be attached to the rod. Clean out the rust, lightly sand the "socket" with emery cloth, then slop in a fingerful of grease. I used automotive wheel bearing grease with graphite in it. Also scrub off all embedded rust on the white plastic ball. Lower that corner back into the newly cleaned and greased socket and repeat for the other 3 corners. Now when you move the tub around notice how the balls pivot in their sockets like they are supposed to. When they were dry and rusty they wouldn't move enough to allow the tub to twist like it should so it slammed around.  Now, shake your head in disgust that after only 2 years there is so much rust that you wonder if it will make it another year before falling apart, close the lid, and try another load.  That totally solved my off-balance problem where even a single handkerchief would give the UL error. It is still a finicky machine, but at least once again works like it did when new.
Posted on Jan 06, 2009
  • 20 Answers
SOURCE: washer will not spin, will not spin in any spin cycle
Your water pump is clogged
Posted on Feb 10, 2009
localwonder
  • 6784 Answers
SOURCE: Washing machine will not complete spin cycle
OK, what you are experiencing is a timer mechanism fault. the timer motor is malfunctioning. anytime you have to manually advance the timer knob, this will signal a fault within the control mech. this is easily fixed by, replacing the timer control module. i will place a link to the actual part needed to fix this issue. you can also purchase this timer on line at this site if you wish.
CLICK HERE
Posted on Jun 18, 2009
I have hitachi washing machine appear lode model SF-100JJS error p9 please tell me what is solution, ?
That is an F not a P. The codes are generic. It is a pump clog, block, or defect.
SOLVED: I am getting F09 error code - Kenmore Elite HE3 Washing ...
https://www.ifixit.com/Answers/View/47460/I+am+getting+F09+error+codeMar 20, 2011 - The F09 error is a water pump problem, either clogged pump, or pump malfunctioning, ... The Kenmore Elite HE3 is a washing machine by Kenmore. .... hi i have f9 display always when i start machine can you help with this. hitachi washing machine f9 error Google Search
May 09, 2016 | Washing Machines
Kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
I'm getting an error mssg "dr" displayed on my kenmore dryer model 84082. help!
"DR" is not a known error - please re-check and post the error code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 11, 2010 | Kenmore 67082 Electric Dryer
My kenmore model number 795.775436000 displays an error code er ff. I checked the evaporator fan and it is good. I replaced the control board and still no luck. Any thoughts?
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Oct 25, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore microwave model 63792 displays F2 error message
The F2 error code on your microwave oven is a membrane failure.
It is recommended that you replace the membrane first & if you still have problems to replace the control board.
Aug 21, 2009 | Kenmore 63792 Microwave Oven
What is the kenmore washer model # 21086 water pump failure error code
Aug 16, 2009 | Kenmore Elite 21086
I have a Kenmore model 795 77563600 refrig side
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Apr 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
C 1 error
The CL fault indicates that there was an instantaneous current spike of 26 amps at the motor windings in the washer. This could be caused by overloading the washer. It can also be caused by problems with the drive motor, thermal protector or the motor controller.
You should have been able to clear the display by pressing the STOP/CANCEL button.
If you try running the washer again and continue to get this fault code even with a small or medium load, I recommend calling a service technician to diagnose and repair the washer.
Mar 24, 2009 | Kenmore Washing Machines
Humming sound, F9 and dead
Seems like I answered this, but maybe it's a different poster.
The 721 model code means it's an LG/Goldstar-made oven and F9 indicates a problem with the inverter or magnetron.
Due to the lethal voltages involved, I do not recommend that a person without training and experience ever work on these models.
I would suggest you contact Sears for service.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 19, 2008 | Kenmore 64683 Microwave Oven
Kenmore dryer 417.84072300
Check you circuit breaker. Even if it doesn't look tripped reset it anyhow. This is a power interrupt code.
Dec 04, 2007 | Kenmore 84072 Electric Dryer
Washing Machines Logo
46 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
