Question about Ricoh Aficio AP410N Laser Printer
Open duplex cover - Ricoh Aficio AP410N Laser Printer
    New Friend:
  • 63 Answers
At the back of the machine
Posted on Dec 01, 2013
Rear cover jammed
Hi madeleine,
1.Press the cover release button and then open the front cover.
2.Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3.Open the back cover.
4.Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
5.Using both hands, gently pull the jammed paper out of the fuser unit.
6.Put the drum unit and toner cartridge assembly back in the printer (press firmly).
Fully close the front and back covers.
Pull the duplex tray completely out of the printer.
7.Pull the the jammed paper out of the printer or the duplex tray.
8.Put the duplex tray back in the printer.
9. Make sure that the Back Cover LED and the Paper LED are off and then, the Status LED lights green.
Still having Problem Then follow Us For
Brother Printer Support
Jan 29, 2014 | Brother MFC-5460CN All-In-One InkJet...
Datacard printer SP75 plus error code error DM-00762 (Duplex Jam)
Open the duplex module cover at the back of the printer (1).
Release any cards stuck in the module (2). Make sure that the duplex
mechanism can move freely in the direction shown
For more help visit cbrtechsolutions
Jun 20, 2013 | Office Equipment & Supplies
Give me minolta sp4000 code 0 d 50
The C0d50 code Duplex unit drive motor failure to turn.Turn ON the copier,open and close the front cover,pull out the duplex tray,clean the rollers alignement the belt.
Enter in the service mode press : STOP - 0 - STOP - 1,select F code history open and close the front cover,press Exit,Exit.
Jan 04, 2013 | Minolta Office Equipment & Supplies
My Dell MFP 1815dn has a paper Jam 2. I removed the toner cartridge and pulled the paper out, before I realized that I needed to open the back. I believe I thought I got the paper out, but the printer is...
After a paper jam occurs in the rear cover of a Dell Laser Multi-Function Printer 1815N, the printer will not resume when the jammed paper is removed. This is the normal behavior of the printer as there is no sensor on the rear cover of this printer.
To open the back cover and remove any stuck paper, perform the following steps:
  1. Open and close the front cover.
    The jammed paper may automatically exit the printer. If the paper does not exit, go to the next step.
  2. Gently pull the paper out of the output tray.
  3. If you cannot see the paper in the output tray or the paper does not move when pulled, open the rear cover.
  4. Skip to step 9. If you do not see the paper, go to the next step.If you see the jammed paper, push the two blue pressure levers up and remove the paper.
  5. Release the blue strap, the rear cover stopper, and fully open the rear cover.
  6. Unfold the duplex guide fully.
  7. While pushing the fuser lever to the right, open the fuser door. NOTICE: Make sure to unfold the duplex guide before opening the fuser door, or the fuser door may be damaged.
  8. Pull the jammed paper out.
  9. Return the levers, fuser door, rear cover stopper, and duplex guide to their original position.
  10. Close the rear cover.
  11. Open and close the front cover.
    Printing automatically resumes.
Jun 24, 2011 | Dell 1815dn All-In-One Laser Printer
Toshiba e studio 250 close duplex unit message
Dear, open the duplex cover, at right corner inner side of duplex cover,there is a micro switch which is not getting pressed,see weather duplex cover is completely closing,If copying is going on see the duplex cover is slightly getting open,if so press the duplex cover while copying is don, for confirmation that switch is not activated.
Regards
Mahaboob Basha.T
Bellary
Karnataka
India
Mar 27, 2011 | Toshiba E-Studio167 Copier
The photo copier is saying close the duplexer cover what is this?
The duplexer on this model is the "box" attached to the right side of the copier. There are 2 doors or covers on it including the whole unit opening up. I would check everything on this right side unit including the door on the copier that is exposed once you open the duplex unit away from the machine. In any case the area you need to focus on is the right side of the machine.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 21, 2010 | Toshiba e-Studio 350 Copier
I have the Dell laser printer 3000cn. The printer powers on and everything but I can not do anything because it keeps asking me to close the reg cover. ther reg cover and all the other covers on the...
Dell 3000cn Color Laser has a duplex. If you face the printer on the top right of the duplex there is a button to release the duplex and it folds back. The reg cover is a door on the back of the printer that is covered by the duplex, try opening again, I know you have done this, maybe even wiggle it a little see if it registers as closed.
Also check to see if any dust or paper pieces maybe be jammed in there.
Nov 02, 2010 | Dell 3000cn Laser Printer
Where is the duplexer cover
In an e-Studio 650 the duplexer is located under the fuser/transport belt tray inside the machine. If you open the front cover, turn the blue lever clockwise and pull that tray out you can then open the duplexer by pushing down on the blue tab that sticks out the bottom on the tray.
Sep 13, 2010 | Toshiba E-STUDIO 650 Copier
1st side cover is open
Hello sir; Are you using duplex unit, check your duplex unit.
Oct 13, 2009 | Konica Minolta Office Equipment & Supplies
Paper Jam Error on Dell 3100cn Laser Printer
Push the side button and open the front cover
Pull out the jammed paper from the duplexer. If jammed paper cannot be found, go to the next step.
Pull up on the belt release levers and rotate the belt unit up
Remove the jammed paper and close the belt unit
Close the front cover
Jan 03, 2009 | Dell 3100cn Laser Printer
Ricoh Aficio AP410N Laser Printer Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
