Question about Xerox Phaser 8550DX Laser Printer
(027-529) : data read failure - Xerox Phaser 8550DX Laser Printer
E315-000d how to solved
a fault is detected when encoding image data,
1.A chip failure is found in writing/reading/verifying the image data by using the register of encoding chip.
2.an error occurs when encoding image data
Apr 02, 2014 | Canon imageRUNNER 8500 Copier
Cmos beep codes
do you know which bios your computer is running ?
AMI BIOS beep codes 1 beep - DRAM refresh failure
2 beeps - Parity Circuit Failure
3 beeps - Base 64K RAM failure
4 beeps - System Timer Failure
5 beeps - Processor Failure
6 beeps - Keyboard Controller / Gate A20 Failure
7 beeps - Virtual Mode Exception Error
8 beeps - Display Memory Read/Write Failure
9 beeps - ROM BIOS Checksum Failure
10 beeps - CMOS Shutdown Register Read/Write Error
Phoenix BIOS BEEP codes. 1-1-3 CMOS write/read failure.
1-1-4 BIOS ROM checksum error.
1-2-1 System timer failure. (Programmable Interval Timer PIT)
1-2-2 DMA (direct Memory Access) failure.
1-2-3 DMA page register failure.
1-3-1 RAM refresh failure.
1-3-3 64K RAM chip or data line failure.
1-3-4 64K RAM odd/even logic failure.
1-4-1 64K RAM address line failure.
1-4-2 64K RAM parity error.
2-?-? Any beep series starting with 2 beeps indicates a 64K RAM chip or data line error.
3-1-1 Master DMA register test.
3-1-2 Mslave DMA register failure.
3-1-3 Master interrupt mask register failure.
3-1-4 Slave interrupt mask register failure.
3-2-4 Keyboard controller failure.
3-3-4 Screen (video) memory failure.
3-4-1 Screen initialization failure.
3-4-2 Screen retrace failure.
4-2-1 Timer tick interrupt test failure.
4-2-2 Shutdown test failure.
4-2-4 Unexpected interrupt in protected mode.
4-3-1 RAM test failure above address 0FFFFh (64K +)
4-3-3 Interval timer channel 2 test failure.
4-3-4 Time of day clock failure.
4-4-1 Serial port test failure.
4-4-2 Parallel port test failure.
4-4-3 Math Co-processor failure.
BEEP codes may vary dependent upon the revision of BIOS. This list is for reference only
hope this helps
Oct 10, 2012 | Intel Mother Board S5520HCR (988889365963)...
Loss of power ,idling lumpy
You need it plugged in to read the live data but it sounds like a very common mass air flow failure, the live data will show this up.
The mass air flow will have a real big impact on the power.
Regards
Lloyd
Dec 15, 2009 | Subaru Impreza WRX STi Cars & Trucks
I have error 0146 once i hit the diagnostics button on my laptop. i read from many sites that it is disk failure. does this mean that there is no hope for data?
It is a hard disk drive read/write failure. It may be possible to recover data from the drive once it is replaced if you slave the drive on another system. If that fails, then there is the option of data recovery from places like Ontrack.com but be warned, data recovery is expensive
Nov 10, 2009 | Dell Inspiron 6400 Notebook
Hard Disk Problem
That failure is predicted by the SMART reporting system. Its a status chip on the drive that reports to apps that can read the smart data from the hard drive. Its not always accurate but it usually is.
Time backup your data on that drive ASAP and then buy a new drive.
Sep 07, 2009 | Toshiba MK1637GSX 160 GB IDE Hard Drive
E000315-000d Imagerunner 3320i error code at start up
E315
A fault is detected when encoding the image data.
1. A chip failure is found when writing/reading/verifying the
image data by using the register of the encoding chip.
FAX failure
2. An error occurs when encoding the image data
Aug 10, 2009 | Canon Image Runner 3320I Copier
Fatal error message 13DOH
Per service manual, Parameter Chip failure
Data, which has been written, is read, checked, and
found faulty; rewriting of the data is then executed and
the data is checked to be found faulty during re-reading.
• A count value is found faulty during reading.
• Parameter Chip is detected to be not mounted during
initial mounting detecting sequence.
Did you recently have the firware updated? Or the main board has crashed. have service Technician reflash the software, or down load it.
Jul 31, 2009 | Konica Minolta Office Equipment & Supplies
Read disc failure
Most local computer shops will recover data from a failed drive for a certain amount. Google "Data Recovery" with your state following that phrase
Mar 12, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Xerox Phaser  8550DX Laser Printer Logo
53 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
