Question about Xerox Office Equipment & Supplies
027-529 fuji xerox
Data read failure
3 Suggested Answers
SOURCE: Xerox 8550 hardware failure front panel data path failure 16.4
It sounds like the display panel has gone bad. Possibly the text is garbled or only half shows up??
If you contact Xerox and tell them, I believe they will send you a replacement display panel - even if your printer is no longer under warranty -- IF your printer has never been sent a replacement display.
I've had this happen on several of these printers - I believe they know there is an issue with the display panels, which is why they are sending replacements for free.
I find the easiest way to contact them is to go through the support section at xerox.com and search for that error, then hit contact us at the bottom of the page. It'll ask for your contact information as well as the serial number of your machine.
Posted on Jul 04, 2009
  • 28 Answers
SOURCE: Data path failure 16.4 xerox 8500
This model of printer has a known fault with the LCD panel.
Contact xerox in your country, who will arrange to have a replacement front panel sent out to you to install - eeven though it is out of warranty and at no charge
Posted on Aug 06, 2009
How to refill fuji xerox docuprint p205b toner cartridge
Need to know how to refill the cartridge for xerox p205b , please email to me : myprinterwork@gmail.com . toner and chip also i got
Sep 05, 2012 | Fuji Office Equipment & Supplies
I by new laptop with windows 7,but I can't install
You can try going to the link below and download the latest drivers directly from Fuji Xerox This link will bring you to the download page for the Fuji Xerox Phaser 3124 for windows 7 install this driver and you should be all set
http://www.support.xerox.com/support/phaser-3124/file-download-fx/enau.html?operatingSystem=win7&fileLanguage=en_GB&contentId=105996&from=downloads-fx&viewArchived=false
Jun 15, 2011 | Fuji Office Equipment & Supplies
FUJI XEROX DocuPrint M205 b - printer error - paper size mismatch
i just bought a FUJI XEROX M250b and it keeps displaying paper size mismatch not allowing me to do any printing or use other application. ive read the manual over and over and i cant fix this problem. Anyone have any idea how to fix this?
Apr 20, 2011 | Office Equipment & Supplies
When i print using my docuprint 203A fuji xerox, the printout result paper was cover with black all over. what does this mean?
This is a rebadged Brother Printer.
Possible causes for a solid black output:
1 Corona failure
Is the corona wire dirty?
Clean the corona wire with the wire cleaner.
2 Corona wire broken?
Replace the drum unit
3 Are the charge electrodes between the printer body and
the drum unit dirty?
Clean both electrodes.
4 Harness connections?
Is the laser unit connected to the main PCB correctly?
Connect the harness between the laser unit and the main PCB
correctly.
5 High-voltage power supply PCB failure
Is the problem solved after replacing the high-voltage
power supply PCB?
Replace the highvoltage power supply PCB.
6 Main PCB failure
Is the problem solved after replacing the main PCB?
Replace the main PCB.
7 Laser unit failure
Is the problem solved after replacing the laser unit?
Replace the laser unit.
Good Luck!
May 12, 2010 | Fuji Xerox® DocuPrint C3055DX Laser...
FUJI XEROX DOCUPRINT C1110 WRONG PAPER SIZE MESSAGE
This printer have a sensor to remind the user when using a wrong paper size.
If you still using a paper that not the same with your software settings, it's still reminds you.
I solve this promblem by after print my works I just press "Cancel Jobs" button to clear a data.
Good luck.
Jan 05, 2010 | Fuji DocuPrint C1110B Laser Printer
Dec 09, 2008 | Xerox Phaser 8500/DN Printer
Fuji xerox docuprint c1618 error
001-360 Fan motor failure Check Fan Rear Check Fuser Fan Check voltage on fan rear should be between 15VDC and 24VDC. Check voltage on fuser fan should be 24VDC
Dec 29, 2007 | Office Equipment & Supplies
16 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
