Question about AEG Lavamat Lavalogic 1600 Front Load Washer
Error code CA - AEG Lavamat Lavalogic 1600 Front Load Washer
My washer has an error code 02 then blinks F is this th same type of error
Datanet Copier, Fax, and Printer Consultants
18543 Devonshire Street #222, Northridge, CA 91324
Printer Repair Pros Inc.
9180 Kelvin Ave., Chatsworth, CA 91311
Image 2000, Inc.
7510 Hazeltine Avenue, Van Nuys, CA 91405
Try the places i have mentioned above.
Jan 09, 2011 | Maytag EPIC MFW9700S Front Load Washer
I have a ca code what does this mean
Hi
Thanks for using FixYa. Error code CA means Average current limit. This error code will display if the load of clothes is more then the normal load. Also if current limit breaches then status signal comes back from the motor controller. The unit will return to standby mode and display CA. Average current trip occurs if the current draw at the motor windings is greater than 5.55 amps in 2 seconds. This error occurs if there is a problem with the drive motor, thermal protector or motor controller. Over-loading the unit may cause this problem.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 22, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
Casio PCR T2000 Register : CA=/AMT TENDER ERROR no code
There was some setting on the CA/Tender button that someone had accidentally entered. to clear this setting we put the register in program mode. then hit 3 / subtotal. then hit 0 / CA/Tender / subtotal. thats it. cleared the setting and the register works fine now.
Jun 18, 2009 | Casio Parts Cash Register PC Desktop
CA error code on Calypso Washer
CA Cl Average current limit Or Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip. Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings. Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
Meaning you had stuffed it full one time and then it was hard on the motor, you will have to change the drive motor most likely...
May 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Sharp service code H5-01
To enter simulation mode to reset errors enter this sequence on keypad.
P, * , CA , P then enter sim # 14 to reset code.
press " custom settings" button to return to previous menu and CA to exit sim mode.
Dec 10, 2008 | Office Equipment & Supplies
CA Error Code - AEG OKO LAVAMAT 86700
c-a error message poped-up.washer stop working.............please help.
Sep 15, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
AEG Lavamat Lavalogic 1600 Front Load Washer Logo
24 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
