Question about Xerox 5855C Copier
Ram error e00074 - Xerox 5855C Copier
Hp Laserjet 2300 showing error 53.10.03
  • 53.xy.zz
  • CHECK RAM/ROM MEMORY
  • Description
  • There is a problem with the printer random-access memory (RAM) or read-only memory (ROM). The DIMM that caused the error is not used. Values of x, y, and zz, are as follows:
  • x = DIMM type
  • 0 = ROM
  • 1 = RAM
  • y = Device location
  • 0 = Internal memory (ROM or RAM)
  • 1 to 3 = DIMM slot 1, 2, or 3
  • zz = Error number
  • 0 = Unsupported memory (for example, presence detect bad)
  • 2 = Unsupported memory size
  • 3 = Failed RAM test
  • 4 = Exceeded maximum RAM size
  • 5 = Exceeded maximum ROM size
  • 6 = Invalid DIMM speed
Jan 04, 2015 | Office Equipment & Supplies
Tip
10 reasons why PCs crash-You must know tip 2
2 Bad Ram
Ram (random-access memory) problems might bring on the blue screen of death with a message saying Fatal Exception Error. A fatal error indicates a serious hardware problem. Sometimes it may mean a part is damaged and will need replacing.
But a fatal error caused by Ram might be caused by a mismatch of chips. For example, mixing 70-nanosecond (70ns) Ram with 60ns Ram will usually force the computer to run all the Ram at the slower speed. This will often crash the machine if the Ram is overworked.
One way around this problem is to enter the BIOS settings and increase the wait state of the Ram. This can make it more stable. Another way to troubleshoot a suspected Ram problem is to rearrange the Ram chips on the motherboard, or take some of them out. Then try to repeat the circumstances that caused the crash. When handling Ram try not to touch the gold connections, as they can be easily damaged.
Parity error messages also refer to Ram. Modern Ram chips are either parity (ECC) or non parity (non-ECC). It is best not to mix the two types, as this can be a cause of trouble.
EMM386 error messages refer to memory problems but may not be connected to bad Ram. This may be due to free memory problems often linked to old Dos-based programmes.
on Mar 04, 2010 | Computers & Internet
Ram error
If it is a RAM error then you will have to replace the RAM. You can check it out by pulling it out one at a time, rebooting to see which RAM set is bad. Replace that one. I really would replace all of it though.
Apr 03, 2014 | Intel Pentium 4 530 3.0GHZ System (SP4S30)...
Num lock blinking
It might be an error code. Most laptops gives error codes in that way where the num lock blinks. Most common problem can be RAM related. Reseat the RAM and try again. If that doesn't work, RAM might be faulty or the RAM slot itself can be faulty. Try to google the error codes for your laptop and see specifically what error it might be.
Jan 30, 2013 | Intel S6240 Notebook
Hello, I have a Xerox 4510 DT that shows the error: RAM ERROR. I have had the users shut down the machine, wait a minute and then restart but the error still shows. What else can I have the user do?
You can try inspecting and moving the ram to the other RAM slot. The 4510 image processor board has 2 ram slots, so one of them should still be unused. To access the ram you must remove the right side cover. Its possible changing the slot the ram is in will fix this, if it does not the next step would be to replace the ram. Part# 133K27760 for 128MB. Finally, if after replacing the RAM the error continues you would need to replace the image processing board. (part# 960K41806). Hope this helps
Aug 01, 2011 | Xerox Phaser 4500 Printer
3 beeps when i boot my pc with ram but no beeps when i boot without ram
Here is the info I found on the Asrock website. This would be a normal code if you have no RAM in the system.
Beep Code Descriptions 1 short Memory refresh timer error. 2 short Parity error. 3 short Main memory read / write test error. 4 short System timer failure. 5 short Process error. 6 short Keyboard controller BAT test error. 7 short General exception error. 8 short Display memory error. 9 short ROM BIOS checksum error. 10 short CMOS shutdown Read/Write error. 11 short Cache Memory bad.
Apr 14, 2010 | Asrock K7S41GX Motherboard
I am getting this error in my laptop when start windows. ''Fatal Error Driver Start EPHD Return False.''
HI,,
ITS PROBLEM WITH URS RAM ,,
IF U HAVE 2 NOS RAM,FIRST REMOVE ONE RAM AND ON THE LAPTOP,IF ITS RUN GOOD WITHOUT GIVING ERROR THAT MEANS OTHER RAM HAS PROBLEM ,,,
TNKS
RABBANEES
Nov 12, 2009 | Dell Latitude E6400 Notebook
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
Ram error on a 6250 xerox printer
TRY FIRST (Solutions without parts):
For a continuous RAM Error message, try cleaning RAM contacts and reseating RAM.
NOTE: Third-party or generic RAM is not covered by warranty or service contract and should be removed for troubleshooting purposes.
TROUBLESHOOTING TIPS AND HINTS:
Replace RAM. If problem is not resolved, replace the Image Processor board. Please Note:
Intermittent 6250 RAM Errors can be resolved by replacing the Print Engine Board and EEPROM, remembering to Save/ Restore in Diagnostics.
Apr 28, 2008 | Office Equipment & Supplies
Phaser 6250 "Ram error" (?)
Apr 15, 2008 | Xerox Phaser 6250DP Laser Printer
50 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
