Question about Frigidaire Ovens
Fridgaire gas oven prob error code
Oven beeps and reads prob err. we are not using a probe
vitg55
  • 70 Answers
SOURCE: dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
Posted on Dec 18, 2008
SOURCE: I have Fridigaire double oven part# PLEB27T8ACA with F8 code prob
wow, that is so weird...i was just getting ready to write the exact same thing. this last time mine beeped, i just kept letting it beep for several minutes. if kept on. i then went in and pressed all the buttons except for cancel and nothing happened. then i pressed the oven light button. the beeping stopped. not sure if it's coincidence or if that was what i was supposed to press. i will keep messing with the buttons and let you know if i figure it out. i will dread if it beeps all night long.
Posted on Feb 14, 2009
jumptrout51
  • 3361 Answers
SOURCE: Oven Temperature rises above setting
You may or may not see the error code.
The temp probe is less expensive and is most likely your problem.
If you choose to replace it and the problem remians your ERC will have to be replaced.
ERC electronic range control
Posted on Mar 12, 2009
SOURCE: kitchenaid display reads insert temperature
We just had this problem with our Kitchenaid Superba electric oven. It started beeping for no reason and showed the probe symbol. I actually never used this probe, ever! Call to the tech people: go get a service man! right...
My husband, smarty pants, lol, put a bowl of water into the oven, plugged the probe in and dunked it into the bowl with water, set the temperature to 85 C (that would be 200 F, I believe, but better check it in the manual) and let it heat up. (In any case, set it lower than water boiling temperature!)
That actually did the trick! Once it reached the set temperature, it shut itself off and the probe light went off! Yeah! good hubby!
Posted on May 01, 2010
jumptrout51
  • 3361 Answers
SOURCE: My GE gas oven flashes a f4 error code several
Your temperature sensor located in the top right of the oven has shorted out and must be replaced.
The GE brand part is a little on the expensive side.
You can use the Whirlpool sensor at 1/3 the cost.
Posted on Sep 20, 2010
Fisher double oven OD302. Periodically it will start beeping, shut off with no default code
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :
http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
How to Get GE Oven to Stop Beeping eHow
Jan 09, 2017 | Fisher Ovens
My Miele oven has a constant alarm going off every time I try to turn it on, it won't let me set the temperature
Oven keeps beeping:
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
Nov 30, 2016 | Miele Ovens
Turned oven to bake it keeps beeping with message "door"
Oven keeps beeping:
Apr 21, 2014 | Whirlpool Ovens
What causes the beeping sound coming from my Hearthstone propane stove? I bought my Hearthstone propane stove secondhand.
Oven keeps beeping:
Read more :
Jan 19, 2014 | Thermador Ovens
F3e2 error
Oven keeps beeping:
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html How to Get GE Oven to Stop Beeping eHow
Jan 03, 2014 | Whirlpool Ovens
F10 oven code frequently beeps,often after cooking is over and oven is coolind down at different temperature settings tempermental some times it works sometimes it does not.
The "F10" error code caused by the runaway temperature.
The first thing I would check is the resistance across the oven temperature probe (aka oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It suppose to be about 1100 Ohms at the room temperature.
If the resistance at the EOC plug is wrong, then measure the oven temperature probe resistance at the probe plug.
If it's wrong - replace the oven temperature probe. It's better to hardwire it, using a high temperature ceramic wire nuts.
If the readings at the EOC and at the oven temperature probe plug are different - check the wire harness between the oven temperature probe and the EOC.
If there is nothing wrong with the oven temperature probe resistance - replace the EOC.
Jul 15, 2011 | Frigidaire Ovens
Was cleaning oven and error code F10 appeared what is a error code F10?
hello there"
- The part number for the oven temperature probe is AP3704441
- The part number for the EOC is AP3776874
- The part number for the EOC overlay is AP3778486
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4431-f10-error-code.html#ixzz156CO7RjB
Nov 12, 2010 | Frigidaire Ovens
The oven warms up and then starts beeping and flashes f10 err.
The "F10" oven error code means "Runaway temperature".
If you have technical skills, you can try to diagnose and repair yourself, otherwise, call a qualified appliance repairman.
Locate the temperature probe wire plug at the Electronic Oven Control (EOC) and measure its resistance. It’s supposed to be about 1100 Ohms at the room temperature.
If the reading is wrong, replace the oven temperature probe.
If the reading is correct, replace the EOC.
Jan 28, 2010 | Kenmore Ovens
My oven door locked itself. It will not let me use the keypad.
The F1 code means the ERC or the touchpad is bad.
F1 fault code generally implies that the electronic oven control has detected an internal malfunction. Most likely the cause is a shorted keypad which would require a new electronic control board. The electronic control board internal checksum may have been corrupted which also would require a new electronic control board. The control also may have sensed a potential runaway oven condition. The control may have a shorted relay, RTD sensor probe may have gone bad. The RTD is the oven temperature sensor probe which needs to be ohmed and the resistance should be 500 ohms or more at room temperature. If the resistance is less than 500 ohms, replace the oven sensor. Normally a technician is needed to make this check.
I recommend calling a service technician to diagnose and repair your oven.
Apr 11, 2009 | Kenmore Ovens
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
22 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
