Question about Sportsart Exercise & Fitness
Lubricate the deck error on afton treadmill - Sportsart Exercise & Fitness
4 Suggested Answers
SOURCE: horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
Posted on Aug 22, 2010
power going to treadmill. it is beeping the whole time but wont start or move
Posted on Jun 14, 2011
  • 52 Answers
SOURCE: treadmill is slippery after lubricating deck
You Ubricate it with silicon spray. It is usually bought at a sports shop which sell treadmills. You lift up the centre of the mat on both sides and give it a spray with silicon spray making sure it goes across the width of the deck. You only need to do one line across, not the whole of the deck. If you have used oil to do this then there lies your problem with the slipping issue. If no oil is used then the adjusters on the rollers which realign the mat may need to be tightened usually with an Allen key wrench, but make sure it is centralised, which you have to do while the machine is plugged in and running. Keep your fingers well clear of the let while any covers are removed as it will remove your finger as quick as a flash. Don't wear any trailing clothing either. Adjust at arms length. Good luck
Posted on Nov 24, 2013
Lubricating walking belt
Video about How to Wax a Treadmill Using Powder Wax
How to Wax Treadmill Using Powder Wax Video
How To Re-Wax a Wood Deck for a Trotter Treadmill
How To Re Wax Wood Trotter Treadmill Deck
Video of How to Lubricate a Treadmill using Liquid Lube
How to Lubricate Treadmill Using Liquid Lube Video
Apr 02, 2014 | Exercise & Fitness
T916 treadmill gives me an system overload error
Dear Sir:
In all case this error indicate tha lack of maintenance, specially lubricanting in Deck vs Belt DECK, do oit. By that reason the machine will Shut down for to prevent the electronic system, in order to preserve the electronic component.
see my personal TIPS for diagnose and trouble.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Mar 06, 2012 | Nautilus Commercial Series T916 Treadmill
My tanturi treadmill model j620p indicate 51 in the panel. even i press the reset button still the 51 still in there. all keys does not work too. what shoul i do?
I will try to help you:
If any error code appears on the display or there are other
malfunctions, proceed as follows:
1. Turn off the power switch for a minute and then
turn it on again.
2. Insure the tether key is properly inserted.
3. Insure the power cord is properly plugged.
4. Insure the treadmill is properly lubricated (see 4.3.
LUBRICATING THE RUNNING DECK).
5. If the error code does not disappear after the
above mentioned maintenance actions, please
contact your local TUNTURI dealer. Always give
the error code and serial number (see the sticker
at the back of the frame, below the left-hand side
rail).
4.3. LUBRICATING
THE RUNNING DECK
Please apply teflon by using the pressurised can provided
with these instructions.
1. Let the treadmill run at a slow speed and spray
teflon into the lubrication .
2. When teflon is applied for the first time,
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 23, 2011 | Exercise & Fitness
My tanturi treadmill model j620p does not work. thou it has a power n the panel indicate a number 51 even i press the reset button it does not reset and all the key button does not function. what sould i...
Dear Sir:
turn it on again.
rail).
4.3. LUBRICATING
THE RUNNING DECK
Lubrication is the most important service activity for the
treadmill. This is absolutely essential, if the friction of the
running deck increases noticeably or the motor begins to
heat up. Lubrication intervals must under no circumstances
exceed 200 usage kilometres; we recommend relubrication
once a month. During the first 200 km of use, the running
deck must be lubricated at intervals of 50 km. Insufficient
lubrication will cause the belt, running deck and motor to
wear out and break.
NOTE! Before you start to use your treadmill, it must be
carefully lubricated per the lubrication instructions
below! NOTE! If the treadmill is not used for at least
three weeks, it must be carefully lubricated per the
lubrication instructions below!
The need for relubrication depends to a great extent on the
running styles and weight of the user: heavy user weight and
slow speed put particular strain on the device and therefore
demand greater lubrication. Use only the teflon enclosed to
lubricate the treadmill. Contact your local TUNTURI dealer
for further supplies of teflon.
NOTE! The device must under no circumstances be
lubricated with silicone!
instructions on the teflon bottle carefully.
teflon into the lubrication pipe underneath the
treadmill. The pipe is marked with a decal.
2. When teflon is applied for the first time, the
spraying time with the pressurised can should be
approximately 20 seconds. Later, a spraying time of
10 seconds is sufficient.
3. Teflon drops through the holes of the lubrication
pipe to the center of the running belt; the treadmill
is instantly ready for use.
Please ensure after each time that you relubricate your
treadmill that a strip of about 8" wide on the underside of the
running belt becomes moist with teflon oil along its whole
length. If necessary,
If you need further assistance, please reach me, sincerely. God bless you.
E.CUADRA
Treadmill shuts off in middle of workout
A treadmill will shut down from to much friction which is due to high motor current because the walkbelt and deck are not properly lubricated. I would recommend replacing the motor controller,walkbelt,deck and applying .5 oz of lubricant on the deck every 3-6 months or 100 hours of use. This will extend your treadmill's life many years.
Aug 09, 2010 | Precor 9.31 Treadmill
I have the Lifecore Fitness T900HR treadmill and when my husband is running it stops. We have made sure all the connections are tight even the safety key but it still stops. When I am using the treadmill...
Their might be high friction between the belt and deck thus causing the error 1 code when your husband is on it. Try lubricating the area between belt and deck using silicone lubricant ( refer to owners manual). Then the lighter of the two "aka wife" walk on the treadmill for about 5 to 10 minutes.
This should take care of the problem if not then their is an issue with the belt and deck ( 85% of problems on treadmills are belt and deck related)
Jul 31, 2010 | RTO LifeCore Fitness LC-T900HR Treadmill
It keeps shuting down
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes.
May 10, 2010 | Proform Crosswalk 500 Treadmill
My treadmill Proform caliber walk... belts keeps
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in2_bing.gif and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
May 08, 2010 | Proform Crosswalk 500 Treadmill
Stops while in motion
May 01, 2010 | Proform CrossTrainer Treadmill
Where do i put lubricant in my reebok treadmill t5.1
To lubricate your treadmill, start by lifting the edge of the walking belt and spread the lubricant between the belt and deck. Once you have finished on one side, do the same to the other side. When you finished both sides, start the treadmill at around 3 mph. Then walk on the treadmill to spread the lubricant on the deck for about a minute. Then your done.
Apr 19, 2010 | Exercise & Fitness
Exercise & Fitness Logo
Top Sportsart Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Steven's...
Steven's...
Tom Chichester
Are you a Sportsart Exercise and Fitnes Expert? Answer questions, earn points and help others
