Question about Samsung PCK5315RX TV
No video my samsung lcd has no video but still has the audio. i checked a few times and everythings hooked up right and tightly in place. whats wrong could it be a blown fuse?
  • 979 Answers
More likely a blown lamp...accordianman
Posted on Feb 01, 2008
SOURCE:
Why am I getting no sound?
I hope u might have muted the sound or batteries of the remote are to be replaced /also check left right connection of the out put
Dec 23, 2014 | Pioneer Audio Players & Recorders
Ms-7108v1
1 long beep dram refresh failed
remove everything
JUST INSTALL MIN. RAM, CPU, CPU FAN, POWER CONNECTION, THAN TURN MACHINE ON, IF OK, CONTINUE INSTALLING I DEVICE AT A TIME UNIT YOU IN COUNTER AN ERROR THAN YOU WILL KNOW WHAT IS WRONG.
now a few things to check video card, ram, cpu fan plugged in right area,
you mite want to reset the cmos, by jumping the connectors for few seconds, then turn machine off, remove jumper, than just install cpu and fan, ram, speaker, keyboard, turn on if ok add video card, turn on , if ok, than install hhd, 1 at a time, than restart system if boots ok than move to next device, keep doing this until you installed everything you want or have to have in the system
Jun 07, 2014 | MSI 848p-neo2-v-848p Neo2-v Intel 848p...
How to connect my bose solo to my 2009 samsung tv
sounds like you have it set correctly..do you have any other sources than external,(such as audio out) ?If so that should solve your problem...does the system have any other connection outs, such as red white audio cables (LR audio )? You can use them as external when the optical is unplugged...if you get sound you either have a bad optical cord or the output for it is defective..good luck GOD BLESS
Oct 12, 2017 | Samsung LN46D630 46 inch LCD 630 Series TV
I cant get any color when i hook up my x box orginal.. tv color works fine.. i have tried plugging the white into the blue and nothing happens.. What needs to be done to be able to have color when im on...
White is your audio signal, not video. If you are using a composite hook up, yellow is your video and needs to go in the yellow slot. White and red is your left and right audio. If you are using a component hook up, then you will need to use red, green and blue for video and white and red for audio.
Apr 11, 2011 | Samsung SyncMaster 2333HD 23 in. LCD TV
I have a Samsung LNS4051D LCD screen with the typical problem of no video but functioning audio. Or more accurately, no light......at the right angle, you can see the image being projected, there just is...
If the TV is working properly with full back lighting then you've ordered the right part which you said "H140024W21B fixed the issue" Now the other part H140024W21H is the other half that hold the transformers to convert the electrical current for the bulbs to light.
Apr 02, 2017 | Samsung Televison & Video
I purchased aRCA 250W DVD Home Theater System with
do you have a set of cables coming from the tv AV out to your home theater system? if not you need to you can use coax out or anolog out either one
Dec 03, 2009 | Televison & Video
When turning on my Samsung lcd i get a few
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 16, 2009 | Samsung LNT5265FX 52 in. LCD Television
My Samsung LNR408D TV is having color problems...
I would replace the main board (Audio/Video Board).
Nov 08, 2009 | Samsung LN-R408D 40 in. LCD HDTV
How to connect?no instructions
ok maybe this will help.
make sure the video and audio are in the right place... setup:
  O OOX yellow OOX white OOX red OOO OOO
then turn device on (dvd/vcr) and on the remote press input button at the very top. this would set your device to video one screen, and you can watch whatever it is that you hooked up.
for cable or antenna hook that up then press reset button on remote ( bottom right hand side)
Jun 02, 2009 | Sanyo Vizon LCD-15A2 Television
Televison & Video Logo
77 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
