Question about SLICK ER-700 7 e-Reader and Case Silver
How can you root an er 700-2
Root software
Need driver download for er-700
Could be a cash register, an ereader or who knows what else. Not a keyboard where you've placed your question.
There are no drivers for an erader. http://www.slickusa.com/support/downloads/ER-700.pdf
Mar 16, 2015 | Computers & Internet
How do I change the ticket title on the Sam4S ER-5115 register? We recently moved our business to a new location and using the old machine left over and don't want it to say the old cafes name on the
turn your key to PRG press 700 then sub/total then press 1(for line number) then press x/time then type in the new name. then press subtotal. press 2 for line 2 then x/time and type in your details and so on
Nov 13, 2014 | Sam4s Samsung ER-5115II Cash Register
How do I find the 4th square root of 16 on a datexx ds-700 scientific calculator??
Roots are called as follows:
square root
cube /cubic root
From 4th on, use the ordinal fifth, sixth, ... n-th
To calculate the fourth root you have two possibilities.
  1. Some calculators have the x-root key marked with an x followed by the radical symbol. See the screen capture on how to find your result.
    Usually the x-root is the SHIFTED function of the general power key that is marked ( [^], [X^y], or [Y^x] ). To use it, you inter the index of the root (the ordinal number). then you press the [SHIFT/2nd/ 2nd] [X^y] sequence and the number whose root you are calculating).
  2. Alternatively: Use the equivalence n-th Root (x)=x^(1/n), meaning that to extract the fourth root of 16, you raise 16 to the power of (1/4)
Sep 19, 2014 | DateXX DS-700 - 2 line LCD Display 224...
Hello, no recognize media expansion bay
I found a list of the needed drivers most of them have drverguide.com registration is free:
VGA
Intel 82865G Integrated Device
AUDIO
Intel 82801EB ER AC97 Audio Controller (ICH5
ICH5R) Device
NETWORK
Realtek RTL 8139 8139C
MODEM
Conexant Rockwell HSF 56k HSFi
FIREWIRE
VIA Fire II OHCI Controller VT6306
DEVICE RECEIVER
Logitech LX 700
MULTIMEDIA ENCODER
Conexant Rockwell CX23418 Single Chip MPEG 2
USB
Genesys Logic USB Hub DUB H4 USB Hub
and
Intel 82801EB ER USB2 EHCI Controller ICH5
ICH5R
WI-FI
Belkin Ralink RT2573 F5D7050 Wireless V3000
Jul 03, 2014 | Acer Aspire RC500 PC Desktop
How do I do 5th roots on the ds-700-36
Use the general power key [Y^x], [X^y] or [^] with an exponent equal to 1/5. N-th root is equivalent to ()^(1/N)
Jan 20, 2014 | DateXX DS-883 Calculator
Nth root on a ds-700-36
If you do not have an X_root key Use the general power key [Y^x], [X^y] or [^] with an exponent equal to 1/5. N-th root is equivalent to ()^(1/N)
How do i use bedmas
BEDMAS is a mnemonic device used to help you remember the order of operations in the evaluation of mathematical expressions.
B stands for Brackets OR Parentheses.
E stands for Exponent(iation)
D: division
M: multiplication
A: addition
S subtraction
I will amend the device to introduce the ROOTS, and to separate the levels of priority by --
B--ER--DM--AS
That means that raising to a power E and extracting a root R have the same priority. When these operations follow one another the order is from left to right.
Division and Multiplication have the same priority levels. When they follow one another, the order is from left to right.
How to use : RECURRENTLY
Look at the expression and locate the brackets (parentheses).
If there are many sets of parentheses start at the left and take care of the leftmost set. When inside the leftmost set of parentheses use B-ER-DM-AS again, and again until there is only one term left.
If there are embedded parentheses start from the deepest.
Let us simplify a bit.
Inside first set of bracket
Are there brackets: No
Are there Powers or Roots: yes. take care of powers and roots starting from the left until there are no more powers or roots
Are there multiplications or divisions? Yes. take care of multiplications and divisions starting from the left until there are no more divisions or multiplications.
Nov 21, 2013 | Canon F-502 Calculator
Software for Sharp XE-A201 Cash Register
You need the PC Link software for your model.
