Question about Craftsman Snow Blower / Snowblower Bottom Cover :
Craftsman snowblower will not kick over
It will kick in but it will not start even when i use the electric starter
    Scholar:
  • 155 Answers
Old gas? Did you pull out the spark plug and see if you have a spark? If the gas is old, drain the tank and line to the carburator, then put in fresh gas. Never put it up for the summer with gas in it. Run it until the engines runs out of fuel, then put it away.
If there's no spark, then you have a coil issue.
Posted on Nov 21, 2013
My snowblower isn't starting
If it's the starter that makes a humming noise then you need to check the starter out. the gears could be stripped or even a tooth missing so it won't grab the fly wheel. Try pulling the start rope and see if that makes a difference. My Craftsman 8 horse has a recoil starter as well and I quite often use it as well. I don't always use the electric start.
Jan 10, 2016 | Craftsman Snow Blower / Snowblower Bottom...
Brand new snowblower. Engine will not start
Stuck? you mean if you try to use the pull starter the engine will not let you pull the cord out?
Will it not start OR is the engine frozen. help us with your description
Take the Spark Plug out and see if that helps it turn over. Maybe the float in the Carburetor is stuck open and the cylinder filled with gas Causing Hydrolock.
Dec 19, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Does 4-stroke and 4-cycle mean the same thing?
yes ... intake, compression, power, exhaust .... vs 2 cycle which mixes them down to two.
Mar 30, 2015 | MTD PRODUCTS INC Craftsman 21" 179cc*...
How do I replace 590787 rewind starter on craftsman snowblower?
ARE YOU REPLACING WHOLE THING OR JUST THE ROPE?
if replacing whole thing just unbolt the 4 nuts
Oct 17, 2014 | Garden
Yardworks snow blower
Leaks are normally from bad seals or ones put on engine wrong. Many snow blowers leak oil, very common. Electric start needs to be taken apart. Rust is problem most likely. When you engage the starter it kicks out the gear to turn over engine. Carefully remove the starter from engine, try to start starter an if the pinion gear does not kick out from starter disassembly it an try to clean rust away from action. Dont break wires around electric motor careful about getting dirt an rust in winding. Try to lube spring an moving parts around gear. One other thing it could be a sheared off gear on starter also.
Mar 22, 2014 | Tecumseh Garden
Craftsman snowblower won't start
give me more information does it pull by hand or starter ?is ther some thing stuck in the drive gear ?or is it the ring gear turn it by HAnd and see if ya can go backwards with it
Feb 04, 2014 | Craftsman Snow Blower / Snowblower Bottom...
Electric starter will not engage when trying to start snowblower
A common problem with snowblower starters. Rust gets all around the kick out pinion gear. When you apply power the throw out gear spring or mechanism is rusted an will not operate. Take it off engine an check for broken teeth as well. Most often is rust on starter clean if you can an lube but usually there is no fix
Jan 31, 2014 | Garden
Craftsman snowblower Model 536885214 plug in electric start, started, ran few minutes, now turns over but wont start ?
My 8 horse has an adjustment screw on the carburetor Turn it out a little at a time till it keeps running Just don't over do it If you turn out too far you will flood it.
Dec 26, 2012 | Craftsman Snow Blower / Snowblower Bottom...
Craftsman Snow Blower / Snowblower Bottom Cover : Logo
160 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
