Question about Bernina Bernette 75
What tension setting for my bernette 134
What numbers should my machine be on for the tension
3 Suggested Answers
  • 109 Answers
SOURCE: I have a bernette 134
If you don't have a manual to check this, contact Ron at
a1sewingmachine.com. The settings on your dials should be
all set on 4. This number should be highlighted or marked different from the other ones. Look for the little notch (or arrow) on the machine and line that up with the 4. Make sure the threads are under the tension discs which are under the dials. When threading pretend you're flossing and pull the thread back and forth so you can feel the slight tension on the thread. Make sure your presser foot is up when you thread the machine. Your stitch length should be about 3 and the stitch width 5 and the differential on 1. These are basic settings for all sergers and you might have to play with them to get a good stitch. Feel free to ask if you have any more questions.
Posted on Aug 23, 2010
SOURCE: I need a manual for bernette 134
here is a link for 2 manuals, one is free the other is not, you can choose which is the one you want.
http://www.bernina.com/getdoc/d4dc2dee-97a4-4987-ac83-14a5e664b42d/Bernette_100_200_manual
http://sewusa.com/Sewing_Machine_Manuals/Bernina_Manuals/134_134D_Instruction_Manual.htm
Posted on Aug 20, 2013
How do you adjust the upper thread tension on the 15000. Karen
Don't have any idea what machine it is from the model number. Most machines have a tension dial. The higher the number, the tighter the tension. The closer to zero, the looser.
Apr 08, 2018 | Sewing Machines
How do i adjust the tension on elna 2003?
Not quite sure what you are asking. The upper tension is governed by the tension disk. Higher number is tighter, lower number is looser. Usually, the mid-range is a good place to start. Tension is correct when upper and bobbin threads meet in the middle of the fabric.
NOTE--ALWAYS RAISE the presser foot when threading so the thread will seat in the tension disk!
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
How to Adjust Sewing Machine Tension on Craftsy
Just FYI:
Why my Elna sewing machine is bad Or dont buy an Elna 2007
Dec 08, 2016 | Elna Sewing Machines
How do I set the bobbin tension
How to change the tension on a sewing machine?
Adjust your top tension if it's too tight. To decrease your top tension if it is too tight, turn your knob so the numbers are decreasing. Try ½ to 1 number lower, then test the stitches on a piece of scrap fabric. Continue until it looks even on both sides and you can no longer see the bottom thread on the top.
How to Adjust the Tension on a Sewing Machine: 13 Steps
www.wikihow.com/Adjust-the-Tension-on-a-Sewing-Machine Search for: How to change the tension on a sewing machine?
https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=Sewing+Machines+How+do+I+set+the+bobbin+tension ..try this link
Dec 04, 2016 | Sewing Machines
Which is the needle tension
Needle tension is governed by the tension dial on the front of the machine. The higher the number the tighter the tension. For basic stitching, it is generally a good policy to start out with the tension set at the midway point between high & low numbers and then tweak it for your particular machine.
How to Adjust Tension Sewing Machine
Nov 30, 2016 | Sewing Machines
What are the correct thread tension numbers on thePfaff hobby grand quilter 1200
Usually, the standard tension for upper thread is midway between high & low numbers. However, every machine differs and may need to be tweaked. Unfortunately, finding the correct tension is generally a test and adjust method. Be sure you are using a brand new needle and good quality thread.
Oct 10, 2016 | PfaFF Sewing Machines
How do you adjust the bobbin tension?
Factory standard tension for upper thread is the midway point between the high and low number. However, that tension dial is meant to be used for tweaking tension. Generally, tweaking is required whenever the type of fabric, needle, or thread are changed, ie thicker fabric like denim should have a different upper tension setting than fine chiffon. To be successful with tension settings, one must become comfortable adjusting the upper tension.
NOTE: Accurate tension is achieved when the upper thread and bobbin thread meet in the middle of the fabric.
Understanding Bobbin Tension
Jan 20, 2016 | Brother Sewing Machine - XL2600i
Model 1507 tension
I'm sorry, but you will have to be more specific. There is a top and bottom tension. The top tension is adjusted using a dial of some kind, visible on your machine. It has numbers on it; generally the lower the number, the tighter the tension. The bobbin tension generally does not need adjusting, although it can be adjusted. Please write again to let me know what it is doing that leads you to believe the tension needs adjusting.
Dec 11, 2013 | Singer 1507
Tighten the tension
Try these following steps:1. Look to see whether the thread loopsappear on the fabric back side. If this is the case, the tension on your sewingmachine is too loose.2. Check to see if your fabric ispuckering on the front side when you sew. If this happens, then your tension istoo tight.3. Adjust your needle thread tensionwith your machine threaded and your presser foot pedal down.4. Turn your thread tension dial asneeded. If you increase the number on your tension thread dial, you will beincreasing the tension on your sewing machine. If you are lowering the numberon your tension thread dial, you will be decreasing the tension on yourmachine.5. Clean your thread tension with asmall piece of paper or a toothpick. Slide the toothpick or paper between thediscs to remove any tangles of thread.Hope this will help you. Good Luck.
Oct 22, 2011 | White Sewing 1409 Mechanical Sewing...
Looking for sewing machine manual for singer sewing machine model 6218. The bottom bobbin tension is so loose that it forms many loops under the fabric.
I went to the singer website & typed the number in 6218 & it came up with nothing, is that the correct model number?
the tension problem try adjusting the top thread tension to 3-5, & see if that helps the loose tension
Oct 21, 2010 | Singer Sewing Machines
Can't get a straight stitch. too loopy.
yes, a greater number will be more tension, i find it helps to use four different color of threads so that it is easier to see the change in the adjustment that you make. be positive that the machine is threaded correctly and the thread is IN the tension disc, very easy to overlook. hopes this helps
Nov 11, 2008 | White Sewing Speedylock 1600 Mechanical...
Sewing Machines Logo
32 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
