Question about Craftsman Snow Blower / Snowblower Bottom Cover :
Snowblower will not start
I can not get it to start even with electric stsrter, it will kick in but it will not start
  • messenger101 Dec 04, 2013
    Clean the sparkplug then spray some WD40 into carburetor for about a second and try to start it. If it doesn't start or sound like it might start spray again.
    New Friend:
    Problem Solver:
  • 8 Answers
Check plugs or clogged filter
Posted on Nov 21, 2013
How to fix a electric start on a Craftsman snowblower
it needs a new starter. also probably needs the carb cleaned out
Mar 14, 2018 | Craftsman Garden
My snowblower isn't starting
If it's the starter that makes a humming noise then you need to check the starter out. the gears could be stripped or even a tooth missing so it won't grab the fly wheel. Try pulling the start rope and see if that makes a difference. My Craftsman 8 horse has a recoil starter as well and I quite often use it as well. I don't always use the electric start.
Jan 10, 2016 | Craftsman Snow Blower / Snowblower Bottom...
Yardworks snow blower
Leaks are normally from bad seals or ones put on engine wrong. Many snow blowers leak oil, very common. Electric start needs to be taken apart. Rust is problem most likely. When you engage the starter it kicks out the gear to turn over engine. Carefully remove the starter from engine, try to start starter an if the pinion gear does not kick out from starter disassembly it an try to clean rust away from action. Dont break wires around electric motor careful about getting dirt an rust in winding. Try to lube spring an moving parts around gear. One other thing it could be a sheared off gear on starter also.
Mar 22, 2014 | Tecumseh Garden
Electric starter will not engage when trying to start snowblower
A common problem with snowblower starters. Rust gets all around the kick out pinion gear. When you apply power the throw out gear spring or mechanism is rusted an will not operate. Take it off engine an check for broken teeth as well. Most often is rust on starter clean if you can an lube but usually there is no fix
Jan 31, 2014 | Garden
Craftsman snowblower will not kick over
Old gas? Did you pull out the spark plug and see if you have a spark? If the gas is old, drain the tank and line to the carburator, then put in fresh gas. Never put it up for the summer with gas in it. Run it until the engines runs out of fuel, then put it away.
If there's no spark, then you have a coil issue.
Nov 21, 2013 | Craftsman Snow Blower / Snowblower Bottom...
Tecumseh 8hp snowblower engine kicks back hard enough to break plastic handle. I checked the key in flywheel ,I cleaned the carb,checked the flywheel, andcleaned magnets and coil pick up. I tried to start...
surging when running is most likely normal ,they have a governer that control's the carb & rpm so it wont over rev. It has a paddle near the fly wheel to pick up wind from it when running hooked to the carb with a small lever and held stable by a spring. Check to see if the spring is too tight or sloppy. 8 hp is a pretty big motor and a kick back is not really un expected. But a plastic handle is kinda cheesy, a rubber or a wooden handle would be better.Good thing you have electric start!
Oct 08, 2013 | Garden
Snowblower slower/no blowing force.
Electric motor may have a shorted winding, better would be the belt is slipping...... Sparks tell other wise.....
Feb 10, 2010 | Kitchen Appliances - Others
Craftsman Snow Blower / Snowblower Bottom Cover : Logo
168 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
