Question about HP Color LaserJet 4650DTN Printer
Cp2025 paper tray tray1 tray2 - HP Color LaserJet 4650DTN Printer
5 Suggested Answers
  • 138 Answers
SOURCE: Tray2 Paper emty message after swapping out tray2 pickup roller
Your problem is more than likely that the sensor lever is not properly positioned. You may also have dislodged the shaft from the drive gears (gears on right out side of carriage). Both are easy to do.
Here's a couple pictures of the exact positioning of the paper sensor positioning. It should freely flip up and fall back down with gravity. Remove the tray and check the flag that hangs down.
Just in case you have dislodged the shaft from the geartrain, here's a free copy of the HP Service manual for the printer that will walk you through disassembling the right side for re-mounting the shaft and holder clip for the shaft.
Hope that helps you. :)
If this resolves the issue, hit me with a Fixya! If not ask me further and I'll try and help you some more.
Posted on Sep 10, 2008
shawn38
  • 200 Answers
SOURCE: HP laserjet p4014n
Check the media settings for your paper trays. Make sure they are set properly, also check the diver media settings. Is the problem happening with a specific print job? If it is check the page setup for that document.
Posted on Mar 06, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: Hey I have a hp3005n that
The paper feed clutch is engaging but not releasing. Either the clutch itself has gone bad or the solenoid that engages the clutch is sticking. HP's are kinda bad about having a foam strip on the solenoid that is suppose to suppress noise when the solenoid activates. Problem is the foam wears thru to the adhesive underneath so then the solenoid arm, when engaged, "sticks" to the adhesive and stays engaged when it is supposed to release. You will either need to call a repair person or dis-assemble and get to the solenoid/clutch area to try and figure out which problem you have. To get an idea where this is you would have to follw the shaft that holds the feed roller, the clutch and solenoid would be on the right side.
Good Luck and Thank You for using Fixya.
Wheatland Services
Posted on Feb 11, 2011
Testimonial: "Very nice solution, the arm of the solinoid was out of position so now its all good, Thx"
  • 7 Answers
SOURCE: I have a HP CP2025
It sounds like a blockage in the paper path at the rear of the unit. This unit picks from the rear of tray 2, and there is a separate path for tray 1 that conveys the paper above that tray and back to where it can intersect the main paper path. Sounds like you have a blockage where those 2 paths intersect.
Remove the cassette 2, and in that hole, there are 2 levers that allow you to lower the bottom half of the tray 1 bypass path. Look back in there for the tiniest scrap of paper left behind.
Next, if nothing is found, open the rear door, and again with a flashlight, look down in the bottom of the paper path for a small bit of torn paper, or some other obstruction. Odds are this is your problem.
Posted on Mar 01, 2011
The HP LaserJet 2430tn Printer will not automatically change from legal to letter paper. Also it shows a jam in the legal paper tray but there is no jam.
change Tray1 and Tray2 Paper size is any size and Paper type is any type as well as check override is on if its off change is on
Nov 04, 2013 | HP LaserJet 2430tn Printer
Hp laserjet p2055dn tray1 manual feed problem
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P3005n Printer
How to fix this error in printer hp p2055dn ''manual feed press ok for available media into tray 1
Aug 01, 2012 | HP LaserJet P2055d Printer
Manual feed tray bypass
Jul 25, 2012 | HP LaserJet 4250n Printer
Tray 1 load recycled letter?
Switch off & on once the printer, load papers in both trays, go to system choose file ask to print, when dialog box appears go to properties, select tray2., the shoot print, check its printing or not. If its printing problem in tray1 paper sensor,clean it.Reason why its not taking from tray 2. In menu settings its selected default tray as tray1. if no paper present in tr1 printer ask to press OK choose another tray to print, during this period indicating error.Best to do: clean all paper path sensor tray1 and tray 2 to prevent further errors... Pl revert..best of luck..
Feb 03, 2012 | HP LaserJet 4100dtn Printer
I have a HP CP2025 that will not pick up the paper from tray2 or print from tray1. It will pull the paper in from tray1, but it jams at the rear of the printer. It sounds like the printer is trying to pick...
Feb 28, 2011 | HP Laserjet Cp2025n Printer
Procedure to activate auto Tray switching in hp laserjet 4100
Okay, do you mean "Tray Linking". The process where, for example, if Tray1 goes to an empty condition, tray2 so the print job runs uninterrupted?
Or do you mean that you want Tray1 to print 6 or so pages and then switch to tray two because you need a different style of paper.
Tray Linking - you use the printer setup to activate.
Switch Trays - Usually controlled by printer escape codes.
If you create a "Print To File" off of the driver page, and send it to me at don.farr@hotmail .com I can look at the file and see what you are doing.
Don
Dec 08, 2009 | Office Equipment & Supplies
IBM Infoprint 1532 Tray Selection
For tray linking to work, both Paper Size AND Paper type must be configured the same for both trays. You probably have the paper sizes the same but types could be different. The is no setting to make tray linking work.. it will do it automatically if the above settings are correct.
Feb 24, 2009 | IBM Infoprint 1532 Laser Printer
HP Color LaserJet 4650DTN Printer Logo
27 people viewed this question
Seeker5211
Seeker5211
