Question about HP CN504A - Photosmart Premium C310a All-in-One Wireless Inkjet Printe
Paper Jam CN504A
Printer has a paper jam. Doesn't seem to have any paper in the printer. Is there a way I can get the gears to turn without loading any paper?
Inkworks
  • 87 Answers
SOURCE: Paper Jam
Sometimes the "paper jam" with no paper is due to the printer not being able to feed paper in to the machine. You send a print job to it...printer attempts to feed paper but can't...then you get the paper jam message and ofcourse there is no paper in the machine. Powering off and on should clear the message. Make sure you clear the print job from the print que or the same thing will happen on power off/power on because the computer will still try to send the print job to the printer when turned on. I have found that all of HP's machines that have this style of paper feed mechanism fails prematurely. The pickup roller is too small for one but as soon as the roller is coated with dust it begins to fail. You can take a Q-tip and go in from the back to try and clean the roller. Water is fine.
Inkworks
866-381-0541
Posted on Nov 06, 2008
  • 685 Answers
SOURCE: can't reset paper jam HP1315 all in one printer
Try these instructions.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01577197&lc=en&dlc=en&cc=us〈=en&rule=8331&product=374568
Sometimes when you get a paper jam the carriage that holds the ink becomes jammed and you have to reset the printer to get it to work again.
Posted on Dec 06, 2008
SOURCE: HP 7680 paper jam
I spent 21/2 hours with the HP tech support - with their recomendation to upgrade my 14 month old computer to the bigger model because the screen reads "paper jam". I have had this printer replaced once already, 1 week after I received it for a defective doc feeder. I decided to take things into my own hands - First of all, no paper was ever located in the paper jam area. Several soft resets by shutting down for 20+ seconds, then pressing #6 at start up resulted in any improvement - the screen continued to read "paper Jam....." the HP tech was unable to offer any practical suggestions.
I turned the machine upside down after removing the document feeder and examined the rollers at the back of the rear tray where the paper jam was supposed to be. I noticed that there was some black residue on the gears and although the machine was off and unplugged - the rollers / gears would not roll freely and seemed to get stuck. I cleaned them thoroughly with an old but clean toothbrush and water. (don't grease the gears - I've heard it eats the plastic) - until the rollers would freely roll when I moved the gray rubber rollers.
Returned the machine to correct position - and turned it on - "paper jam" message returned but the machine was sounding different than it had - so I did another soft reset (unplug from wall and printer for 20 seconds, then holding #6 for a few seconds while plugging back in and now I can print. The printer went through its maintenance cycle and did a realignment. I can print and everything is working fine at this time.
I hope that this will help someone. I couldn't find any information on how to repair the printer and HP seems to be all about producing junk and convincing you to "upgrade" at a cost of $2-300. When this one does finally go - I won't be buying an HP!
The 7680 jams a lot and the document feeder has a lot to be desired. It has trouble feeding straight and if there is a jam anywhere in the machine - it is always difficult removing the paper without tearing it and creating more problems and waste of time.
Posted on Apr 10, 2009
  • 54 Answers
SOURCE: flashing paper jam, no jammed paper
Check to see if there is dust on the senor inside the fax machine, blow with some air can help
Posted on Apr 23, 2009
SOURCE: lights flashing, printer won't print as a result of a paper jam
Hi Girlemom. Just had the same problem here. Lift up the lid and slide the ink cartridges to the left. If they are stuck in the middle, this will prevent the printer from starting properly. Then, unplug it, plug back in, and turn on. It should restart normally.
Posted on May 21, 2009
Paper jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 12, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper Jam lite is on ( no paper jam )
give this a try
alternative :
May 28, 2009 | Brother HL-2040 Laser Printer
E-04 Clear Paper Jam, no paper in printer
alternative :
May 15, 2009 | Epson Stylus CX7800 Color Flatbed...
Paper jam
alternative :
Mar 23, 2009 | Sharp UX-B20 Plain Paper Inkjet Fax
PAPER JAM
try this
alternative :
Mar 19, 2009 | Sharp FO DC500 Plain Paper Laser Fax
Paper Jam
try these steps
alternative :
Feb 14, 2009 | Dell 810 All-In-One InkJet Printer
Paper jam
give this a try
alternative :
Dec 26, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Paper jam paper jam error message continues even no jam, have to feed by hand sever times before paper will feed into printer.
try this
alternative :
Dec 23, 2008 | Canon Pixma MP450 All-In-One InkJet...
Paper jam notification after printing one page, no paper jam
try this
alternative :
Nov 16, 2008 | HP PSC 2210 All-In-One InkJet Printer
Paper jam
hey, give this a shot
alternative :
Oct 19, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
HP CN504A - Photosmart Premium C310a All-in-One Wireless Inkjet Printe Logo
22 people viewed this question
Seeker5211
Seeker5211