All of these manuals can be downloaded at:
http://the-checkout-tech.com/
sharp ER-1017 Service
sharp ER-1072 Service
sharp ER-1073 Service
sharp ER-1074 Service
sharp ER-1075 Service
sharp ER-1076 User Service
sharp ER-1077 Service Programming
sharp ER-1077
sharp ER-1077
sharp ER-1772 Service
sharp ER-1772s Service
sharp ER-1871 Service
sharp ER-1872 Service
sharp ER-1873 User Service
sharp ER-1875 User Service
sharp ER-1910 User Service
sharp ER-1911 User Service Programming
sharp ER-1911s User Programming
sharp ER-1920 User Service
sharp ER-1921 User(R) Service Programming
sharp ER-1921s Programming
sharp ER-1970 User Service Programming
sharp ER-2000U Service
sharp ER-2100 User Service
sharp ER-2370 Service
sharp ER-2371 User(R) Service Programming(R)
sharp ER-2385 Service
sharp ER-2386 Service
sharp ER-2386s User
sharp ER-2395 Service
sharp ER-2396 Service
sharp ER-2720 Service
sharp ER-2722 Service
sharp ER-2722A User Service
sharp ER-2742 Service
sharp ER-2742A Service
sharp ER-2770 Service
sharp ER-2782 Service
sharp ER-2782A Service
sharp ER-2905 Service
sharp ER-2908 Service
sharp ER-2910 Service Programming
sharp ER-2970 User Service
sharp ER-2975 Service
sharp ER-2980 User Service
sharp ER-2980S Service
sharp ER-3100 User Service Programming
sharp ER-3110 User Service Programming
sharp ER-3115 Service Programming
sharp ER-3120 User Service Programming
sharp ER-3550 Service
sharp ER-3600 User Service
sharp ER-3630 User Service
sharp ER-3712 User Service
sharp ER-3721 Service
sharp ER-3731 Service
sharp ER-3732 User Service
sharp ER-4100 User Service Programming(R)
sharp ER-4110 User Service Programming(R)
sharp ER-4100S Service
sharp ER-4110S Service
sharp ER-4550 Service
sharp ER-4630 User Service
sharp ER-4633 Service
sharp ER-4700 User
sharp ER-6740 Service
sharp ER-8700 Not Available, do you want to swap?
sharp ER-A150 User Service Programming
sharp ER-A160 User Service Programming
sharp ER-A170 User(R) Service Programming
sharp ER-A180 User Service Programming
sharp ER-A220 User Service Programming
sharp ER-A227G Programming
sharp ER-A250 User Service Programming
sharp ER-A310 User Service Programming
sharp ER-A320 User Programming
sharp ER-A330 User Service Programming
sharp ER-A410 User Service Programming
sharp ER-A420 User Service Programming
sharp ER-A430 User Service Programming
sharp ER-A440 User Service Programming
sharp ER-A440S Programming
sharp ER-A450 User Programming
sharp ER-A450S User Service Programming
sharp ER-A450T User Service Programming
sharp ER-A460 User Service Programming
sharp ER-A470 User Service Programming
sharp ER-A490 User(R) Service Programming
sharp ER-A510 User Service Programming
sharp ER-A510s Service
sharp ER-A520 User Service Programming
sharp ER-A530 User Service Programming
sharp ER-A550 User Service Programming
sharp ER-A550s User(R) Service
sharp ER-A570 User Service Programming
sharp ER-A610 User Service Programming
sharp ER-A650 User Service Programming
sharp ER-A650S Programming
sharp ER-A670 Not Available, do you want to swap?
sharp ER-A670S Programming
sharp ER-A750 User Service Programming
sharp ER-A770 User Service Programming
sharp ER-A770II User
sharp ER-A770M User Service
sharp ER-A771 User Service Programming
sharp ER-A850 User
sharp ER-A880 Not Available, do you want to swap?
sharp UP-3300 User Service Programming
sharp UP-3300M Service
sharp UP-3301 User Service Programming
sharp UP-600 User Service Programming
sharp UP-700 User Service Programming
sharp UP-800F User
sharp UP-810F User
sharp UP-820N User Service
sharp UP-X300 User
sharp UP-X500 User Service
sharp XE-A101 User Service Programming
sharp XE-A102 User Programming
sharp XE-A106 User
sharp XE-A110 User Service Programming
sharp XE-A120 User Service Programming
sharp XE-A130 User Service Programming
sharp XE-A201 User Service Programming
sharp XE-A202 User Service Programming
sharp XE-A203 User Programming
sharp XE-A206 User
sharp XE-A20S User Programming
sharp XE-A212 User Service Programming
sharp XE-A213 User Programming
sharp XE-A301 User Service Programming
sharp XE-A302 User Programming
sharp XE-A303 ? Programming
sharp XE-A401 User Programming
sharp XE-A402 User
sharp XE-A406 User
sharp XE-A40S User Programming
sharp XE-A505 User Programming
Dec 30, 2009 | Sharp XE-A402 Electronic Cash Register
Toestel werkt niet blauw scherm geef error code 5f08 en 5e02
1 van de mogelijke oplossingen is dat er vuil in de binnenkant van de lens zit. Als dat het probleem is, is de oplossing de camera op te starten met de lens naar boven.
Andere oplossingen kan bv update van de software via de olympus software
Aug 21, 2009 | Olympus Stylus 700 / 700 Digital Camera
SLICK ER-700 7 e-Reader and Case Silver Logo
32 people viewed this question
Top SLICK Computers & Internet Experts
David Payne
David Payne
Are you a SLICK Computer and Internet Expert? Answer questions, earn points and help others
