Question about Zebra Z4M Printer
Zebra Z4M won't print whole label
I have a Z4M that was working fine until I started trying to get it to function with label peel, rewind. I changed a lot of settings, pushed a lot of buttons... now it won't print the bottom 1/5 of my labels. It is set to the right label size. Any ideas? I've even tried reloading the drivers.
  • 4,889 Answers
Did u try system restore?It will restore all of ur settings to how they were when it was working...
Posted on Oct 11, 2007
6ya staff
SOURCE:
Z4MPLUS doesn't recognize the MEDIA(LABEL) automatically.
you should recalibt=rate the printer.
Are you sure that your previous label was not longer?
With the autocalibrate function activated the printer should try to detect the correct length. If it doesn't the yoou have
- A problem with the label border
- Preprinted stuff which the printer detects as to fo feed
Dec 09, 2013 | Zebra Z4Mplus Label Printer
Zebra LP 2844 doesn't feed label all the way out for tearing off. When I print a label everything prints fine, however the last 1/4" or so is still left in the printer. Technically, it's like the printer...
Hi Brian,
When the last label printed is still under the printhead, that means the printer is in "rewind mode". There should be an option for "tear off" mode in the printer driver. This is the mode that pushes the last label printed out to the tear bar. The printer will then "backfeed" when printing the next label. Peel off mode is used if you want to print a label and have it "peeled" off the liner so that you can just pick up the label off the liner and apply it. That takes the rewind option to be installed.
Watch out though, if you are using a label software package, there might be a setting in the label format setup for "tear off" which usually overrides the settings in the printer.
Hope that helps !
May 06, 2010 | Zebra LP 2844 Thermal Printer
My Zebra Z4M stopped rewinding the used liner
This could be something simple like not having rewind (peel) selected in the setup menu. Or you could have a bad rewind motor or main logic board. Remove the cover and make sure no plugs have come loose. There isn't an easy way to check the motor or logic board unless you have a spare that you can swap.
Jun 25, 2009 | Zebra Z4M Printer
Zebra 4 Plus pause botton shows a fast blink when using take-up mode. have to push in peel lever to get it to print. Please help
Are you sure you are not in peel off mode? It is waiting for a sensor change. When you push the lever, you may have triggered this and allow it to print another label. Put the printer in Rewind mode or something else and see if it changes for you.
Apr 20, 2009 | Zebra Z4M Printer
Can't print images on zebra z4m printer
Check the "Dithering" setting in the printer driver. Turning "Dithering" on improves graphics but reduces speed of processing.
Apr 07, 2009 | Zebra Z4M Printer
Slow Printing on Zebra Z4M
An unorthodox solution is to install an old driver. Another solution is to use with Codesoft the driver from www.seagullscientific.com, and with Zebra Designer, the Zebra Designer driver. If the printer is connected to the serial port, speeds up communication.
Roberto Martinez
Mar 30, 2009 | Zebra Z4M Printer
Zebra 105SE label material will not retract in prep for next Lab
The platen is the driving force for the label. the main drive belt runs all functions in the printer.
Is the back feed turn on in the printer? Check the setup.
Also if the print driver is set(doc/properties settings on print depending on software) to use pirnter settings, and the back feed is turned off in the printer, it will not backfeed.
Feb 24, 2009 | Zebra 105Se Thermal Printer
ZEBRA Z4M PRINT QUE ERROR
Try a reset: press the PAUSE and FEED keys while turning the printer, release the keys when feed the label. You can also try downloading the latest firmware.
Jul 02, 2008 | Zebra Z4M Printer
Zebra Z4M Plus
this is a color printer or not
Oct 01, 2007 | Zebra Z6M Plus Thermal Label Printer
Zebra Z4M Printer Logo
263 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Gateway information...
Marvin
Marvin
Ekse
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
