Question about LG WM1812C Front Load Washer
Lg wm2016cw smoke comign out of washer
Smoke coming from tub
SOURCE: Strong meldew smell from washer
Clean out the drain filter. mine had one of my kids socks stuck in it. Any small item could get clogged, it is best to use a laundry bag for those items.
Posted on Jul 13, 2008
  • 489 Answers
SOURCE: LG WM2016CW front load washer
Check to make sure that the filters in the water valves are not clogged up.  Go behind the machine, turn off the water supply and disconnect the hoses on the machine side.  Look inside the water valves and check the filter screens to make sure they're clean.  Get a large bucket and open the water valve to clear out the hoses and make sure you have good water flow coming out of the hoses.  If both of those situations are cleared up, your machine should work properly.
Posted on Sep 29, 2008
SOURCE: The lights on my LG WM2016CW will not come on.
While looking for the fuse, which I could not find despite opening up the machine from the back (and vacuuming underneath--yuck!), I left the washer unplugged for about 30 min. From reading other forums and such, I realized that unplugging for a little while is often the solution because the prolonged (at least 5 min) lack of power triggers the system to reset. Sure enough, when I went back to plug it in and give up for the night, the thing worked fine. Good luck to anyone else out there!
Posted on Aug 24, 2009
SOURCE: LG Model WM2016CW Front load washer is 1 year old.
Same thing happened to me
I freaked out
Then I emptied the water basin, on the front of the machine near the bottom. then it started up and worked
Posted on Aug 17, 2010
pctech1
  • 1940 Answers
SOURCE: my washer won,t drain how hard is it to replace
Open the little door in the bottom left hand corner, unscrew the black cap and drain the water out.
If this doesn't fix the problem, you may need a new Drain pump. Unplug the machine. Remove the filter recess by removing the one screw inside and using a putty knife at the left and / or right edge and popping it out. Pull the machine out about 18 inches and tip it back, resting it against the wall. Remove two more screws behind where the recess was holding the pump housing on. Reach under the machine and remove pump. There is a tab to depress under the pump housing to release it from the base. The pump motor is held onto the housing by three screws. Remove them and inspect the impeller to see if it has come off the shaft. If it has, pushing it back on will not solve the problem, as it will come off again. Install new drain pump and reassemble.
Posted on Feb 27, 2011
Why does a front loading lg washer smoking in spin cycle
Lg washer smoking - YouTube
? 1:06
https://www.youtube.com/watch?v=vKeIDM78CFI
Mar 29, 2013 - Uploaded by mrsbarney04
Lg washer smoking ... LG Front-Load Washer Disassembly -Washing Machine Repair Help ... Lg Washer model #WM2016CW PARTING OUT! ... Roblox: Chaos Washers -SPINNING IN A GIANT WASHER WITH FANS!
GE Washer Diagnostic - Loud Noise and Smoking ...
? 2:33
https://www.youtube.com/watch?v=a-ONJ2_RQvk
Jul 7, 2013 - Uploaded by ApplianceVideo.com
Service your trusty GE Washer that has these following dilemmas: Loud Noise ... L-G. Samsung Kenmore ,LG, Whirlpool, Electrolux Speed Queen, Amana ... Front Load Washer Repair - Bearing and Seal Failure Mode - Duration: 14:44. ... WasherDiagnostic - Very noisy during spin -GE, General Electric, ...
LG WM1815CS Front Load Washer Smoke burning smell ...
Jan 25, 2016 | LG Washing Machines
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
How do you fix the rear tub spindle on an lg wm2016cw?
If its the main drum bearings gone then this will entail a complete strip to access them. The parts are available online, just have your serial no, model etc ready and trawl through various web appliance sites to find the best price. You will need a fair amount of mechanical / DIY knowledge to carry out this task. There are lots of parts and electrical connections.
Aug 05, 2014 | LG WM2016CW Front Load Washer
What are the most major issues with lg wm2016cw washers?
all washing machines suffer from same things.overloading throws balance off stuff in pockets finds its way to the pump too much powder is used causing blockages and soft water areas cause elements to fir up with limescale.eventally motor brushes wear.but theyre cheap to replace
Aug 05, 2014 | LG WM2010C Front Load Stacked Washer /...
WHY IS WATER IS LEAKING FROM WASHER?
you just have to pull it out and take back panel off start filling with water and watch and see where it coming from a few rubber hoses under there or water pump.
Jul 30, 2014 | LG WM2016CW Front Load Washer
Bearing noise in a lg washer
Check your owners manual, some models warranty the rear tub that houses the bearing and the inner spin basket. If not the rear outer tub and the gasket between both tubs will have to be replaced the correct the problem. If out of warranty it may not be cost effective to repair.
Apr 04, 2014 | LG WM2016CW Front Load Washer
LG Washer leaking water underneath
Some times a water valve can have a leak inside the machine coming out the bottom.
Also make sure the filter in the front lower left corner is tight in the housing.
Tub inside could be damaged from shipping.
Sears should be able to fix you up.
Jan 20, 2010 | LG WM2016C
Aug 24, 2009 | LG WM2016C
LG WM1812C Front Load Washer Logo
744 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
