Question about Sanyo AWM-3500 CD Shelf System
Sanyo Awm 3500 manual - Sanyo AWM-3500 CD Shelf System
How to play preset radio stations on sanyo AWM-660. Do you have to remember the preset numbers?
Once the stations have been stored in memory, you simply press the preset button for a particular station. Of course, you will remember which station was assigned to which button. :-)
Nov 12, 2016 | Sanyo AWM-660 CD Shelf System
WHERE CAN I FIND A DOWN LOAD OR OTHER MANUAL
go to http://www.hifi-manuals.com/Sanyo/AWM-2600/downloads
Oct 22, 2015 | Sanyo Cameras
Awm 660 bass
Does the manual list the part number of the remote? If it does you can search for a replacement on-line. If you are from the UK Curry's Partmaster has a good range of Sanyo remotes.
Sep 02, 2013 | Sanyo AWM-660 CD Shelf System
Need to connect a 6 cannel 9 pin audio cable subwoofer to a standard audio receiver. is there an adapter to make it plug into rca javks?
Nothing commercially available as the pin-outs are all different and 9 pin din is a non standard connector. Contact the manufacturer directly and ask tech support for pin out diagram.
Oct 27, 2011 | Sanyo Micro Shelf System AWM 3500 Shelf...
Can the AWM-660 Sanyo Shelf system connect to an iPod?
Yes but you need a adapter like one you would put in a car with a tape player.
Jan 18, 2011 | Sanyo AWM-660 CD Shelf System
Sanyo stereo AWM-2700U, cd player says'' door'' just blinking.
Press Eject button while tapping on the top. It should open
Dec 28, 2010 | Sanyo AWM-2800 CD Shelf System
Clock set instructions for Sanyo stereo awm2800U
you need the remote to change the clock press timer am 1200 blinks press timer again for at least 2 seconds the hour blinks press tuning/time set plus or minus press clock adjust the minute will blink press time set to adjust minutes then clock adjust there you go...
Mar 10, 2009 | Sanyo AWM-2800 CD Shelf System
Sanyo AWM-3500 CD Shelf System Logo
96 people viewed this question
Top Sanyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
