Question about Whirlpool MH2155XPS Microwave Oven
Whirlpool microwave Hello, this is my problem: I used the microwave yesterday in the morning and went to use it the afternoon it worked. Tried to use it about 5 minutes later and it had a funny noise coming from behind the digital clock like a humming noise. Like it was trying to heat up and quit. Everything still works except now you push the start button it humms and won't heat up. The warranty is up and just need to fix. thanks
  • Anonymous Feb 20, 2008
    Whirlpool mh2155xps microwave oven comes on, light and plate turns but the is no heat.
  • Whirlpool Master
  • 9,098 Answers
This may have already been dealt with, but others can benefit from an accurate, thoughtful reply to this problem.
I would suspect a shorted high voltage diode or bad magnetron.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 26, 2007
  • 473 Answers
It has a problem in the high voltage which should only be repaired by an experienced technician for safety. On some models the magnatron has a longer warranty than just one year. Will have to check your manual. High voltage parts are magnatron, capacitor, diode, and transformer. If it isn't under warranty it's almost better to buy new due to repair costs on microwaves. May be worth at least having it checked by a technician.
Posted on Oct 08, 2007
Yesterday the microwave was working fine, this morning nothing at all...No power at all. I have checked the circuit breaker and everything is fine. The oven below it is on the same breaker and it works...
it sounds like the internal fuse has blown. if your handy, it can be done , however,,MAKE SURETO
DISCONNECT THE POWER SOURCE BEFORE BEGINNING. if your not 100% comfortable
have a trained technition service the unit...
Nov 20, 2010 | Whirlpool GH7208XR Convection / Microwave...
MV1502B over-the-range unit. worked good yesterday (sunday)morning, but stop heating in the afternoon. light, turntable and humming sound still, but no heat, placed piece of alum foil and no sparks
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 15, 2010 | Microwave Ovens
Light bulb not on and microwave not turning on. Was working fine in the am but went to warm something in the afternoon and the light wouldn't come on and didn't warm the coffee.
Firstly check fuses in your microwave. You will have to take off the outer casing and check on the power circuit board to see if there are blown fuses.
Best wishes,
Graemevm
Jan 22, 2010 | Whirlpool RMC275PD Microwave Oven
Yesterday, I went to use the microwave and as I pushed start, I heard a loud pop and saw sparks behind the vent cover. The microwave light and turn table work fine, but it does not heat. Is it repairable?
sounds like your magnetron went out . check how old it is, sometimes the manufacture gives a 5-10 yr warrenty on part if no warranty on unit then it may not be worth fixing depending on how much u spent on it. part roughly 89.99-139.99 labor 85-165.00 depending on who u use and were u live. hope this helps . thanx..
Oct 07, 2009 | Whirlpool Microwave Ovens
Hi Yes I have a Whirlpool MIcrowave Oven Model # MH7140XFB-1 And It was working fine this morning I went to use it this afternoon and the panel is not working no lights work nothing the fan under neath...
check for a blown ceramic fuse behind the panel. If the fuse is dark in color it is probly bad. you can get one at radio shack store or on line
Apr 16, 2009 | Microwave Ovens
Unit will not function
well how old is the unit? and if you do a local search you will find a service place with in your zip code....that will be the better solution for you....good luck and hope this works,,but its not something that is a pin point solution....
Jan 21, 2008 | Microwave Ovens
Microwave plmv169dcd
You may be right.
The hood fan should always be on whenever you're cooking on the stovetop.
If it does not dry out over time, it may need to be manually dried or blown out.
Replacing the keypad is generally not too hard do-it-yourself job.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If you need more detailed help, please feel free to follow up directly via the first link.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 11, 2007 | Whirlpool GH7145XF Microwave Oven
Whirlpool MH2155XPS Microwave Oven Logo
187 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
