Question about SanDisk Sansa E280 MP3 Player
Sansa 280 memory
Can't remove 5 gb of songs off memory any suggestions Please.
  • 626 Answers
You can format the device thru My Computer. My Computer>Device Name (e280)>Right click and select format. This will erase everything on the device. Best of Luck.
Posted on Oct 08, 2007
SOURCE:
Error message on E260 player
Same problem delete a couple of songs up to 6 mg or 10 whatever then allow to refresh then download your songs back in the music file. the sansa needs some memory to know it has the sdcard in it...
Dec 28, 2008 | SanDisk Sansa e260 MP3 Player
Sansa 280 memory probleme.
Does the device your playing it in support MicroSDHC?
If it doesn't, it will not play it on that size of a memory card. The most you can get away with using on that player is 2gb.
Dec 10, 2008 | SanDisk 2GB microSD Memory Card
Sansa 280
ok buddy...it might be problem with the storage.. try to format the player once.. now the player will be fresh... now download all the songs and try whether its working fine... if the problem continues try to contact the player manufacturer for replacement
Sep 17, 2008 | SanDisk Sansa e200 MP3 Player
My Sansa c200 says memory full
some times their is not enough space in phone memory! if you hav any pic or video in phone memory! move memory card or pc! then you can download songs! actually one songs is 3mb! check phone memory
Jun 30, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa keeps shutting off/ wont read memory disk
The issue you have described with your portable device in most cases can be resolved by formatting your device. Please follow these steps even if you have already attempted them once before.
Please note that this will remove all music from your device.
Formatting the device in Windows Media Player
1. Open Windows Media Player with your MP3 player connected to the computer
2. At the top of windows Media Player select the Sync tab at the top
3. The MP3 player should be recognized on the right hand side and say "Your Player Name"
4. Above the player name is a button that says "Format Storage Media" click this button to erase all the data from the player
5. Continue with the acknowledgement of erasing all data on disk.
Jan 17, 2008 | SanDisk Sansa e260 MP3 Player
Sansa 280 with 8 gigs
The message says it needs 6MB of space for the MUSIC DB ( the database, the artist names, etc).
You need to delete some of the recordings off of your device to free up some space.
You can manually delete the files while connected to your computer from My Computer>Device Name (e280)>MUSIC Folder.
Best of Luck.
Nov 09, 2007 | SanDisk Sansa E280 MP3 Player
Can't erase songs
THE ONLY HELP THAT I CAN GIVE YOU IS TO CALL THE COMPANY HERE IS THERE NUMBER Contact Customer Support at 1(866)SAN.DISK
Aug 11, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
A bunch of little problems!!
Hi moogle. Normally a 4GB player should hold about 1000 songs, but then again there are disclaimers from companies that it depends on the file format and the length of the songs that you download to the player. For example, an MP3 file is twice as large as a WMA file, etc. Well, granted you're downloading songs of about 3-4 minutes average length, then there may be a possibility that some corruption has taken place in the memory of the player. You may need to format the player to completely remove these corruptions. Here's how to format your E260: (1) Set your player to MSC mode by navigating its Menu as follows: Menu > Settings > USB Mode > ..select "MSC" (2) Plug your E260 to your computer (are you using Windows XP or ME?). Your Operating System should recognize the player as a "Removable Disk" and will be assigned a drive letter. (3) Right-click on the drive letter corresponding to your Sansa E260, then select "Format" (4) When the Format window appears, make sure that the file system type is set to "FAT32", and that the "Quick Format" checkbox at the bottom of the window remains un-checked. Click "Start " to begin the process and follow the on-screen prompts. Formatting the player, though, will erase all your files but will clear the player of any corruption. Make a back up if you wish before formatting. (5) Unplug your player and switch the mode back to MTP if you like. MTP is used for subscription songs while MSC is generally used for non-licensed songs (like songs from Limewire, songs ripped from CD's, etc.). (6) Transfer your songs again to the player I hope this helps. Normally this would solve the little glitches in your player. If it doesn't, leet me know... there may be another solution I could offer. Syd :)
May 08, 2007 | SanDisk Sansa e260 MP3 Player
How do i free up memory?
Delete other songs and files.
Apr 21, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
66 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
