Question about Garmin Nuvi 660 GPS Receiver
How do you open a nuvi 660
Can some one tell me how to open up my nuvi 660. thanks
  • 1 more comment
  • bill z Mar 05, 2008
    i see the screws behind the antenna but i'm not able to access them. the antenna is in the way.
  • Eshwar Pittampalli Apr 14, 2008
    How do I put the ribbon cables back?
    I cannot really insert all the cables and put two halves together.
  • mark18152 Feb 28, 2009
    I took the two screws out that are behind the removed antena, but the case dosen't seem to want to come apart. I there somthing else I need to to do?
  • 3 Answers
The ribbon cables are clameped in place. The look like they would slide out from the connector if you pulled then hard enough,... you do NOT want to do that. The black portion of the connector is actually a hinged clamp. With the unit lying on a table, face up as it you were using it; lift the top screen half away for the bottom half and tilt it toward yourself. You should see the ribbon cable and the red & blk wires. For the wide center connector and the one on the right, the black piece hinges up an away from you (towards the top). Try the one on the right first. When you flip it up, the ribbon will pretty much fall out. Pry the wide center one on the ends, NOT in the center. The narrow one on the left tilts donw towrds you. For the antenna, the hinged peice is brown, and it flips up towards the right. This one does not just fall out. It needs some gentle wiggeling. Also, I was able to use a T6 torx, T5 seemed a little loose,... yo don't want to strip any screws or you'll be screwed. SpaceVector
Posted on May 17, 2009
How can I get the anntenas ribbon for my nuvi 310, my ribbon is broken
Posted on Jun 30, 2008
Hello Steve, Flip up your antenna, at the very top you will see two screws, (These are T-5 Torx) remove them. Next be very careful when you open the top cover! The ribbon cable for the antenna comes through the bottom corner (I think it is on the right looking at the unit.) Next focus on the left bottom corner, there is a black barrel that holds the antenna to the unit and also provides the clicking steps you get when positioning the antenna. There should be a slit for a screw driver inboard about 3MM Put your screw driver there and pull to the right. Now you can lift the antenna box free. (NOT THE ENTIRE UNIT, THE RIBBON CABLE IS STILL ATTACHED.) Now at the top of the unit you will see two more T-5's under the antenna pivot area. You should be able to pry the unit open once these are removed. Still you must be careful the touch panel, speaker cable, power cable and one more cable is still attached. That one more cable you will see right away, it is red and black and you can remove it and fold the two halves over with the others still attached. After removing the final three which are all ribbon cables. Also don't forget the antenna calbe which once removed can be pulled through the half of the unit it is attached to. After seperating the halves you have the touch screen removed. You have two more phillips screws which removes the "motherboard so to speak." Hope this helps you peace. KP
Posted on Oct 09, 2007
Please be carefull if you want to remove white protective foil from the motherboard - you might detach small round piece marked 4R7. Happened to me and needed soldering.
Posted on Jun 03, 2008
This helped me open my Nuvi 310. Cheers.
Posted on Oct 10, 2007
Duh, i see the screws, they are on the top of the antenna. i was looking under the antenna bill z
Posted on Mar 05, 2008
  • 2130 Answers
SOURCE: Garmin Nuvi 660 "GPS is off" Can I bypass?
Try this first:
if that doesn't work, there is a magnet in the antenna and magnetic switch in the base that needs to be looked at inside.
- Jim
Posted on Oct 08, 2009
SOURCE: how do i unlock garmin nuvi 660 ? thanks
how do i unlock the gps
Posted on Aug 03, 2009
SOURCE: garmin nuvi 660
Thanks Jim, but problem was a loose flat cable cable connection from main pcb to screen.
Posted on Aug 06, 2008
  • 3006 Answers
SOURCE: can u tell me how to download free up dated maps
Hi Vicki, unless your nuvi was first activated and acquired satellite lock in the last 60 days (unlikely as yours was discontinued a long while ago) then you cannot get free map updates, sorry.
For models activated within the last 60 days Garmin offer a free update to the latest maps if the maps already on the product when it was purchased are an older version. After that, all updats must be paid for.
You simply won't find free map updates legally. Accurate maps cost a fortune to produce and update so nobody gives them away, even the few illegal downloads tend not to work and if they do work are likely to be out of date anyway.
The way that Garmin price their map updates, it's often better to simply buy a new Garmin with the maps pre-installed, although I appreciate that's not the answer you hoped for. If you do buy Garmin updates then you can either go for a one-off update, or for additional cost can buy a lifetime update, but it's limited to the lifetime of the device which is only designed to last three years anyway so may be poor value if you buy the lifetime update and your machine then dies of wear or old age.
Posted on Sep 29, 2010
  • 2386 Answers
SOURCE: how do i open my
You can get help from this video
Hope this helps if so do rate the solution
Posted on Jan 04, 2011
My garmin nuvi 660 is frozen . how can I do?
Reset the nuvi 660:
1 Disconnect from external power.
2 Flip antenna up.
3 Locate and press small button labeled "RESET" in the antenna recess on rear of nuvi 660.
4 Connect to external power source.
The nuvi will reset, power up and operate normally. If this was helpful, please rate it 4 thumbs up - thanks & good luck!
Sep 20, 2011 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 - Won't register
Sound like somebody has boughten that registered then return to the store. I would go back to the store where you bought it from and tell you want a new. .
Nov 23, 2009 | Garmin Nuvi 660 GPS Receiver
Speaker of garmin nuvi 660 doesn't work anymore
I measured a speaker on a Nuvi that I had opened up on my repair bench. It measured 7.8 ohm. I'm pretty confident that your speaker is bad.
- Jim
Sep 05, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 660
Jul 08, 2008 | Garmin Nuvi 350 Car GPS Receiver
Audio gone from my gps garmin nuvi 660
If you can hear audio through the headphone jack but not the internal speaker jack, then the speaker is bad.
This is a problem I have seen many times before. I will be posting an article soon on how to replace the internal speaker, however this is not a repair that just anyone can do.
You have to have skills in dissassembly & soldering.
- Jim
Jun 09, 2008 | Garmin Nuvi 660 GPS Receiver
Deleted MP3 files still play on my Nuvi 660.
Go to the GARMIN M3U file , open it and do what you want .Transfer, delete , copy and so so....
Dec 23, 2007 | Garmin Nuvi 660 GPS Receiver
Nuvi 660
you have to subscribe to FM Traffic
to do that go to
Oct 10, 2007 | Garmin Nuvi 660 GPS Receiver
Forget my gps nuvi pin
There is no way to unlock a locked GPS without the PIN or going to the location where the PIN was set. If you do not know these, the unit must be sent back to Garmin.
Jul 29, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
16,958 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
