Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer duet sport wfw8300sw05 door won't unlock
Door sometimes won't unlock you can run it thru rinse and spin cycle and it still sometimes open after two or three tries doesn't seem to have any water in tub though
SOURCE: Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Posted on Mar 01, 2009
richardsimpl
  • 230 Answers
SOURCE: Whirlpool washer doesn't unlock the door at the
Hi There
I have found this for you to read. it's door unlock error. Hope this helpful and let me know how it goes.
F/dU Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you for writing to fix ya.
Best Regards Richard
Posted on Dec 29, 2009
blueextc3221
  • 15935 Answers
SOURCE: My whirlpool will not spin or drain?
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!$!$!$
Posted on Sep 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a Whirlpool Duet Sport (Model #
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$#$#
richroth
  • 9472 Answers
SOURCE: Hi. My Whirlpool Duet
The pump on your washer is apparently not working. It should have pumped the water out when the FL was displayed. You should schedule service and let a technician diagnose and repair the washer.
Flood Condition F L "FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed. With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
Posted on Mar 21, 2011
Door won't open on front load washer
How to Unlock a Whirlpool Duet Washing Machine ' Home ...
homeguides.sfgate.com > Mortgages > Mortgage Options
If you must manually unlock the washer door after each wash cycle your drain ... to Change a Water Inlet Valve for a Whirlpool Duet Front-Loading Washing Machine ...Causes and Repair for a Whirlpool Washing Machine That Won't Spin or ...
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ..... Front Load Washer Repair - Not Draining or Spinning - How to Unclog ... Washing Machine Repair - Replacing the Door Bellow (Whirlpool Part
Nov 05, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
Why would a whirlpool duet sport model number WFW8300SW05 starts fine stops during cycle. No error codes door locked red light on water in machine.
you have a plugged or partial plugged drain pump for sure. maybe there is a 20 stuck in it this time! easy to find just follow the drain hose back and you will find your pump.
also could be the cycle your using has a bad area in timing cct. check a different cycle like the delicate cycle and that will confirm pump or cycle
Jun 10, 2014 | Washing Machines
Whirlpool Duet washer does not indicate end of cycle and unlock door
Most times this problem can be caused by a blocked tube to the pressure switch,..
Mar 03, 2014 | Whirlpool Washing Machines
I have a Whirlpool Duet Sport (model #WFW8400TW03) that shuts down when I press start. There are no error codes and the last cycle ran with no issues. The door is shut and seems secure. I can find nothing...
I had the same problem. My control lock was on without the status light on. To unlock the controls I Selected and held END OF CYCLE SIGNAL button for at least 3 seconds. The lock/unlock control status light never indicated the locked position, yet my washer now works. NOTE: Select and hold END OF CYCLE SIGNAL button for 3 seconds to toggle between lock and unlock.
May 18, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Mar 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Fron Load washer. Can not unlock door.
There is a manual way to unlock door. I copyed this from the tech sheet.
Manually Unlocking the
Door Lock System
1. Unplug the power cord from
the outlet.
2. Remove the lower kick panel.
3. Reach up along the inside of
the front and locate the bottom
of the door switch/lock unit.
4. Located on the bottom of the
door switch/lock unit is a
tear-drop shaped tab.
5. Gently pull the tab down about
a ¼” or until a click is heard.
6. The door may be opened.
Also there is a test procedure you can run to check the door lock actuator.
DIAGNOSTIC TEST
The washer must be empty and
the control must be in the OFF
state before pressing the
touchpad sequence to start the
test.
Starting the Test Mode
 Close the door.
 Push CONTROL/ON (if present on
this model).
 Select the DRAIN/SPIN cycle.
 Select NO SPIN by pressing the
SPIN SPEED touchpad.
 Push PREWASH OPTION four
times
within five seconds. (If
PREWASH OPTION is not present
on this model, press RINSE HOLD
four times within five seconds.)
C:00 will light up on the display.
Hope this helps.
Dec 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet won't run
The trouble could be with the door interlock. When the clothes were jammed in the door it could have caused the door latch to put strain on the interlock.
Oct 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
