Question about Crosley CAWC529JQ Top Load Washer
Spins but won't agitate
Washer will fill spin and drain fine but agitation is weak. I checked the belt no cracks and it seems tight. When turned by hand the agitator moves I am guessing correctly in both directions. If it is a clutch problem I do not know how to check it.
  • 38 Answers
Clutch is only used locking into spinout. Is drive coupling is loose or torn, if not you are most likely talking about a bad transmission
Posted on Nov 21, 2013
  • 61 Answers
SOURCE: Kenmore 80 series
ok sound lie a broke drive coupling lean the machine back look under the front you will see the motor in the center with a pump mounted on the front behind the motor is the gear case between the motor and gearcase is the drive coupling. To replace it disconect the power, remove the two clamps holding the pump on,remove the pump disconect the wiring harness to the motor now on the front of the motor there are two screws one on top and one one the bottom one the front of the motor with a 1/4 scocket romove the two screws. with a flat head screwdriver release the top clamp on the motor now the motor should tilt down and you can lift it off the coupling is on the short shaft of the motor and on the shaft of the gear case remove both may need to use a flathead screwdriver to get the one off the gearcase replace using a 1/2 deep well scocket and short extention and hammer tap them both on lightly but be sure the go all the way on put the rubber part of the coupling on the gearcase side and turn one of the fingers to 12:00 position turn one on the motor to 6:00 put motor back on the gear case bracket and put the top clamp on frist put the bottom clap back on insert screws put pump back on put pump clamps back on note you will have to turn the ootor to line the shaft up to go into the pump reconect the motor wiring harness plug machine in and test
Posted on Jan 20, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: wont spin does everything else but spin
Your spin cycle control seems to be bad. This is also called your timer. Check for power supply by pulling off your top panel and checking for power everywhere.
Posted on Apr 17, 2009
  • 151 Answers
SOURCE: won't spin out clothes after replacing belt
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on May 03, 2009
localwonder
  • 6784 Answers
SOURCE: agitates and drains but will not spin
Hi, there is a lid pressure switch that controls the motor during the spin cycle. if the lid is up, it will close open the circuit that controls the motor and it will shut the spin down.
Now, if this lid switch is broken or lose, it will not allow the spinning action at all. your lid pressure switch is damaged or lose at this time. i recommend inspecting this switch that is located under the lid rim. check the wires and connection clips for a lose fit. if the wires and clips are in good condition, this Will confirm the switch failure. replace in this case. i will link you to a replacement switch you can order on line if you choose.
CLICK HERE.
Posted on May 15, 2009
rickyrt441
  • 4399 Answers
SOURCE: my agitator wont agitate and the basket just spins
Thanks for choosing FixYa and welcome. If you have a washer that has a weak agitation or no agitation at all, here are some possible solutions. You need to check your belts. Most washers have one or two belts. Check your lid switch. If a lid switch is bad, it can cause the washer to not work properly. Sometimes, they will not work at all. Make sure you check your drive motor. The drive motor controls the spinning, draining, and agitation. Most washers have the reverse motor, meaning the shaft rotates in both directions, clockwise and counterclockwise. It is possible to lose one direction and not the other. Some washers have a clutch that controls the agitation. If it is bad or worn, it may prevent the agitator to work. Most of these washers come from General Electric. You could have a bad motor coupler. They are located on the side of the motor drive inside the washer. It is also possible that you have a bad transmission. Check the agitator itself. You could have a bad spline or two. The splin accompanies the shaft and allows the movement of the agitator. If you rule out all the parts above, you may have an electrical issue or an issue with the control board. It is very important to test each part and make sure it is getting power. If a part is not working and not getting any power, the power loss may be the reason that it doesn't work. You can test the current in the wires with a voltage meter. Thank you very much for reading this tip and thank you for using Fixya
Posted on May 01, 2011
What needs to be replaced? I installed a new motor but my washer still won agitate or spin.
check / replace the start run capacitor for the motor
have a electrician do it or a service technician if you do not recognize it
it is normally up near the control panel
Oct 19, 2015 | Haier HLP21N Washer
Whirlpool washer fills sometimes and won't agitate or spin or drain what should i do
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Jul 24, 2014 | Whirlpool Washing Machines
My washer will not spin or agitate, but will fill & drain
with it empty need to look at the bottom of the unit and see if the pulley and belt setup is bad.. my sisters un it broke the pulley and hers is newer..seems they dont make them to last anymore..
Feb 08, 2014 | Washing Machines
W600 fornt load washer does not wash or spin. It does fill and drain fine.
Jan 12, 2014 | Asko W600
Kenmore top load washer won't agitate, but will drain and spin
your dogs may be bad in the agitater.. if u open the lid and turn the agitater back and forth does it rachet or does it turn freely both ways?
Dec 13, 2012 | Kenmore Washing Machines
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Oct 11, 2012 | Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
Sep 30, 2012 | Roper Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Will not agitate or spin. Have replaced the belt (was worn) but still wont. Fills fine. When I first put the new belt on I ran it empty (stopped it when it started agitating, moved it to sping, stopped...
Thanks for choosing FixYa and welcome. If you have a washer that has a weak agitation or no agitation at all, here are some possible solutions. You need to check your belts. Most washers have one or two belts. Check your lid switch. If a lid switch is bad, it can cause the washer to not work properly. Sometimes, they will not work at all. Make sure you check your drive motor. The drive motor controls the spinning, draining, and agitation. Most washers have the reverse motor, meaning the shaft rotates in both directions, clockwise and counterclockwise. It is possible to lose one direction and not the other. Some washers have a clutch that controls the agitation. If it is bad or worn, it may prevent the agitator to work. Most of these washers come from General Electric. You could have a bad motor coupler. They are located on the side of the motor drive inside the washer. It is also possible that you have a bad transmission. Check the agitator itself. You could have a bad spline or two. The splin accompanies the shaft and allows the movement of the agitator. If you rule out all the parts above, you may have an electrical issue or an issue with the control board. It is very important to test each part and make sure it is getting power. If a part is not working and not getting any power, the power loss may be the reason that it doesn't work. You can test the current in the wires with a voltage meter. Thank you very much for reading this tip and thank you for using Fixya. As for the spinning, you need to check the lid switch. It may be bad. It may be your motor drive since it doesn't do both. Have you had draining problems?
Feb 23, 2011 | Maytag HAV3460AWW Top Load Washer
Crosley CAWC529JQ Top Load Washer Logo
61 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
jdthefixer
Karl H
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
