Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
Xl 76 decompression
Spins easily with plug removed but almost impossible to pull starter cord with plug in
3 Suggested Answers
  • 5 Answers
SOURCE: HARD TO PULL CORD WITH SPARKPLUG IN CHAINSAW. IF
sound like hydraulic lock,try leaving the spark plug out and pull it quite a few times with the spark plug hole facing the ground, this should shoot the offending fluid out.
might work ?
Posted on May 01, 2009
dontbother10
  • 2220 Answers
SOURCE: homelite super xl ao runs for a short time, then
Inspect your cylinder and piston as follows:
A written diagnosis by a good independent saw shop ($10-20 I recommend Stihl) might be a good idea at this point.
1. Remove the starter housing. Does the starter operate smoothly? If yes, reinstall the cover and continue with 2, if no repair starter.
2. Is the saw equipped with a decompression valve? Yes continue, no proceed with 3.
· Leave the ignition off, set the valve and pull the starter.
· Pull gently to release the valve. Is there a difference in the effort required?
· If yes continue with 3, if no repair or replace the decompression valve.
3. Was this saw perhaps operated in a lean condition (metal transfer from the piston to cylinder wall)? This may be caused by many things including; leaky intake connections at the engine or carburetor; leaky crankcase seals; or running on gasoline containing no 2-cycle oil.
· Remove the spark plug wire and plug. Remove the muffler, hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears?
· Pull the starter slowly, inspect the piston as it rises and falls. Is it a dull gray without scratches and gouges?
· Hold the light at the exhaust port and look through the spark plug hole, inspect the cylinder above the exhaust port. Is it shiny and smooth or speckled with gray spots or smears?
Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by an independent saw shop should be considered.
4. The last likely possibility is the saw has jumped timing. This problem or any not discussed is usually beyond the ability of the operator to repair. Please take it to a good local saw seller/mechanic for a written diagnosis before authorizing any repair. HTH
Lou
A short block R² is the usual repair homeowner grade saws. You may find some additional help here:
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
Please do a search for your saw before posting any question.
Posted on Jan 15, 2010
The engine in my My McCullock Promac 610 has suddenly become impossible to turn over using the starter cord although it turns over easily with the spark plug removed.
Keep in mind... Gasses compress, liquids do not. Remove the spark plug. Hold the saw so the spark plug hole is the lowest part of the engine... and pointed away from you. Pull the starter cord rapidly until all fluids are purged from the crankcase. If it happens again... rebuild or replace the carb. Good Luck !!
Mar 02, 2015 | McCulloch Pro Mac 605 610 645 650 655...
Saw starter pulling too hard to start.
Check piston rings. Sounds like you have a seized engine.
Feb 20, 2013 | Husqvarna Chain Saw Models 51, 55
Thanks for your help re my Husky345. However I am still in trouble as I have found there is no decompression valve on it. The starter is very lumpy and hard to pull, having already broken the cord dr
Remove the flywheel and check the key has not sheard, if this is ok the only thing you can do now is to increase the air gap between the ignition unit and the flywheel magnets, move it out to 0.8mm and try again, this will alter the ignition timing slightly and reduce the drag from the magnets.
Dec 27, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 345 decompression valve
The345 should have a blue push in deco valve on the r/h side of the cylinder, if not there may be a 13mm blanking screw there, this can be removed and a deco valve fitted.
Dec 24, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Pully stater will not spin when pully rope is pulled.
Starter Handle difficult to pull:
1. Remove the starter cover.
· Inspect the flywheel and crankshaft under the starter cover. Are the woodruff key slots on the crack shaft and flywheel aligned and the key intact? If not; Please consider taking the saw to a good local saw seller/mechanic for a written diagnosis before authorizing any repair or ordering any parts; if yes continue.
· Does the starter operate smoothly? If yes, reinstall the cover and continue with 2, if not repair the starter.
3. Was this saw perhaps operated in a lean condition (metal transfer from the piston to cylinder wall)? This may be caused by many things including but not limited to; leaky intake connections at the engine or carburetor; leaky crankcase seals; cracked fuel delivery lines; running on gasoline containing no 2-cycle oil.
· Disconnect the spark plug wire and remove the plug. Remove the muffler (clean it and the spark arrestor before reinstalling), hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears?
Please Note: Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by an independent saw shop should be considered.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 14, 2010 | Husqvarna Chain Saw 20" Bar
My Chainsaw Husqvarna 345, won't start. With
I hope 2 different problems Marvin. I think the starter is most important, after you reply with findings we will take on the likely fuel delivery problem. Please do this and post back (below) with what you find.
1. Remove the starter cover. Does the starter operate smoothly? If yes, reinstall the cover and continue with 2, if not repair the starter.
4. The last likely possibility is the saw has jumped timing. Inspect the flywheel and crankshaft under the starter cover. Are the woodruff key slots aligned and the key intact? Please take it to a good local saw seller/mechanic for a written diagnosis before authorizing any repair.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Starter fluid removes what little lubrication is provided by the fuel mix. I suggest a teaspoon of mix into open carburetor throat or the plug hole. Do not go to speed with the air filter removed.
Mar 29, 2010 | Husqvarna Garden
Why is my pull cord hard to pull? Seems like it is catching on something.
It should be hard to pull during part of the revolution... this is the compression stroke and is normal.
Better chainsaws have a compression release that allows the engine to spin faster while cranking and then closes when it fires. These are easier to start but cost more.
Mar 09, 2010 | Homelite Garden
I AM NOT ABLE TO PULL CRANKING CORD ALLTHE WAY. IF I REMOVE SPARK PLUG THEN IT IS EASY TO PULL CORD ALLTHEWAY UP. WHY AND WHAT TO DO ?
Starter Handle difficult to pull:.
1. Is the saw equipped with a decompression valve? Yes continue, no proceed with 2.
· If yes continue with 2, if no repair or replace the decompression valve.
2. Was this saw perhaps operated in a lean condition (metal transfer from the piston to cylinder wall)? This may be caused by many things including but not limited to; leaky intake connections at the engine or carburetor; leaky crankcase seals; running on gasoline containing no 2-cycle oil.
3. The last likely possibility is the saw has jumped timing. This problem or any not discussed is usually beyond the ability of the operator to repair. Please take it to a good local saw seller/mechanic for a written diagnosis before authorizing any repair. HTH
Lou
Feb 20, 2010 | Garden
Homelite super xl ao runs for a short time, then
Lou
Jan 15, 2010 | Homelite Garden
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
19 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
