Question about Logitech Computers & Internet
Compatibility Patch for using my ProCam C910 M/N:Y-00017 isn't available a/o 11/14/13. Now?
My last call to Logitech on 11/14/2013: 'Not available and don't know when it will be.' DUH!
I have a Dell Logitech wireless keyboard that has recently quit working although the mouse is working fine. I have replaced the batteries to no avail. what is the next step?j
If you've replaced the batteries and it still isn't working, your last hope is to see if the keyboard has a reset or connect button on it. Press this (and the one on the dongle if there is one) and it should reset the connection. If not, you're going to need to buy a new keyboard i'm afraid, as this one is kaput.
Thanks
Moza805
Aug 31, 2011 | Logitech Deluxe Keyboard
'No driver found' for my Logitech QuickCam Chat? Ok, I have the basic QuickCam Chat Camera. It looks like this: http://pics.unitedsale.info/img001/Logit? When I install the camera, it says that it did not...
A driver is a computer program used to run a device or hardware.
You can download the Logitech software bundle from here
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
Browse the photo gallery and click on your pic to move to the support page for your model
Click the 'download' link to what OS Logitech support for your cam
Older webcams will not have a windows 7 driver but you may be able to download the bundle and run it in Compatibility Mode
If no driver is available try using the older OS software in Compatibility Mode
Right click on the webcam icon on your desktop or the webcam file from 'All Programs' - select 'Properties'
Select the 'Compatibility' tab
Select 'Compatibility Mode'
Use the dropbox to show the OS
Click OK
Restart your computer
Jun 23, 2010 | Logitech QuickCam® Chat Web Cam
Driver for logitech quick cam 5.2 for windows 7
You can get software from the logitech support website.
Browse the webcam picture gallery and click on your model to access support for that product.
If you have an older model look for the link at the bottom right hand side of the page -"Still can't find your product"
If no driver is available try using older OS software in Compatibility Mode
Right click on the webcam icon on your desktop - select 'Properties' > Compatibility tab > Compatibility Mode > OS > OK
Jun 02, 2010 | Logitech Webcam
Medieval lords not running
Hello wilsonpaul74
As far as I know, there isn't a patch for Windows 7. Have you tried running it in compatibility mode? There are two ways to do this:
OPTION 1 - TROUBLESHOOT COMPATIBILITY
1. Right click on the programs shortcut, .EXE file, or installation program, and click on Troubleshoot compatibility. N.B. You will not have the Troubleshoot compatibility option available for pinned items in the Start Menu or on the Task Bar.
2. The wizard will now give you a list of options to choose from. Try each individual option, following the on-screen instructions.
If this doesn't work, you can try the following option.
OPTION 2 - THROUGH THE PROPERTIES PAGE
1. Right click on the programs shortcut, .EXE file, or installation program.
2. Click on Properties.
3. Click on the Compatibility tab.
4. Check the Run this program in compatibility mode for box.
5. Click on the drop-down menu arrow, and select which version of Windows the game was made for. N.B. Always pick the latest Windows version the game was made for a better chance of it running properly.
I hope this helps. If you require further assistance, please don't hesitate to ask.
ajblaj
Apr 28, 2010 | Monte Cristo Medieval Lords for Windows
The software that I have for my cam won't work with Windows Vista is there any updates..
Visit the logitech support website - identify your webcam - click on it and check what OS is available
If the webcam is old and Vista is not available, you can try running the webcam in compatibility mode.
Nov 01, 2009 | Logitech Webcam
Can not run on windows xp
Most programs run properly on Windows XP. The exceptions are some older games and other programs that were written specifically for an earlier version of Windows. These programs may run poorly or not at all after you first upgrade to Windows XP. You may have heard this referred to as application compatibility issues or program compatibility issues.
You should run the Program Compatibility Wizard before you try other ways of updating your programs or drivers because it identifies compatibility fixes written specifically for Windows XP.
To run the Program Compatibility Wizard:
1.Click Start, and then click Help and Support.
2.Click Fixing a problem, and then click Application and software problems.
3.Under Fix a problem click Getting older programs to run on Windows XP.
4.Read the instructions and then click the Program Compatibility Wizard.
Update Your Program or Drivers
If your program does not run correctly after testing it with the Program Compatibility Wizard, check the Web site of the program's manufacturer to see if an update or patch is available. Also, go to Microsoft Update to see if a fix is available there.
If the program is a game that uses Microsoft DirectX®, make sure that you’re using the latest version of Microsoft DirectX. In addition, check the Web site of the manufacturer of your video card or sound card to see if newer drivers are available for either of them.
I hope this helped!
if you need any further help please contact me
Please don't forget to vote.
Jun 21, 2009 | GT Interactive Bedlam for Windows, Mac
How can I change the date display battery of Polaroid ProCam?
I typed in Polaroid ProCam into google and the first result that popped up is a manual:
http://www.polaroid.com/service/userguides/photographic/procam_ug.pdf
Instructions on changing the date is on page 15.
Hope this helps : )
Mar 01, 2009 | Polaroid ProCam Film Camera
Will rrt3 work with vista
Try running the game in Compatibility mode. Right click on the game icon, go to Compatibility at the top, then check the box that says "Run in compatibility mode". Then select the compatibility mode for the reccomended operating system for the game.
Nov 21, 2008 | Take 2 Interactive Railroad Tycoon 3 for...
Windows Vista
http://www.softwarepatch.com/utilities/logitech-webcam-driver-quickcam.html
Try these, it works for me on Ultimate after a bit of compatibility tweaking (a lot of it on my account as I messed up the install and had to clean up the mess)
Try it out.
Oct 25, 2007 | Logitech Quickcam Zoom 5 Pack Webcam
Logitech Cordless Internet Hnadset Phone on VISTA! for SKYPE
Handset shows DISCONNECTED.
On Logitech support page lookup document 6674 (search).
Boot computer with minimum og services and programs running.
Start Logitech handset program - this starts skype.
the handset will disconnect.
As soon I start the new LIVE MESSENGER BETA - the hanset disconnect.
Therefor I installed a msn messenger extension in Skype extras.
This gives me the opertunity to use msn messenger without using the LIVE MESSENGER PROGRAM - if I do - Logitech Handset will not work.
Sep 06, 2007 | Logitech Cordless Internet Handset Phone
Computers & Internet Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
